Likes Likes:  7
Results 1 to 16 of 16
Thread: Frankenstein trike owners ?
    80+ Posts ncbandit's Avatar
    Feb 2017
    Wilmington,NC, USA
    Default Frankenstein trike owners ?
    For the Frankenstein kit owners, if you ordered the raked trees from Frankenstein did they come with Fork leg extenders? My concern is the raked trees will lower the front end too much. If fork extenders where not used did the front end drop seem noticeable? Any comments are appreciated.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    That is probably something to ask Frankenstein. Why not order a tree from ZOOK the site owner. I know his trees of 4-5 degrees do come with 1.5" spacers but specifically ask for them.
    Jim Murphy
    Iron Butt Rider 2001
    Feb 2017
    Wilmington,NC, USA
    Yes I agree. They have already been shipped and I will be calling them Monday. Being a trike novice the thought initially didn't cross my mind that extenders would be needed. I would assume (hope) they come with the kit.
    40+ Posts
    Jul 2014
    Pgh Pa
    When I converted my wife's Softail with a Frankenstein Kit, I used there raked trees and they said no extentions were needed.
    Feb 2017
    Wilmington,NC, USA
    Quote Originally Posted by monks View Post
    Thanks for the information. I called Frankenstein and they confirmed that also.
    250+ Posts
    Nov 2013
    homossasa fl usa
    No extenders supplied with my kit(Sportster) and no drop noticed. Trike sits level.
    90+ Posts Chappy KC's Avatar
    Apr 2015
    Marion, Illinois
    Quote Originally Posted by retread83 View Post
    How does that ride over the bumps?
    2017 Can Am Spyder RT-S
    Feb 2017
    Wilmington,NC, USA
    Quote Originally Posted by Chappy KC View Post
    You definitely feel the bumps more than with 2 wheels. I have 1000 miles on my kit now and only got irritated one time with a stretch of road that was extremely rough. Typically it's a non factor.
    Quote Originally Posted by ncbandit View Post
    If your shocks are adjustable work with it and the tire pressure. You can go as low as 22 lbs in the rear tires. It will improve the ride considerably.
  11. #10
    Feb 2017
    Wilmington,NC, USA
    I am currently running 25lbs in the back. I never messed with the shocks so I'm sure they are still set at the stock setting. Thanks for the suggestion, I may experiment a little bit.
  12. #11
    JMO That light of a trike 25 is to much
  13. #12
    Apr 2017
    Wynnum West,Queensland, Australia
    Default Tire presure
    Quote Originally Posted by gorilla View Post
    if your shocks are adjustable work with it and the tire pressure. You can go as low as 22 lbs in the rear tires. It will improve the ride considerably.
    mate im running 17 lb , i used these exact same tire , th10" on my saloon car ( speed way and run 15 lb but used a beed lock so no problems
    pat
  14. #13
    30+ Posts Mcgee10's Avatar
    Apr 2017
    Rockford, MI USA
    Default tire pressure
    Being new this week to my Frankenstein trike I did adjust the preload on my shocks some I went for real soft and that was worse stiffen them back up now about the same. Then I went to 20 lbs in rear tire got a little better I'm running 17 now and it's better I tried 15 but then the tire starts to look flat. Mine steers like a dream
  15. #14
    100+ Posts
    Mar 2017
    Bournville, OH, USA
    Default no extenders with my kit
    I am just now finishing up the conversion of my Road King, I did not receive any extender with my kit, I did get the triple tree also.
    not being very smart of some thing. what exactly are these extenders you are talking about, where do the fit on front end,
    thanks
    Hank
  16. #15
    Feb 2017
    Wilmington,NC, USA
    Quote Originally Posted by Hank62 View Post
    thanks
    Hank
    Hey Hank,
    I came to find out they aren't needed. Can't wait to see your final pics.
  17. DKCustoms postbit
  18. #16
    Jun 2008
    Lovington, NM, U.S.A.
    thanks
    Hank
    These are extenders for the GL1800, they fit in place of the oem fork cover on top of the fork tube and get clamped in the upper part of the triple tree.
    Retired trike builder
  1. Frankenstein owners
    By jerry1@iw.net in forum Frankenstein
    Last Post: 04-01-2024, 03:47 PM
  2. Frankenstein sportster trike
    By onebikerguy44 in forum Harley Trike Conversions
    Last Post: 07-07-2014, 07:15 PM
  3. frankenstein trike kit
    By Torchman in forum Harley Trike Conversions
    Last Post: 10-18-2011, 06:42 PM
  4. Frankenstein Trike website down?
    By oldnewby in forum General Discussion
    Last Post: 04-12-2010, 11:34 PM
