LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  5
Thanks Thanks:  1
Results 1 to 13 of 13
Thread: Exhaust removal
    Dec 2018
    St. Charles,I'll,usa
    Default Exhaust removal
    Anyone know best way way to remove slip on mufflers?Also anyone put tank lifts on with stock handle bars and how high?2017 tri glide
    Give the muffler joints a shot or 2 of WD40 or P B Blaster
    After removing the clamps, twist the mufflers and pull , they should slide off pretty easy
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Yep, P B Blaster or WD40...I've been using P B more lately, seems to work a bit better.
    Remember to remove the two bolts in the hangers at the rear of the slip-ons.
    A rubber mallet can help if they are too tight for the twist & pull.
    www.DKCustom.com
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I've used a strap wrench successfully to twist the muffler and help break it loose and pull it off.
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by ultrafxr View Post
    Never thought of that...that is a really good idea!!!
    www.DKCustom.com
    Oct 2010
    USA
    As suggested Lube,remove the rear bolts side to side movement up and down slide off.
    Make sure muffler clamps are loose enough too to slide off or just slide them to the header pipe.
    60+ Posts
    Mar 2010
    Western NY
    Default Ditto
    +1 on the strap wrench
    '15 TG Red Sunglo/Cayenne, Chrome Forks & Wheels, LED's, TGlide Stuff Lift.
    Patriot Guard
    Previous HD's: '13 TriGlide, '13 Fat Bob, '05 Super Glide, '00 Heritage, '96 Heritage, '94 FLHTC, '77 FXR
    I use baby shampoo and water to get them loose ... also ... if you use an exhaust pipe expander (1.75" like $3-4 at harbor freight) to expand the muffler inlet a little before installing (don't go deeper than the split), they will slide right on and even come off easier next time. They will seal fine after expanding.
    If your issue is the hanger bolts, get a ratcheting box end ... the thinner the better .. I think they are 1/2"
    Dec 2013
    Clarion PA USA
    The flex head ratchets I use the gear type not like the old 12 pt. the new sears spline type socket
  11. #10
    anti seize paste on the install helps on the next removal.
  12. #11
    Dec 2013
    Clarion PA USA
    Kevin it sure is slick with the strap wrench and flex head ratchet box end spline type sears. Fred
  13. #12
    Apr 2016
    columbia, ct usa
    Quote Originally Posted by Bruce51 View Post
    Yes, I've installed the "tank lift" on my 2015 Triglide. Besides looking better, (you have more of a sense of sitting in the trike rather than on), it makes cleaning the front cylinder much easier to clean. I really can't comment on the "cooling" factor, but it makes sense that if exposed to more airflow, the cylinder will cool easier, which was primarily why I installed it. Regarding the fuel capacity loss, I suspect, due to the angle, I lost about a pint of fuel. In short, I think it's a great addition and would recommend doing it.
  14. #13
    Dec 2013
    Clarion PA USA
    I did a two inch lift on our 09' with stock bars no problem Name:  DSC01216.JPG
Size:  144.0 KBName:  DSC01218.JPG
    Then in the winter of 14 I Changed the bars to Khrome Werks 2+2 Wide Sweepers Name:  DSC01012.JPG
Size:  161.0 KBName:  DSC01020.JPG
Size:  160.8 KBName:  DSC01022.JPG
    Great changes resolved my neck and back pain so much more comfortable than with OEM bars. Travel safe Fred
  1. Drive Shaft with Front Clamping Yoke Removal
    By Trike Dude in forum General Discussion
    Last Post: 09-06-2020, 09:06 PM
  2. Exhaust removal
    By boeing247 in forum Harley Tri Glide
    Last Post: 12-31-2018, 09:27 AM
  3. Tri-Glide Oil Filter Removal
    By motorman7 in forum Harley Tri Glide
    Last Post: 08-31-2009, 10:55 PM
  4. Windshield removal
    By JimEd in forum General Discussion
    Last Post: 05-24-2009, 02:39 PM
  5. Chrome Rotor cover and Ring of Fire Removal
    By firebreath in forum Honda Trikes
    Last Post: 05-19-2009, 09:18 PM
