Results 1 to 20 of 27
Thread: Enclosed Trailer Trike Tiedown Ideas
    2750+ Posts Rosy's Avatar
    Jan 2012
    Dover, NH USA
    Default Enclosed Trailer Trike Tiedown Ideas
    OK, need input on how everyone ties down their trikes in an enclosed trailer.
    I do my Hannigan Wing with straps from the "crash" bars to the sides and the trailer hitch to the sides. Strap the front tire down on the chock.
    I have been thinking of putting e-track under the tires and tie the tires down to the e-track. This should keep the trike down on the floor and shouldn't go from side to side. What do you think?
    Thanks for your input.
    Rosy
    350+ Posts Livin2Ride's Avatar
    Nov 2011
    Leasburg
    Default Re: Enclosed Trailer Trike Tiedown Ideas
    I would keep doing as you have been. That is the basic way I tie down my HD when I have to trailer it and I've never had it move. The E-Track under the rear tires and strapped would be ok, but I would still have to cross tie off the rear frame just to make sure it didn't move off the E-Track. MHO only.
    Sam - Mid MO
    2015 Triglide.
    Jan 2012
    Dover, NH USA
    I just thought when I see a tow truck hauling cars, they have the tire hold down. But, the only problem with my Hannigan would be, can I get the tire hold down over the top of the tire, because the fender is so close to the tire.
    Thanks.
    Rosy
    Jun 2010
    Indianapolis, In.
    FYI, The tip over bars(they are not crash bars!)on a Wing are NOT designed to be pulled down on! That is the worst place to use tie-downs. I learned this the hard way!!!!
    It. is best to use soft ties around the lower triple tree, ratchets attached to the soft ties and attached to D-rings or E-trak that pulls forward and down. DO NOT colapse the forks more than a couple inches. This secures the front wheel into the wheel chock and holds the front properly.
    The trailer hitch seems a logical place to secure the rear.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Jan 2012
    Dover, NH USA
    Looking at the internet for hauling cars, they have a rubber block which fits on the strap going over the tire. You need three of these block to hold the tire securely. The block have cleats which fit into the tire's rain grooves so they don't slip off the tire. You can buy the complete set up with blocks, strap, and ratchet for about $30. They attach to you e-track, secured to the floor of the trailer.
    Again, need to see if I can get the strap over the rear tires on my Hannigan kit.
    If I can, it would not put any pressure on the suspension, front or rear.
    I heard, one problem tying the hold down strap to your handlebars is, you put pressure on your fork seals and could cause the seal to blow.
    Anybody out in TT Land have had this happen?
    Rosy
    Jan 2012
    Dover, NH USA
    Here is a picture.
    Rosy
    Nov 2011
    Leasburg
    Looks like a good product and a good idea, but like you I'm not sure about getting it over the rear tires due to clearance, especially when you're working in a tight environment like an enclosed trailer.
    Sam - Mid MO
    2015 Triglide.
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by Rosy View Post
    Rosy
    That is exactly the reason I wrote not to compress the front forks more that a couple inches! Fully compressed can cause fork seals to "pop"!
    Also, the handle bars of a newer Wing should not be used as a tie down location.
    Patriot Guard
    Was a LEO
    Jan 2012
    Dover, NH USA
    My trailer is 12X7, so there is room to play with. You are correct, most buy a trailer just wide enough to put the trike in, therefore they suffer from lack of room.
    My friend has a Cheetah, which is great to tie down in this manner because the rear wheels are expose with a small fender.
    Rosy
    800+ Posts
    Aug 2011
    Evansville, IN
    Rosy, this is the type of tie-downs I like to use, I think they would be easy for you to install.
    http://www.etrailer.com/Trailer-Carg...son/77314.html
    Jan 2012
    Dover, NH USA
    DTR 11TG,
    I looked at those but as you noticed in the photo of my trike, the ratchet would not fit under the fender, not enough space between the tire and fender.
    With the other tie down (see attached photo), it brings the straps closer to the bottom of the tire, then the ratchet is further down the e-track.
    I believe it is going to be one of those, spend some money to see if it works, then make a decision for yeah or nay!
    Do you use the over the tire tie down on your trailer?
    Thank you very much for the info!
    Rosy
    800+ Posts
    Aug 2011
    Evansville, IN
    I should have looked closer at your pic, I didn't notice that it was using a roller idler. I use the same thing on mine, it allows the ratchet to be in a more workable spot, I have my ratchet to the rear.
    After looking at your system closer, I like it. I think, rubber blocks or not, with the lower trike tire pressure it would allow the ratchet to pull the center of the tire down & that strap won't go anywhere. Because of the tight tire to fender clearance I don't really like what I'm using, I might try to make my own with all the straps & ratchets I have sitting around. Thanks for the idea
    Jan 2012
    Dover, NH USA
    You know, you can buy the rain groove block separate to fit your strap. I would think you are correct, but just for peace of mind, I would use one block on the top of the tire.
    Let me know if you want the place you can buy the block.
    I am a little leary about hauling my trike. Went to NC to pick it up, on the way home doing about 65mph a crazy person cut in front of my truck..He was about 6" from my front bumper..I cut the steering wheel, hard right..Looked out the passenger window and there was the trailer ready to jackknife, cut the steering the other way, after my knees stop shaking and pulled over, I checked the trike..I expect to see her on her side or against the wall..nope all was right..I had tied her down very well..So, I am always looking for a better and easier way to tie her down!
    Hope you had a Wonderful Christmas!
    Rosy
    100+ Posts
    Jul 2010
    Orange city Fl
    HI Rosy I do it the same way in my enclosed trailer , off the front engine guard and the trailer hitch , never moved on many trips back n forth to Florida , Happy New Year to you and your wife ~~
    Jan 2012
    Dover, NH USA
    Thank you very much, and same to you and your Family!
    How many straps do you use? I use 5 to tie her down?
    If I can use the tire strap, then it would reduce to 3. One on each tire, and one at the chock.
    The other thing I was looking at was to reduce any forces to the suspension while tied down. Some people use the handlebars for a tie down and I heard some fork seals being blown.
    I could be all wet on the suspension thing, but maybe it would give me peace of mind.
    Any thoughts on this?
    Rosy
    100+ Posts
    Jul 2010
    Orange city Fl
    Rosy I only use 4 straps , 2 up front , 2 on the rear trailer hitch , that way if any hick ups , the rear suspension will only react on the coil over springs as needed up and down , and the front will react on the fork springs as needed , never had any problems . J.M.O
    Jan 2012
    Dover, NH USA
    Ultra fred, I will be going down to Florida with almost the same set up you have. You are correct, the trike will not move. So, I should not worry, correct.
    We just have to make sure we stay away from the crazy cagers that are on the road. Just like the one, in the thread above, when I went to pick up my trike in NC!
    Rosy
    100+ Posts
    Jul 2010
    Orange city Fl
    Hi Rosy , you will be fine , all I do when I travel back n forth to Maine is everytime I stop for gas or food etc I always double check the straps and safety chains , plus it gets you to stretch your legs out a little more , so you can be more alert of those crazy cagers !!!!! safe travels my friend .
  19. #19
    50+ Posts Condor Spirit's Avatar
    Jun 2014
    Keene NH USA
    CAUTION! My brother in law always used straps on the engine guard of his Harley. But one time the factory bracket where it attached to the frame broke. The engine guard put a huge dent in his front fender. One of the brothers who is a welder made a much stronger bracket so that won't happen again.
    In Youth you Learn. In Age you Understand. Now if I could just remember what I learned.:xzqxz:
  20. #20
    Jan 2012
    Dover, NH USA
    Thanks Shell, WOW, something to think about.
    Maybe that is another reason to use the tire tie downs, if possible.
    Rosy
  1. Enclosed Trailer
    By Marv1 in forum Harley Trike Conversions
    Last Post: 09-04-2015, 08:46 PM
  2. Considering getting an enclosed trailer
    By rmrc51 in forum Honda Trikes
    Last Post: 10-02-2011, 12:37 PM
