Stallion Parts & Maintenance Reference
My AC did leak But I tighten the fittings and did a recharge I have cold air
All the time now in las vegas
Also on the antifreeze at the rear left tire there's a pipe with a rubber cap might have to be replaced same thing the right front under the hood by the gear shift does a rubber cap that I had to replace and mine works fine after those replaced
Re: Air Leak
I have noticed that I'm losing air, both over night and while riding. Last night I parked at 28psi, both sides even. This morning was at 17psi, and a 3/4" differance left to right side. Anyone else had this problem?
I had a slow leak as well. Turn out to be a leaking valve stem. Now, all is good
Re: First oil Change
Hello; Mattel, I use car ramps and just back my stallion up on them works great, also I bought a Low Profile Floor Jack from Harbor-Freight I think it was about $80.00 but it's only 2 7/8" high and goes under the frame easy and its a 3ton. Hope this helps.
William aka: admin7
I changed my Oil this weekend and it went well. I have heard that it is tough to get off the oil filter for the first time, so I used a Cup style oil filter wrench. The tip that i learned related to using the filter wrench. With the cup style wrench if you do not get it to seat all the way it will just slip. I used a rubber mallet to tap it into place. Once I did that, it was a snap to get the oil filter off. Then you need a vice and a flat head screw driver to hammer the wrwnch off the old oil filter.
I used a 13mm socket to get the oil plug out.
My Stallion only took about 4 quarts of synthetic oil.
The most difficult thing was to get my Stallion up high enough to change the oil. Big Dog suggested using bricks under the rear tires. I stacked several bricks 4 bricks high and used plywood. I had to use a car jack to get the frame high enough to use a floor jack.
One other thing I noticed was the oil filter I took off my Stallion was longer than the stock Ford filter.
Over all it went well. I think the next time will go smoother now I know how to do it.
Re: Locking Gas Cap info
Thanks! thats good news.
William aka: admin7
I found the locking gas cap that fits the Stallion:
It is the Stant 11510
It also fits the 2008 Mustang
You can reuse the plastic connector that keeps it connected to your tank by just sliding it off and attaching the new gas cap to it the same way.
Save your old gas cap, you may need to replace the rubber gasket in a few years.
I found this at an Advanced Auto Parts store.
Has anyone ever pulled the steering wheel off their stallion? I need to pull mine because when going straight on the road my wheel is tilted to the right, and not straight across the way it should be any help would be greatly appreciated still can't find a service/maintenance manual for my 2008 stallion. Anyone find one yet???
William
Re: Parts & Maintenance Reference
Your attachment pic didn't show up for me could you please pm me a pic if you can. thanks William
To the Stallion owners, I found this lift searching the internet. It's available through Northern Tool. It has a lift capacity of 2000 lbs. I thought it might be the answer for servicing my YET to arrive Stallion, like changing the oil, tires, exhaust work and so on. Since I hold the comments and opinions of this forum in such high esteem, would anyone care comment. (I hope the attachment photo displays correctly...)
Daydreamer
For the ones that is worried about the low clearance of the stallion I had the same problem, and found a Low Profile Floor Jack from Harbor-Freight I think it was around $80 bucks it is only 2 7/8" high and lifts to 21" hopes this help... Works great for me.
William
William
You don't need to pull the steering wheel to get it straight. Go under the hood and look for the zerk fitting on the top rod. You will need to just adjust that part to bring the steering wheel back straight.
Hope this helps
Hello; everyone, I was wondering if the stallion had a paint code stamped some place on the trike, have to get some damage repaired my color is Black Cherry , and 2008 but, it has like metal-flake in it or something I can't find the code anywhere.
Thanks!
William
William, I'm not sure where the code might be stamped, but I believe your codes are:
U.S. Paint Code Color Description Honda Paint Code
AJ7023* Bloodstone Red (Black Cherry Candy)* R-287M
Double check to make sure on the codes. I tried matching my color exactly, without going to the company that makes the paint for the Hondas and Stallions (US Paint) and it did not match. My body shop had to order the paint from US and unfortunately they won't sell in small quantities.
The paint codes can only be found through Thoroughbred Motorsports/Motor Trike...
The Stallion paint is different depending on the VIN#... There were changes made in the vendor as well as specific paint formula changes...
Some year models paint can only be ordered through Thoroughbred due to it being a custom PPG paint.
Hope this helps! ThumbUp
Deniz
Go to the US Paint and type in Stallion and you should see the colors. I haven't checked it out for a couple of years now, but they did list the Stallion colors separate.
Tomg
TOMG you are right to an extent...
The PPG can be had through the vendor store locations no problem...
The U.S. Paint is a different story... When you try to order through U.S. Paint, they want to sell it to you by the QUART :xzqxz:
Unless you need a LOT of extra paint, The only other option I know of is to go through Thoroughbred for a smaller quantity...
This information comes from the US Paint website.
Re: Stallion Parts & Maintenance Reference
I bought a 2009 Stallion a couple days ago.....has anyone had an issue with their fog lights? If so what did they find wrong? Both of mine are out.
Got another question....are the amber turn signals also amber markers?
Could just be the bulbs are out. You do know to turn them on the light switch goes clock wise on then pull the center out to turn on the running lights.
Ted
Also what is the last 3 of the vin that you purchased? Post some pictures
I can't help with your for lights, but the turn signals are just that, not marker lights.
I can barely figure out how to read replies let alone add a picture.
Thanks for your help and yes I was able to put the switch in the correct position.
Ted
Testing to see if photo comes up.
Nope didn't work yet.
well suggest that you start trouble shooting. Look to see if you have power to the bulbs with the switch on. Check for a blown fuse. If factory switch is bad suggest just wiring them with a replacement switch. The bulbs can be replaced in the housing. You have to solder the wires in but it beats buying new lights. I believe the buld is a H-3 100 watt. I would suggest substituting with 50 w they last a lot longer and the difference in light is not that much.
LoneRider
LoneRider
