Likes Likes:  45
Thanks Thanks:  2
Page 2 of 2 FirstFirst 1 2
Results 21 to 34 of 34
Thread: Love Jugs install today
  1. #21
    550+ Posts GoSlo's Avatar
    Oct 2012
    Centennial, CO, USA
    +1 ... One last question ... do you guys run these in the winter ... or am I the only nut job riding in the 30"s? ... LOL.
    Live just across the continental divide from you (south of Denver) and we ride year round as long as the roads are free of snow/ice. Too many clear blue sky days out here to not ride just because temps are lower. Yes, I ride with the fans on all the time, all year long and LOVE them. The Mighty Mites really do a good job. I've got mine wired so they start when the trike starts. Original install was wired so I had to remember to turn the fans on. Turns out I have more brain farts than I care to admit to and forgot to turn the fans on enough times that I changed the wiring.
    I used to have the Wards fans on my '13 Triglide and really liked the thermostat thing. Not so much for when it turned on (when engine temps reached around 220 degrees), but more so for when it turned off (fans stayed on until the engine cooled down to 180 or so degrees). Seems like it was a good idea to have the fans still run after you stopped to keep cooling the engine down...but to be honest, I don't know if that's a good/useful thing or not. I know there's a fan built into the trike that I hear running after I stop, but it doesn't run very long and not sure if it's cooling the engine down much. Maybe someone with more knowledge about this will chime in.
    ...Barry
    Ride Hard - Ride Fast - I'll catch up sooner or later
    2018 TriGlide • DK 14" lifts and shocks, tank lift, deflector wings, Mighty Mite Love Jugs
  2. #22
    Quote Originally Posted by GoSlo View Post
    The fans cool the coolant down ... not the engine.
    I get the whole brain fart thing ... when I buy these .., I'm getting whatever I need to make them come on with the ignition.
  3. #23
    5750+ Posts BillR's Avatar
    Aug 2015
    Gloucester, VA
    I have the Wards with thermostat on my '10. In the Summer they might run for 5 minutes, then shut off. The only time I turn them off is when fueling. I'm skeered of blowing atomized fuel onto a hot engine if I spill some. The couple of times I've forgotten to turn them back on, I noticed the heat difference right away on the Powervision.
    Bill
    R I P MANDY
  4. #24
    Bob's Curmudgeon Apprentice
    consitter's Avatar
    Jun 2015
    Ashland, KY
    My Ward’s fans come on with the ignition. You gotta buy the auxiliary switch that replaces the blanks next to the passing lights switch. I reckon I’ll be buying Mighty Mites from Zook when my present fans decide to take a crap. Wards isn’t an option anymore even if I wanted them.
  5. #25
    Quote Originally Posted by consitter View Post
    You are really going to like the Mighty Mites
  7. #26
    70+ Posts cowboy472's Avatar
    Mar 2019
    Westport Ma.
    Default Love Jugs
    You all convinced me. Mighty Mites are on my wish list for this year!
    I have to say. I in joy reading all the great advice. It just helps in proving owe life still of riding. Keep up the great job!!!
  8. #27
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Alan, take a look at the 5th pic in the thread and zoom in to see lighted switches in lower left dash panel. Just another method used to have more on/off control of some add-on electronics. https://www.triketalk.com/forum/thre...ob-almost-done
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
  9. #28
    Quote Originally Posted by ShapeShifter View Post
    So they are run off the same acc connection, just via that switch? You still have to turn them on or do you leave the switch on all the time? What else is in that acc port? it's only rated to 15 amps.
  10. #29
    Aug 2018
    SW, Arkansas, USA
    Yea, the harness for the Auxiliary Power Switch Kit connects to the Accessory Connector left side cover. The harness has a 4 way Deutsch Connection for electronics above 2 amps (plug and play connection for MM plug-in (dedicated to switch position 3 in the dash panel) That harness also has a two or three wire connection points for wiring in electronics below and above 2 amps, respectively (connections dedicated to switch in center position of dash panel. 2 wire components are like LED Lights and three wire connections like heated grips.
    I've been leaving my dash switch and flip switch for MM's always on, except when I visit dealer service. Apparently they get annoyed when the fans come on whenever they need to turn the ignition switch on, so they flip off the switch on the fans. Afterwards I push the switch on , but end up riding several miles before noticing the increase heat and reach down and hit fans flip switch. So turn off before entering service solves that.
    So only two connections for the switches harness; mine are Mighty Mites and Stealth LED Driving Lights. Because the harness has sole use of the Accessory Connector, is the reason why I'd like to have a "Y" connector to be able to connect my heated seat connector again, which I had to remove.
  11. #30
    Is all that gonna be less than 15 amps? I have no idea what those loads draw ... but seems like a lot ... as I've stated a lot ... me and tricity don't get along ... stuff scares me.
  12. #31
    Aug 2018
    SW, Arkansas, USA
    Well under 8 amp draw for LED Driving Lights, MM's and Heated Seat....But if it's cold enough outside for me use to the heated seat, then I'd never have the MM's switched on. So excessive current draw really isn't an issue for me.
  13. #32
    450+ Posts MB1953's Avatar
    May 2014
    Peru, IN USA
    And these fans cool the engine down. Got them with the accessory plug, right into the harness under the left cover. Dash switch on, fan switch on, fans come on with the ignition. Easy-peezy. gotta love them! Thanks, Papa Zook!
    2017 TriGlide Vivid Black - DK Outlaw AC, Fullsac performance baffles, PowerVision from DK, Love Jugs Mighty Mites from Papa Zook, HD Black Reach Bars, all kinds of BLACK stuff... Hi, my name is Mark and I used to be a chromeaholic!
    was - 2014 TriGlide Vivid Black - DK Custom Lift, 2" tank lift, DK Dual Cool, DK Discrete breather, Wards Parts Werks FCS, HD Reach Bars, all kinds of shiny stuff!
  14. #33
    Banned
    Apr 2018
    Clayton,NJ USA
    Quote Originally Posted by MB1953 View Post
    do they blow air across or suck air inboard?
  15. #34
    Quote Originally Posted by chester View Post
    They blow across to the air cleaner side
  1. Love Jugs Mighty Mite Install with Pics & Reviews
    By Recall in forum Harley Tri Glide
    Last Post: 08-17-2020, 08:45 PM
  2. Jug Fishing For Catfish..That's Not A Catfish!
    By Papa Zook in forum General Discussion
    Last Post: 04-18-2016, 09:13 PM
  3. jug fans to cool your barrels
    By waynerid1 in forum Harley Trike Conversions
    Last Post: 03-26-2016, 10:21 AM
  4. Shutting off rear jug
    By slaw32 in forum Harley Freewheeler / Road Glide 3
    Last Post: 01-06-2016, 01:41 PM
  5. Removing HD parade fan/install Love Jugs
    By Lakeman in forum Harley Trike Conversions
    Last Post: 03-06-2015, 08:23 PM
