Likes Likes:  8
Thanks Thanks:  1
Results 1 to 20 of 20
Thread: Flasher
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Default Flasher
    Does anyone know where the turn signal flasher is. I can hear it, but I can't locate it. I am converting to LED's and the turn signals flash fast, so I need to replace it. Thx Rick
    Stallion #378
    Suzuki Burgman 650
    300+ Posts
    Signal Mountain Tn
    Quote Originally Posted by rocket1lf View Post
    Look around your oil dipstick. It is somewhere in that area, just have to poke around. If you can find a flasher that will work with led's that will be great. I installed in line resistors on mine, worked fine.
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    The flasher is located on the top right side and should be seen attached to the support bar. The flasher is a Ford flasher and you can get it at any part store. The flasher on my 08 is on the top right and you can see it as soon as you open the hood. The flasher is attached to the support bar and can be changed without any problem.
    Dec 2013
    Hot Arizona, USA
    Quote Originally Posted by Ed Hobgood View Post
    Thanks Ed. Do you know if it's a standard Ford truck 5 pin relay? Rick
    Stallion #378
    Suzuki Burgman 650
    Jan 2011
    Dexter, MO, USA
    I'll check in the morning but I think it was a standard Ford turn signal relay.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Just bring it to any auto parts store and they will match it up. They run about $15/16 bucks. I've had 4 replaced now !! Probably because I've been caught in a lot of rain on my trips.
    Tom
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    I believe led replacement flashers are available Your parts guy should know. And yes, definitely bring in your old one to match the pin print.
    Dec 2013
    Hot Arizona, USA
    I got a Novita EP27 from Autozone for $15.99. Works great. The flasher was just where you said it was. One problem that I did have, that drove me nuts, was the right side front bulb wouldn't flash with the LED, but would work with the incandescent bulb. It took a while trying to find the problem until it hit me that the LED is polarity sensitive. I checked the voltage at the socket and sure enough, it was reversed. The - was on the pin and the + was on the side. It was a pain trying to get enough wire and cross them, but I finally got it done. Now both fronts work. Tomorrow I'll just have to see if the rear lights were wired wrong also. I hope not. Rick
    Stallion #378
    Suzuki Burgman 650
    Rick what LED bulbs did you use in the mirrors? Are they brighter then the incandescent bulbs? Same info on the rear when you get r don
    Ted
    Dec 2013
    Hot Arizona, USA
    Ted
    Ted,
    I used these for the running/brake lights and they seem to be a bit brighter. I like the flashing for attention. I purchased two sets.
    http://www.ebay.com/itm/2X-Flashing-...5SKlAC&vxp=mtr
    I used these for the turn signals and they are pretty close to the same brightness. I polished the front reflectors to shine them up a bit. I did not try them in the rear yet, so I don't know if the wiring back there is correct. This set comes with four bulbs.
    http://www.ebay.com/itm/4X-1156-High...JWMWCN&vxp=mtr
    Rick
    Stallion #378
    Suzuki Burgman 650
    Dec 2013
    Hot Arizona, USA
    They're all working. The only difference I see is the amber LED bulbs in the back are not as yellow as the amber colored incandescent ones. I don't know of any LED's that are. I can live with it. I was lucky and the rear wiring was correct. Rick
    Stallion #378
    Suzuki Burgman 650
    Glad that worked out for you. I may also give them a try. Thanks for the post.
    Ted
    250+ Posts Dean H's Avatar
    Oct 2010
    Tampa, FL
    Rick, just a note, I thought that the little amber light in the rear tail light assembly was pretty 'funky' looking, so I removed that bulb and had the lights rewired so that the entire back tail lights are not only the brake light but also the turn signal light. The entire light flashes for the turning signal.
    Dean - 480.734.7161
    Tampa, FL
    dean.hauser3@gmail.com
    '09 Stallion #643
    200+ Posts
    Feb 2017
    Arp, TX - USA
    A bit late, but maybe it'll help someone else. No Stallions in our facility at the moment, so I had to get creative and robbed this image online. The flasher relay is a standard Ford unit (only blue relay under the hood). I edited this image to show the approximate location for future reference. Hope it helps.
    Quote Originally Posted by trike tech View Post
    Thanks again Richard its good to have you on board
    Hi I found a set of LED replacement tail light units for the Stallion.
    http://www.ebay.com/itm/351998588536...%3AMEBIDX%3AIT
    I installed them slight mod but look great
    Dec 2013
    Hot Arizona, USA
    Looks great. You must of done a lot of work getting the housings apart. Rick
    Stallion #378
    Suzuki Burgman 650
    No they come as a unit. Look at the listing. The only mod is to cut off some of the flange on the top inside area that is easily done by following what you see on the old assembly. A filler piece is riveted on that you transfer to the new assembly and then mount the assembly in the opening. Just a step above plug and play. Wife loves them.
  19. #19
    300+ Posts
    Signal Mountain Tn
    Ted, did you have to install a resistor in line?? Thanks.
  20. #20
    Quote Originally Posted by trikervet View Post
    It came with 3 modules for each assembly but still the turn signals flash fast. When I get a chance Im going to try the flasher listed at the start of this thread, but that will be down the road a time.
  1. freewheeler and custom dynamics flasher
    By GLT in forum General Discussion
    Last Post: 04-20-2016, 09:52 AM
  2. Brake Light Flasher
    By psychogramps in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-19-2016, 04:21 PM
  3. motor trike flasher unit
    By WVFoxtrotter in forum Honda Trikes
    Last Post: 10-24-2013, 01:44 PM
  4. Flasher ??
    By Rsw in forum VW Powered Trikes
    Last Post: 07-11-2012, 03:17 PM
