Likes Likes:  6
Results 1 to 20 of 27
Thread: Cutting antennas
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Default Cutting antennas
    I would like to slip a small flag on the base of each antenna, but I can't get the flags over the caps on the ends. Can I clip off the caps and then glue a cap back on? I can't think cutting 1/2" from each antenna would hurt anything. Am I wrong? Any other suggestions? Heating with a heat gun maybe?
    IBA#61162
    PATRIOT GUARD
    USMC
    Oct 2010
    USA
    I cut mine when I had the TRI. and didn't affect anything. Dont they still have set screws holding in the antenna to the base spring?
    Trike Talk Executive Chef
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    If you have a Tour Pak with the Mount on top, they make a Spring loaded flag Pole that clamps on.
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
    Member Patriot Guard Riders
    70+ Posts cowboy472's Avatar
    Mar 2019
    Westport Ma.
    Antennas are cut to a wave length ether for receiving or transmit. It's not advisable to cut unless you are tiring to tune it. You can try stripping just the rubber tip off with out changing the length. Then you can slip your flag over the top. Then glue a vacuum line cap on top for protection. Personally I would just sew the flag around the ant.
    I'm not sure I'd put a flag on the antenna ... at 75 mph that's gonna put some stress on the antenna, I know the HD antenna flag mounts state for parade use only for that very reason.
    200+ Posts pioneer11's Avatar
    Jun 2016
    Occupied Kingwood Tx
    You don't say what kind of antenna it is. If it is for receiving broadcast radio, you won't notice a difference. If it is CB, watch out. You may be making it too short which could cause the RF output transistors to overheat and fail.
    Remember, electrical stuff works on smoke. If the smoke gets out, they quit working.
    Keep your eyes on the road and your feet on the floorboards.2016 Freewheeler
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    I'm with Fuzzy on this. Mounting flags on the antennae is a bad idea imo.
    Mar 2019
    Westport Ma.
    Your right i didn't stop an think to ask how large of a flag. I was thinking they wanted the small ones.
    Even a small flag is gonna stress the antenna ... ever put your hand out the window of a car at 70mph ... lots of force ... it might be okay .. and HD antennas aren't that pricy, like $25, so you could try it ... another issue might be if the flag ever stretched and slid down on the "fat" part of the antenna, it would scratch the paint flipping around ... just playing "devils advocate" ... looking at plusses and minuses ...
  11. #10
    At least your putting the flag on an American [For now anyway] Trike.....I Get a kick out of the nimrods with an American flag on a Japanese vehicle.....
  12. #11
    GLEN ELLYN, IL. USA
    I don't think so anymore.
    IBA#61162
    PATRIOT GUARD
    USMC
  13. #12
    GLEN ELLYN, IL. USA
    Quote Originally Posted by Sully View Post
    Thanks, but that costs waaaay too much.
    IBA#61162
    PATRIOT GUARD
    USMC
  14. #13
    GLEN ELLYN, IL. USA
    A small 3" x 5" shouldn't effect the antennas at all down by the base. Worked OK on my older bikes. The caps came off them fine, but not the newer antennas.
    IBA#61162
    PATRIOT GUARD
    USMC
  15. #14
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    How about just using a Zip Tie.........
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
  16. #15
    GLEN ELLYN, IL. USA
    Then I'd have to cut holes in the flags to run the zip ties thru. Then the flags would really tear apart.
    IBA#61162
    PATRIOT GUARD
    USMC
  17. DKCustoms postbit
  18. #16
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    Wow......most flags have Brass Rings for mounting.
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
  19. #17
    Go to a Walmart and in the fabric/crafts aisle get a tube of Liquid Stitch. Fold the end of the Flag around the antenna and glue the fabric together.....Just don't make it too tight around the antenna so it can swivel in the wind...The Liquid Stitch is water proof and its almost like you sewed it on...Ive used it on my leather motorcycle jacket to fix a rip, And its held up for years....
  20. #18
    Aug 2015
    ft worth
    I concur, always seemed odd,. jap stuff merican flag, mmm, oh well.
  21. #19
    4750+ Posts
    Mar 2015
    Texas
    Are you really and truly talking about a 3 inch by 5 inch(small 3" x 5" ) flag? What kind of material? Cotton at 70mph will do damage to an antenna even mounted at the base. Polyester you might be okay. Now any damage might not show for awhile, but if you think about how much flapping around a flag will do, at some point you'll see the damage. Especially on the whip antennas. Some of that damage might be the paint on the tour pak if you get the flag too close. If you have the short antennas you might be okay as they are stiffer. All in all I think anything on the antenna is not good.
    American Legion Rider
  22. #20
    GLEN ELLYN, IL. USA
    I agree, Larger flags (15" and larger)do, but small ones don't. At least the ones I have don't.
    IBA#61162
    PATRIOT GUARD
    USMC
  1. Antennas
    By plumberdoug in forum Harley Tri Glide
    Last Post: 01-15-2015, 10:39 AM
  2. How good are internal antennas?
    By dadorfman in forum General Discussion
    Last Post: 05-05-2013, 03:29 PM
  3. Trike finders: Antennas
    By Konrad in forum Honda Trikes
    Last Post: 10-31-2012, 12:01 PM
  4. Finding a spot for mounting my Antennas
    By bulkness in forum Harley Trike Conversions
    Last Post: 05-23-2012, 09:32 AM
  5. Diamond cutting
    By redneckray in forum General Discussion
    Last Post: 10-22-2010, 06:32 PM
