Likes Likes:  2
Thanks Thanks:  2
Results 1 to 8 of 8
Thread: 2014 Tri Glide rear brakes, HELP !!
    Aug 2021
    CAPE GIRARDEAU
    Default 2014 Tri Glide rear brakes, HELP !!
    I am replacing rear brakes on 2014 Tri Glide, due to rotors being scored too bad, HOW do you get piston pressed back into caliper ?
    Welcome to Trike talk and your first post
    The first thing to do is put some slack in the E brake
    Next step, remove rear master cover on reservoir, remove some fluid ( as you push the rear pistons in the fluid in the reservoir will rise Next, slowly ( using a C clamp ) push the piston in until it seats ( be careful to not push any further)
    Now you can install the pads and reassemble caliper( I like to bleed each wheel as I go along)
    Do the same for the other caliper
    Once you are done, slowly pump the pistons out and rebleed the system
    The last step is to readjust the parking brake
    Aug 2021
    CAPE GIRARDEAU
    Default Rear brakes 2014 Tri Glide
    Jack, thanks for your reply on my question, we have Ebrake fully disengaged, but piston will NOT move, no matter how hard we compress C clamp. I know on older models (only ones I could find on "YouTube" , you had to remove a bracket from the Ebrake.......your saying the piston should just slide back into the cylinder pretty much the same as a cars front brakes?
    Quote Originally Posted by Chilltrike View Post
    Yes, surprising, the pistons do not move much, try opening the bleeder valve a touch, this will force the fluid out as the piston compresses
    Your brake caliper and pads should look like this
    Chris .......Welcome To Trike-Talk.............
    I hope you are making progress?
    100+ Posts Koolbreeze's Avatar
    Oct 2018
    Stewartstown, PA, USA
    They have to be turned in clockwise at the same time as being compressed. You can buy the tool or rent/free at an autoparts store. There will be two little indentations on the piston.
    https://www.autozone.com/test-scan-a...iece/94798_0_0
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    Quote Originally Posted by Koolbreeze View Post
    I use a pair of needle-nose pliers, it works great.
    2019 TriGlide, Twisted Cherry. Khrome Werks 2+2 bars, Eagle Lights front and rear
    DK foot board extensions, rear bearing retainer plates, tourpack relocation kit and oil filter relocation kit
    with cooler, powder coate tod wheels, Progressive 444 shocks,. More
  1. Rear Brakes on Tri-Glide
    By OlBandit in forum Harley Tri Glide
    Last Post: 08-01-2021, 12:12 PM
  2. 2014 tri glide brakes
    By LarryF in forum Harley Tri Glide
    Last Post: 07-15-2018, 02:17 PM
  3. Help, 2014 TG Rear Brakes
    By Jlbhdtrike in forum Harley Trike Conversions
    Last Post: 03-05-2015, 10:44 AM
  4. 2014 Tri Glide Brakes
    By Will Parish in forum Harley Tri Glide
    Last Post: 10-12-2013, 10:25 AM
  5. Tri Glide Rear Brakes
    By trikermutha in forum Harley Tri Glide
    Last Post: 04-05-2012, 12:58 PM
