LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  2
Results 1 to 8 of 8
Thread: Hardtail on V8 trike. Is that crazy?
    Aug 2017
    Table Rock, NE, USA
    Cool Hardtail on V8 trike. Is that crazy?
    I have gathered up a load of major components for my trike. I am going to fabricate a fairly short and fairly narrow machine.
    I want to keep it pretty short and not use a driveshaft or CV joint.
    My plan is to use double #100 roller chain & sprockets as a coupler from the trans output to the 3rd member input.
    I have two rear axle already.
    1. 2005 Ford T-Bird IRS, brand new and complete. It's 66" wide. Needs narrowed.
    2. 1976 Ford Maverick 8" ring, used, needs freshened up. It's 56" wide. PERFECT WIDTH!
    I would have to narrow up the T-Bird IRS in order to use it. But I'd make it a lot simpler to use the 56" Maverick and no suspension.
    I wondered if it is possible to have a driveable trike with a solid (unsprung) rear axle.
    Much obliged,
    Mustang Gregg
    Welcome to Trike-Talk, Gregg.....Should be a very interesting build your doing....
    Aug 2017
    Table Rock, NE, USA
    Default New guy here.
    Thanky, Rhino 2.
    This forum looks like a great one to get trike info.
    I worked as a machinist and got into aircraft maintenance, so I'm not afraid to tackle a trike myself (with some helpful advice). LOL
    Much obliged,Mustang
    welcome aboard. I would think you would want some suspension. With the 2 wheels in back and acting together because no suspension it would be really a rough ride.
    Apr 2015
    Batesville, AR. 72501
    Welcome to the forum.
    I have seen "sprung" setups that mount the rear end rigidly to a subframe that the motor is mounted to and the whole assembly is pivoted at the front of the engine. The subframe has springs at the rear end. This way you wont need a driveshaft and will have a little less unsprung weight and a little softer ride.
    Research about sprung vs. unsprung weight and how it affects handling and you will probably want to do the extra work to reduce your unsprung weight to save your kidneys.
    I rode a rigid Harley in my younger years and hitting the brakes on the washboard pavement at a red light could be quite exciting. When you put on the brake and hit the first bump, the rear tire would come off the ground and the brakes would lock up. Got exciting when the rear tire came back to the ground and wanted to skid rather than turn.
    Spend some time in the old forum posts and you'll get a lot of good ideas. Check out the Tech,Tech... sticky thread in VW trikes forum for a lot of good general information.
    Most important......post pictures of your build. We like pictures!
    Aug 2017
    Table Rock, NE, USA
    Default Interesting design!!!
    VWBug72501:
    I was pondering good springs under the seat and using some really good foam in the upholstery, but your idea sounds cool.
    So I am interested in the whole power unit pivoting like you described.
    That would definitely keep the wheelbase about 12" shorter.
    I would sure like to see one under construction or in use.
    Do you have any idea where I can find any photos of such a design?
    Thanking you!
    Mustang
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Mustang Gregg View Post
    Much obliged,
    Mustang Gregg
    personally i would not build a trike with no suspension "again"... wasnt horrible... but i was about 20 then and didnt know better... i did certainly bounce a lot as mentioned...
    to each his own but i have used t bird, mazda rx7, and subaru rears... all i rs... which i left pretty much stock width... dont think i would go much narrower....as it is i have been on 2 wheels a couple times,,, but as i said to each his own
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    My first trike (back in the 80s/90s) was a hard tail. The frame was bolted straight to the rear axle
    http://3fowlers.com/firsttrike.html
    Thank you
    Bob
  1. Crazy looking Trike
    By Zammy in forum General Discussion
    Last Post: 05-03-2016, 09:17 PM
  2. Am i crazy or what
    By chris vickers in forum General Discussion
    Last Post: 08-27-2015, 08:47 PM
  3. V8 hardtail?
    By VaBob in forum Home Built Trikes
    Last Post: 05-01-2014, 05:00 PM
  4. Thinking of building a trike out of a daytec hardtail frame
    By Tim Walding in forum New Member Introductions
    Last Post: 01-05-2014, 06:12 PM
  5. SBC Hardtail a slow build
    By sleepyonthree in forum Home Built Trikes
    Last Post: 11-03-2010, 06:41 PM
