Likes Likes:  6
Thanks Thanks:  3
Results 1 to 20 of 37
Thread: Tri Glide Primary Oil
    250+ Posts onahog's Avatar
    Aug 2012
    Portage La prairie,manitoba,canada
    Default Tri Glide Primary Oil
    Just throwin this out there people..Lets Discuss!!
    What Oil do You use in your Tri Glide Primary?
    Why?
    How Much?
    How often R & R?
    ATF? Dennis?
    Please Explain, as we all value your choice!
    750+ Posts
    May 2011
    peru,in,usa
    Default Re: Tri Glide Primary Oil
    manual says 38oz's. thru the derby cover torque the torex screws 84 to 108 INCH pounds and 45 oz's if you remove the primary covertorque these screws 108 to 120 INCH Pounds. drain plug 14 to 21 ft . pounds.
    i use NAPA #41 "o" RING STOCK # 35755b 9/16X7/17X1/16 AND tfe paste (pipe sealant) on the drain plug threads.
    don't overdoo the torque. just tight & it won't leak. you can get a 1/4" drive "click" torque wrench on the net for about $40.00 delivered.
    750+ Posts Bruce's Avatar
    Sep 2010
    NY, USA
    always used HD primary oil in all my bikes and the trike, change it every time I change the oil (3000 miles )
    1000+ Posts
    Mar 2011
    Muncie, Indiana
    Quote Originally Posted by onahog View Post
    Why?
    How Much?
    How often R & R?
    ATF? Dennis?
    I just do allot of reading on allot of different things. The search engines just takes one to allot of stuff out there and some not true too I guess.
    Looking into clutch stuff , I went through tech stuff on racing clutch setups as well as stock setups. Barnet and Rivera both recommended ATF in HD primaries. One specifically recommended not to use +1.
    Everyone has reasons why they use any fluid in the three holes of the TG. Whatever you use, fluids we have today are probably not close to wore out when we change them. I change crank case and primary around 5000 or so. I have taken several trips which were over 7000 and changed when I got home. Tranny I change at 10,000.
    Guess I would change it at end of season if I did not put that many miles on it. I do only use the Red line stuff in there.
    Opinions are like noses, we all have one, I just went to ATF in primary because when I ask my independent wrench what he used, he smiled and said Valvoline ATF, had been for years. His point was it is used in transfer cases with clutch packs and chains and such as well as a detergent in it. It is also recommended by the clutch companies.
    While on clutches, those of you who have had dyno runs, look to see if it shows any clutch slippage anywhere. It should show you even if you cannot feel it yourself.
    From charts of runs I have seen, most folks who do even slight build on motors without updating clutch packs are leaving allot of the gains on the floor.
    Just rambling again, food for thought and cussing and discussing.
    barnett carbon fiber clutch they say ATF type "F" that's what i use
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Food for thought to those who have Screamin Eagle compensators or those who have 09 to present Triglides. The compensator suffers from lubrication issues, it doesn't get enough which leads to a shorter life. When you shut your engine off and hear a bang and sometimes a clang, its the compensator which has failed. There are some folks on their 2nd or 3rd compensator due to its early demise. What has show to help it live a little longer life is Harley Davidson Formula+, ATF shortens the life.
    I can understand why some clutch manufacturers recommend ATF because the frictions and steels are very much like those in an automotive transmission. What they fail to recognize is the shear in which the compensator ramps are under, this leads to high wear in the ramps to the point of ridges developing.
    Just my 2 cents.
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    I use Amsoil in the motor and trans, but like Formula+ for the primary.
    I don't use anything automotive in my Harley.....oils, tires etc. .....not counting wax's cleaner's etc.
    200+ Posts
    Aug 2010
    north
    I use RedLine Primary oil, 38 oz wet change. Had primary opened recently, around 16,000 mi, saw no compensator wear.
    My current rides, all modified in some way.
    '10 107" Street TriGlide FLHXXX, '07 SoftTail Deluxe FLSTN, '07 Road King Custom FLHRS with Liberty Side Hack, '09 103" Dyna FatBob FXDF with Frankenstein rear, '18 FLSS SoftTail Slim, '19FLSB Sport Glide, '19 Freewheeler
    300+ Posts
    Dec 2011
    Iowa
    Redline Primary Oil here also.
  11. #10
    50+ Posts
    Sep 2012
    Merrimack NH
    Havnt taken delivery of my TG yet, but in my FXSTB I ran Royal Purple in the engine, Redline shockproof in the tranny, and Formula+ in the primary, as soon as the TG comes home thats what will be going in it...The only place I use Syn3 is my lawnmower, worst crap I ever ran, bike ran hotter with it, clutch slipped with it, and the transmission sounded like it was crushing rocks with it....
    Ryan
  12. #11
    Sep 2009
    NE Ohio
    Quote Originally Posted by STG246 View Post
    Ryan
    In defense of Syn3, I ran it in the engines of my bike and trike for quite awhile. I can say I saw no difference in oil temp with either one between the Syn3 and Amsoil. I ran it in the primary of the bike for quite awhile without any clutch slippage, at 1 point I was making 104hp 100ft/lbs torque with the 95" engine I had in my 06 Ultra at the time. I will say I don't like it in the transmission at all, always found metal fuzzies on the magnetic drain plug when it was in the transmission. I switched to Redline Shock proof in the tranmission years ago which ended the fuzzies. I started running Formula+ in the primary because it is cheaper and has shown to help the compensator live a little longer. I had some oil analysis done by Black stone labs when I was running Syn3 in the engine of the 2010 Triglide I owned at the time. The oil held up fine, they found no damaging issues with it.
  13. #12
    Jan 2022
    Glen Saint Mary
    Default Oil consumption
    Can anyone explain why a 2012 HD Tri glide with only 3k miles burns a quart of oil every 1200 miles?
  14. #13
    Why?
    How Much?
    How often R & R?
    ATF? Dennis?
    Syn 3 20W50…. First change at a thousand miles and then every 10 thousand miles after..
    And I let the dealer do it’ Mostly cause I enjoy the 80 mile ride to them..👍..
  15. #14
    Quote Originally Posted by DaveC32040 View Post
    David..Welcome to Trike Talk..👍👍.
    10 years old with only 3thousand miles on it how long has it been sitting ??
    And if you are trying to keep the oil level right at the top mark check the air cleaner to see if oil is coming out from it…
  16. #15
    Jan 2022
    Glen Saint Mary
    I bout it used with only 1540 miles on it. The dealer I got it from went over the whole bike replacing all lines and all fluids. Air cleaner looks brand new...
  17. DKCustoms postbit
  18. #16
    You didn’t say do you see smoke coming out of the exhaust pipes..If not then….
    I’m trying to do the math The dealer change the fluids at 1500 miles.. there is now 3000 miles on it….So you added a quart at 25 hundred miles?.
    I run all my Harleys a half quart below the full line….I’ll ask again are you trying to keep the oil level at the top ..If so that might be where the oil is going… on Harley‘s sometimes The oil level will seek its own level….
  19. #17
    Jan 2022
    Glen Saint Mary
    I haven't noticed any oil coming out of the tail pipe or any residue sitting at the end of the pipe. I'm trying to keep the oil level where the manual says to keep it. I usually check it cold. Was talking with a gentleman I just met said he runs his 2015 HD between 1/2 to a quart low with no issues. I've only had this bike for 5-6 months. And, yes, it sat a long time in a garage.
  20. #18
    Jan 2022
    Glen Saint Mary
    Forgot, this will be the second quart put in the bike between 2500 and 3500.
  21. #19
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    For years I used HD primary oil, then they changed it to sport trans for trans or primary. Shortly after that I switched to Lucas primary oil.
  22. #20
    . I'm trying to keep the oil level where the manual says to keep it. I usually check it cold. .
    Next time you think it’s a quart low….Instead of adding a quart just add a Half Quart and maybe the next time you check it you’ll see it didn’t go lower….That is if it isn’t going past the piston rings and as light smoke out the exhaust pipes but not enough for the smoke to be noticeable..??
  1. Primary Fluid Capacity
    By ttanthony in forum Harley Trike Conversions
    Last Post: 07-03-2013, 05:20 PM
  2. primary chain adjustment
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-20-2013, 03:03 PM
  3. Transmission/Primary Chaincase oil
    By Lakeman in forum Harley Trike Conversions
    Last Post: 06-21-2012, 07:49 PM
  4. primary oil change
    By whizzer in forum Harley Trike Conversions
    Last Post: 05-14-2012, 05:40 PM
  5. Primary Gear oil
    By tri glider in forum Harley Trike Conversions
    Last Post: 10-01-2011, 09:58 PM
