LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Results 1 to 5 of 5
Thread: Lehman Monarch II rear suspension
    Oct 2010
    canada
    Default Lehman Monarch II rear suspension
    When riding over an uneven surface the rear tire on my trike either hits the fender or, is lifting off the road and then skidding as it connects again. Any suggestions as to the best rear suspension settings for this trike.
    I believe that there is a ring to adjust the spring tension in addition to the preload setting.
    I am not very heavy - about 170lbs.
    Also any idea on what weight the trike will carry - rider, passenger, luggage.
    Thanks for your help.
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    Default Re: Lehman Monarch II rear suspension
    Hi Bette, and welcome to TrikeTalk. We've got some great folks on here. You should get the answers you need
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Welcome to TRIKE TALK Bette.I can' help with your problem,but you have come to the rite place. Enjoy and RIDE SAFE
    The Spaminator ThirdWheel's Avatar
    Mooresville, NC
    bette - Welcome to the site. First check the air pressures in the rear tires. They should be around 18-22 lbs., overinflated would cause extra bounce. What shocks are on the rear? What bike do you have triked? That will determine the what load you can carry.
    Quote Originally Posted by bette View Post
    Welcome aboard bette. Glad you found us.
  1. Rear tire sizes for gl1800 lehman monarch ii trike
    By Motogordo in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-24-2016, 10:23 AM
  2. Germany need your help, Lehman Monarch
    By ramon in forum Lehman Trike
    Last Post: 11-24-2012, 07:47 PM
  3. Lehman Trikes Monarch II
    By cincydude in forum Honda Trikes
    Last Post: 10-03-2012, 05:16 AM
  4. Lehman Monarch II rear shock actuator
    By Mick in forum Lehman Trike
    Last Post: 04-21-2012, 11:47 AM
  5. Lehman GL1800 Monarch
    By DeerWrangler in forum Honda Trikes
    Last Post: 12-14-2011, 09:06 PM
