Likes Likes:  5
Results 1 to 20 of 21
Thread: Shifting
    100+ Posts haute pursuit's Avatar
    Aug 2016
    houston, texas, usa
    Default Shifting
    My FLRT only has about 400 miles on it so far, but when shifting, the audible metal to metal noise is extremely noticeable. Both down and up. Is this normal? Is it just that tight new?
    350+ Posts Springman2007's Avatar
    Sep 2014
    Grafton, OH, USA
    Quote Originally Posted by haute pursuit View Post
    Is this your first Harley? I have to tell you that you and the folks next door can always hear a Harley shift.... In fact that auditable "Clink" has always been something I love about Harleys.....its very hard to miss a shift with one..... and, new HD transmission whine like the dickens......
    With the above said. A factor in how your trans will sound is the type of lub/oil you use in it. HDs Syn makes for very loud operational noise - on the other hand, Bel-Ray can make the trans very quiet. And, there are many makers of trans fluid out there.
    I have to confess I use HDs to keep it simple. But, I think other here can give you advise on alternates.
    Finally, if your in doubt, being a new trike take it to your dealer and ask - never hurts and its probably a quick trip.
    Besides, if something does develop (I hope not), then your on record for reporting it.
    Springman
    If it don't clunk it ani't a Harley..... That said if it will make you feel better let your dealer check it out... Cant hurt. I had a Honda 929 and when i dropped it into first you would have though i hit the case's with a hammer, My Victory also shifts loud ,And thats a sore point on most Victory Forums also...
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Worse than the audible metal to metal noise is not hearing anything. Yesterday my shifter became disengaged, so I was stuck in first gear. I got off of the road, managed to get it to catch, tightened it up and rode home. It didn't fall off, like the one on my 2003 Road King, so at least I didn't have to go looking for it.
    The bad part is I now have my toe shifter 1/4 inch from the floorboard and I have to do a high step to use the heel shifter. I am not brave enough to pull it off and start over, so off to the dealer I will go.
    300+ Posts J.T.M.'s Avatar
    Jan 2015
    Buffalo, Ky, USA
    As I have told others, you bought a Harley, Harley make all kinds of noises. That is the reason we run loud exhaust, it helps to cover up the clatters, raddles, clunks, ticks. Just make sure the dealer makes a note about all the noises when they service it then you are covered if something goes wrong. After a while and some miles you will learn to enjoy the HARLEY noises.
    Every day is a good day.
    US NAVY SEABEES 1971-1975
    2010 Ultra Classic/ Hannigan Transformer
    1987 Honda Rebel 450
    Sold all the others
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Put real gear oil in the transmission. I use Bel-Ray 85W-140 Hypoid gear oil. (28 ounces for wet change) There are many other Harley transmission specific oil brands available to use.
    Bob
    Aug 2016
    houston, texas, usa
    HaHa... thanks guys. Just wanted some assurance that clanking noise was supposed to be there!
    I have a knife addiction..
    Gone2Three's Avatar
    Aug 2016
    Pflugerville, Tx
    Yep, like he said!
    4250+ Posts
    Feb 2015
    San Antonio
    I read a suggestion someplace on this site to hold your clutch in for about 10 seconds before shifting when you have been parked for a while.
    Works for me. I also tell myself that I need to find that post and thank the poster, but I can't find it.
    The M8 clicks in gear the change is nice
    I run belray in the tranny and formula plus in the primary
    Just a late suggestion on my part...But;
    The OP might be changing gears a tad too low in the RPM range, Or slow shifting........ie; Clutching then shifting , Instead of doing it simultaneously...
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Clunking is normal, it can be reduced by having a properly adjusted clutch, and by using Redline Heavy Shockproof oil in the tranny. I also found that by running Syn3 in the primary there is less of a clunk, and smoother clutch engagement.
    But if it is a metal to metal sound, I would check the fluid level in the transmission. Many years ago I got my bike back from the dealer with NO fluid in the transmission...they forgot to put it in!
    www.DKCustom.com
    60+ Posts
    Jun 2015
    Tickfaw, LA, United States
    Default First time Harley owners.
    I rode Suzukis before I bought my FW. When I shifted the FW, I thought something was broken. My Suzi 1100 barely made a sound when shifting. After owning the Harley for a year and a half, I've concluded Harley needs to give first time owners two lists: The first list is titled "They All Do That" and the second is "There's a Trick to It".
    450+ Posts Bill G's Avatar
    Mar 2015
    Bakersfield California USA
    As said by others a clunk in normal. My 2015 Freewheeler on the other hand shifts very smooth with a minimal HD clunk. I believe it's because I run Spectro Platnium 75/140 six speed specific synthetic tranny fluid. This prouduct is recommend by Baker racing transmissions and is rather pricey (around $20.00 per quart). I run the recommended amount of Formula plus in the primary. (My Freewheeler was 6 oz low in the primary from the factory new. I always double checked everything just as soon as I got home when new). The Freewheeler has a hydraulic clucth no manuel adjustment. I also run this same set up on my 2016 Dyna Street Bob with the same smooth results with minimal HD clunk.( Also on the Dyna the clutch is adjusted to spec).
    I would never run HD Syn 3 in the tranny no matter what anyone tells you. It's ok in the primary but HD Formula Plus is better and is also a much better product on the newer style Harley compensater. (HD Formula Plus is one of the better primary fluids out there).
    A good 75/90 or 75/140 gear oil is good in the tranny also the HD Formula Plus is a pretty good tranny fluid. Just don't put HD Syn 3 in the tranny I don't care if this goes against the grain of some folks beliefs. I have seen to many issues over time with HD tranny because of HD Syn 3 being used in the tranny. (Why Harley recommends this can be done I don't know and is beyond me).
    Ride Safe,
    Bill G
    Through Jesus Christ, I a sinner am saved. Not by my doing but through his doing by his sacrifice and Blood Shed on the Cross. His gift to all mankind that will only believe and accept him by Faith. Through his Death and Resurrection I am Saved by Grace and someday I will be with our Lord in Heaven forever.
    Jul 2017
    Pompano Beach, FL, USA
    Default trouble upshifting
    I hadn't ridden in over fifty years but got the urge again and bought a 1992 Goldwing 1500 trike. Everything has been going fine until to day. Put it in reverse and pulled out of the garage. Got on the road and had no trouble shifting into first and second. Have a heel toe shifter and when I tried to upshift nothing happened. Couldn't feel any engagement.
    Downshifting and shifting to first, second and reverse, no problem. Above second gear, nothing. No tension in shifter. Just feels like it isn't doing anything.
    Any suggestions?
    The hydaulic clutch can be made adjustable
    I have it figured out if anyone wants to know
    IMO the MOCO did a half DONKEY on this 1
    The clutch should have been made adjustable @ the designing stage BUT the bean counters saw a cash cow for an upgrade JMO
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    The hydraulic clutch can be made adjustable
    Curoius minds want to know. Please tell.
    Nuc
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    At my 1,000 service in CA, the dealer put in HD Syn 3 & my trip back to St. Louis it ran cooler & shifted better. At 3,750 miles, I changed to Lucas 20W-50 full synthetic high performance motorcycle oil in all 3 holes & the improvement in shifting was immediate. Also, the engine operating temperatures dropped 20 degrees.
    I am glad that I made the switch & I like having the same oil everywhere. I am using the HD 5 micron oil filter. Looking at the specs, it's 1 of the better ones out there.
    Just my opinions.
  19. #19
    Sep 2016
    Springfield, Mass. USA
    Sound like were ALL agreeing that synthetic oil, makes the best choice to use in our motorcycles, instead of the regular brand oil?? Am I correct in "thinking this??
  20. #20
    Jul 2014
    S.E. PA, USA
    Quote Originally Posted by Rudy K. View Post
    Any suggestions?
    Wrong forum for Goldwing question.
  1. Down Shifting for a slow-down
    By mgwtrike in forum Honda Trikes
    Last Post: 03-06-2016, 07:11 PM
  2. Shifting and NOT shifting
    By Zorro in forum Honda Trikes
    Last Post: 07-25-2014, 10:02 PM
  3. triglide shifting
    By dollysgizmo in forum Harley Tri Glide
    Last Post: 09-02-2013, 05:50 PM
  4. Shifting CLUNK!
    By jimdog1356 in forum Harley Trike Conversions
    Last Post: 04-17-2012, 08:17 AM
  5. Hard Shifting
    By Mcwac in forum Harley Trike Conversions
    Last Post: 08-23-2011, 08:57 AM
