Likes Likes:  2
Results 1 to 9 of 9
Thread: Best Front Tire
    10+ Posts 3puttbob's Avatar
    Aug 2017
    Acton,ca.,usa
    Default Best Front Tire
    Hi All
    Probably beating this subject to death but, I need to replace the front tire on my '01 GL1800. Has a Champion conversion. Been hearing about the AVon Cobra Chrome Trike tire. My 130/70r-18 only shows this tire available in the V speed rating. I also hear the H rating is better for mileage but, The H doesn't seem to be available in this size. I'm looking for responces on the V or, alternate suggestions. I'll also need to replace the rears soon. Anybody find soft ride rear tires?
    Sep 2016
    Springfield, Mass. USA
    I have the Avon "trike tire" on my Roadsmith..................
    Three season's and I have been a happy boy
    1/6/22
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    Quote Originally Posted by 3puttbob View Post
    Hi All
    You mention that you want soft ride rear tires. What psi are you running in your rear tires? That will have a big impact on how rough or soft your ride is.
    Sep 2016
    Quote Originally Posted by pwhoever View Post
    Thanks to the recommendations on this board, I started to ride my rear tires at 22 lbs, and found that it did totally help with my smoothness
    1/7/22
    550+ Posts Mick's Avatar
    Feb 2008
    Midwest
    Ive got an Avon trike on mine 17,000 and it looks like I can get at least a few more thousand out of her. I love the handling and the ride.
    60+ Posts
    Oct 2012
    Cold Lake Alberta Canada
    Ive been running the Avon trike tire on the front for 3 or 4 years now. They last long here cause of our long winters with no riding! I like mine . dosesn't seem to want to follow grooves in the road as bad as the orginals on my wing. ...Ken
    300+ Posts brianl's Avatar
    May 2013
    leominster, ma. USA
    Avon trike tire for sure. I replaced mine this year and couldn’t find the actual trike tire because of supply problems and used a regular Avon tire with the same dimensions. Definitely can’t tell the difference as far as ride. Not sure about the longevity yet but the ride is awesome.
    80+ Posts
    Feb 2014
    Toledo,Ohio-USA
    Brethren,
    I Had A Regular Avon Front Tire On My Trike, Lasted About 3 Yrs Then Developed A Slow Leak Around The Bead, Switched To The Avon Trike Master & No Problems Since.
    Aug 2017
    Acton,ca.,usa
    Well, y'all talked me into it. Got the Avon Trike tire. I like it. Thanks
  1. Best 19" Front Tire
    By Strohkr in forum Harley Tri Glide
    Last Post: 11-12-2021, 11:12 AM
  2. Valkryie Front Tire - Whats Best?
    By ruezier in forum Honda Trikes
    Last Post: 05-03-2015, 08:24 PM
  3. tire size for rear tire on front? 2007 goldwing trike
  4. Best 16" Front Tire?
    By gonzo in forum Tires, Wheels, Brakes, Front End
    Last Post: 12-18-2013, 12:26 AM
  5. Best route from 81s to best western
    By trikermary in forum Other Rallies & Rides
    Last Post: 05-17-2012, 10:08 AM
Tags for this Thread
