Likes Likes:  4
Results 1 to 12 of 12
Thread: Gas in the auxiliary tank is not moving
    Apr 2018
    Palm Coast, Fl, USA
    Default Gas in the auxiliary tank is not moving
    Gas in the auxiliary tank is not moving to the main tank when I flip the switch. I can hear the motor working. I'm also looking for a replacement cap for a 2005 Goldwing Trike.
  2. Roadsmith banner
  3. #2
    Welcome to Trike -Talk....Ann......I can't help , But in sure someone will chime in with the help you need.....
    Again Welcome...
  4. #3
    Mar 2011
    mountain home,ar. USA
    Do you have two red lights lit indicating there is fuel in the tank?
    Possible that fuel filter is plugged? (It's inline right before the pump)
    If you can hear the pump running then these are the only two reasons for no fuel moving that I can think unless the pump itself has gone bad.
    Good luck.
  5. #4
    30+ Posts T-Cat's Avatar
    Feb 2018
    MIDLOTHIAN, TX 76065
    Quote Originally Posted by ChefNYC View Post
    Check on Ebay for replacement cap, saw a few available on there tonight.
    Retired & Time to Ride
    Tom H - aka T-Cat
    2002 Silver GL1800A
    2003 Silver Bushtec Quantum GL trailer
    2007 Black Nomad 1600 - Totaled May 2018
  6. #5
    Welcome aboard ANN you might just want to call Road Smith and get their opinion.
    Apr 2018
    Palm Coast, Fl, USA
    Default Gas not moving from rear tank
    Thanks for the responses. I did indeed speak to Roadsmith. Their response was similar to what’s been suggested on the site. They no longer sell the replacement gas caps. I started looking on eBay. They suggested I try some Marine shops since the rear tank on the older trikes was styled after a marine engine. I have a mechanic investigating all of the suggestions. Thanks again.
    300+ Posts
    Jun 2014
    S.E. Ohio,Close to the triple nickel
    One thing to keep in mind is the fuel pump is very slow to transfer fuel. It takes 20 minutes or so to get the fuel transferred to the main tank. When I first used mine I thought it was not working because It was so slow.
    Sep 2012
    Lakeland, FL
    I had a fuel pump go down, a 2012 RS conversion. RS Daytona shop replaced under warranty. Yes, it can happen. If you can hear the pump and there's fuel in the aux tank, then what's left but the pump, or a plugged line?
  10. Roadsmith banner
  11. #9
    Apr 2018
    Palm Coast, Fl, USA
    Default Gas not moving from auxiliary tank
    I spoke to Roadsmith and Mike gave me the following application for the gas filter:
    1968 Ford Fairland 302 V8 2 barrel carburetor fuel filter.
    Thanks to everyone on the site for your responses. I wanted to share with you my final results. The filter costs $2.40.
  12. #10
    Sep 2012
    Lakeland, FL
    Thanks for sharing, please let us know how difficult it is to change the fuel filter, and if that fixed your problem.
  13. #11
    750+ Posts
    May 2011
    peru,in,usa
    take the gas cap off of the rear tank and see if that works.
    use shop air to try and blow the vent line clear.
    use a test light and see if the xfer valve is getting power.
    see if the rear pump is actually putting out fuel
  14. #12
    Sep 2012
    Lakeland, FL
    For us Road Smithers, walk us through the filter replacement.
  1. Noise from gas tank and lots of air pressure
    By LinDIVA in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-30-2018, 06:55 PM
  2. Bigger gas tank
    By Grumpy7760 in forum Harley Tri Glide
    Last Post: 03-04-2018, 08:41 PM
  3. New auxiliary tank system
    By Carbon_One in forum Yamaha Trikes
    Last Post: 08-29-2013, 02:52 PM
  4. Leaky auxiliary gas tank :(
    By MarciaG in forum Honda Trikes
    Last Post: 05-26-2012, 08:24 AM
  5. Auxiliary Gas Tank
    By philmcc in forum General Discussion
    Last Post: 07-08-2011, 04:03 PM
