Likes Likes:  8
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 49
Thread: One wheel drive
    30+ Posts
    Jun 2018
    Las vegas, nv, USA
    Default One wheel drive
    Hey I got a question. I have a trike that's one wheel drive and pulls hard to the right. It's tiresome to use the right hand to fight back. Does anybody know if a steering dampener would help this issue?
    Steven, in alignment terms that is called torque steer, yup even from the rear
    If you bisect the thrust angle front to back the rear may push from off the center line or the thrust angle
    With cars you can adjust the back end, bikes not so much
    30+ Posts
    Jun 2018
    Las vegas, nv, USA
    Will a steering dampener help?
    Quote Originally Posted by vegasboy View Post
    I dunno for sure
    I have one on the front end of my Freewheeler, it helps with the shake in the front end
    You may try a bit lower air pressure to compensate
    Is it pulling to the drive side ? I would guess so
    30+ Posts
    Jun 2018
    Las vegas, nv, USA
    It is pulling from the drive side. I know the steering stabilizers help out with high speed wobbles I just didn't know if it would help with a consistent pulling on the bars.
    Yeah, I dunno
    I would try a bit lower PSI in the opposite rear tire this could plain it out some
    30+ Posts
    Jun 2018
    Las vegas, nv, USA
    Yeah I'll give it a shot see what happens. Maybe if that fails I can put a really thick spring on the left hand side. LOL
    30+ Posts
    Jun 2018
    Las vegas, nv, USA
    Coincidentally if I'm traveling down a road that has a High middle center and a side slope off either end, if I'm in the fast lane it'll alleviate some of the pressure because the trike is tilted to the left.
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    If you're saying there's two rear wheels and only one drives, then you have no differential correct? If thats the case I've seen two trikes built that way and neither was successful for the very reason you describe. A steering damper wouldn't help in that situation.
    What make/Kind of Trike are you taking about........
    750+ Posts
    Jan 2010
    east windsor ct
    the answer to the question is no
    a damper is basically a shock absorber.. as in a car it wont "hold" the front end any more than it would hold up a car
    do you have a stock front end? or raked trees? any idea what the trail is?
    i anything has a diff in it, it is not one wheel drive
    i assume this is mostly on right side of the road / high way... try passing lane on the hyway or any place the crown in the road is to the left ... we can go from there ..
    stace
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    with some "creative" wheel alignment......i'm talking stock car racing alignment tricks, camber caster and stagger, maybe you could get the pull out of there at a given power input. that said, some state reg's want the front wheel centered with respect to back wheels centerline w/in 1 inch....thats for trikes, bikes must be w/in also. they don't say anything about stagger, however enough stagger would affect the centerline figures at some point. just a thought...
    30+ Posts
    Jun 2018
    Las vegas, nv, USA
    I read the instructions on how to post a pic but I don't see any button to click on to even start I'm using a phone. Any help on this?
    30+ Posts
    Jun 2018
    Las vegas, nv, USA
    I've been all over this form trying to find out how to post pictures from a phone. Haven't found one post yet that tells me what to click on. The screen I'm looking at doesn't give me any options to do anything but title, message, submit reply preview post.
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Have you checked out this thread on how to post pictures?:
    https://www.triketalk.com/forum/thre...Post-a-Picture
    This may help.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    One wheel drive will always favor a circle direction. If no diff. Is wanted, then conciter a live axle. Although I don’t know what your working with , Live axle downfalls will be front plowing along with possible road wander. Sort of like welding the spider gears. It will also raise havoc on the axle as twisting and possibly braking it could occur. (Sounds like drug side effects).
    30+ Posts
    Jun 2018
    Las vegas, nv, USA
    Yes as previously stated I have read these instructions. However it says to click on the editor toolbar above the text box. There is no editor Toolbar to click on when using a phone.
    30+ Posts
    Jun 2018
    Las vegas, nv, USA
    Apparently all instructions on how to insert pics are done on a laptop. I must be the only guy on this form using an Android phone to post apparently. This is ridiculous, I even watch the video I have to insert the picture but it was also done on a regular computer not a phone. It gives me no options to do anything but post a title a message preview post and send that's it nothing else on the entire page when using a phone no options whatsoever. If I could post pictures you guys could help me out a lot faster this format is unlike any forum I have ever seen that I've used previously on the internet. It doesn't need to be this difficult it's not rocket science.
  19. #19
    30+ Posts
    Jun 2018
    Las vegas, nv, USA
    Nevermind I figured it out had to scroll all the way to the bottom of the page and click on the full website and get out of the mobile the mobile website won't let you do anything give me a second I'll put some pictures up
  20. #20
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Calm down Steve ,
    Try this; Reply to thread, scroll down to manage attachments, click on it, upper right ,it says add files, click, choose file, click, photo library or take photo, click on one, after you pick the pix click on upload on upper right, after it shows up, click insert inline , click on done, then you should be good to go. Hopefully.
  1. Rear Wheel Drive Assembly Lube Points
    By nevtat in forum Harley Tri Glide
    Last Post: 11-28-2017, 06:11 PM
  2. voyager trike issue...Drive wheel problem
    By baba67 in forum Outrigger Style Trikes
    Last Post: 11-17-2015, 09:38 AM
  3. Swivel-Wheel Trailer behind 5th wheel
    By Doc Dyna in forum Trailers / Campers
    Last Post: 10-16-2012, 10:04 PM
  4. Replies: 4
    Last Post: 09-22-2012, 08:09 AM
