Has anyone tried to install the Kuryakyn Heel-Toe Shift Part#4039 on their Trike (CSC with ground effects). I looked at the part and I don't see why it would not work:gah:. The installer told me that I could not install any Heel-Toe Shifter as it would not clear the ground effects, but its like five inches from the foot peg to the grouund effects and I figured when you shift the shifter it is only moving 1 to 2 inches max:Shrug:.It will still allow the Ground effect to be bolted to the foot peg as you use your original foot peg, all you are doing is moving it out approx. a inch to add in the new mount with the shifter installed on it. Any help would be greatly appreciated.
