Results 1 to 10 of 10
Thread: VW Trike Value
    Default VW Trike Value
    Going to look at this Rewaco VW Trike and have no idea what it is worth. Can anyone give me a ballpark figure so I won't get took? This is all the info I have "this is a rewaco trike factory made.completely rebuilt about a year ago.it has new motor/ wiring /lights stereo.upholstery and only has around 800 or so miles on it." I provided a link that should carry you to it. Hope it works. If not, thanks anyway.
    vw trike
    The Spaminator ThirdWheel's Avatar
    Mooresville, NC
    Default Re: VW Trike Value
    Trikectr, who is a member here is a Rewaco dealer and distributor. PM him and I bet he can give you some advice. Sounds like an excellent deal. Just make sure everything is on the up and up (maybe to good of deal).
    20+ Posts cblack6540's Avatar
    Feb 2010
    Port Richey , FL
    sounds like a good deal. check the crankshaft endplay by pushing and pulling on the bottom pulley. should be very little movement, .004 to .006 thousands play is ok,if it feels like a notch the case is bad. a lot of people rebuild these engines and never check the case. better safe than sorry.
    Thanks for your response. I am going to a swap meet tomorrow that the trike will be at. May get some additional info on it and then send it to the dealer and see what he thinks. I thought it looked like a good buy.
    Quote Originally Posted by hdcharles17 View Post
    vw trike
    I'm not an expert on what type of trikes Rewaco makes, but I've never seen one like the one in the picture made by Rewaco.
    I agree. I am having problems finding a Rewaco Trike like this one. I have searched the net but could not find one even similiar. I am going to lay eyes on it today. I think it is early 90's but I am no expert either.:yes:
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    It don't look Rewaco to me either .. Most have a much larger structure . The top would be the first thing to go in my list.
    http://www.quadvertiser.co.uk/en/for...EWACO++Red.htm
    20+ Posts sewelly's Avatar
    Mar 2010
    Victoria Australia
    It IS a mid 90's rewaco - HS1 i would say. Usually can tell by the bodywork where you would generally see a tank nowdays.
    The Herman Munster thing could be ok depending where you live but might make ya a bit unstable at speed lol
    Good luck with it. Let us all know how you go
    Quote Originally Posted by sewelly View Post
    Yep, your right! It is a mid 90's HS1. Looks just like a lot of home built trikes.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Looks like it might be a very decent deal to me if everything had been re-done and it checks out in person. Let us know what you find out.
