Likes Likes:  9
Results 1 to 20 of 20
Thread: 1500 Cornering lights
    150+ Posts eastkytriker's Avatar
    Jun 2013
    Grayson, Ky.
    Default 1500 Cornering lights
    Just wandering has anyone tried the 50 Watt LED Replacement Cornering Light Bulb (SCML50WC-2 from Cyclemax. Is replacement simply as printed and are they brighter than the oem bulbs. They are quite pricey and I haven't seen any kind of review.
    May 2011
    San Angelo
    Quote Originally Posted by eastkytriker View Post
    Howdy Roger. If my old memory serves me right folks that have tried that melted plastic parts. In most cases the manufactures seem to give all the light that works correctly but with the advent of LED lighting you can get much more brightness with much less heat. If you can locate an LED bulb to fit that would be an excellent solution.
    2015 GL1800/Roadsmith HTS1800
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by Gold Rush View Post
    Howdy Roger. ... etc ... If you can locate an LED bulb to fit that would be an excellent solution
    Ummmm .... I read his, then yours ... and was soon scratching my head
    If anyone needs it, a link:
    http://cyclemax.com/inc/sdetail/50_w...bulb/83/270155
    May 2011
    San Angelo
    BINGO !!! That will not melt plastic! Thanks for passing that on CP.
    Apr 2010
    Oh .... it had me wondering too. I knew "E-T" said LEDs, but he called them 50 watt LEDs. I knew .... "can't be".
    When I first bought our Trike in 2004, it had the wire cut at the relays to make them hot all the time .... I replaced bulbs a couple times (not a common bulb & not cheap at Honda shop) ....
    then I reconnected that wire.
    No blown bulbs since.
    I may decide to clip it again myself and use a set of these LEDs myself. One could even wire a small DPDT Switch in to the wires and "choose" on the go?
    May 2011
    San Angelo
    When I first bought our Trike in 2004, it had the wire cut at the relays to make them hot all the time .... I replaced bulbs a couple times (not a common bulb & not cheap at Honda shop) .... then I reconnected that wire. No blown bulbs since.
    I'm soooooo embarrassed!!
    I committed one of my Pet Peeves.
    Either that or it just did not get through my thick skull before I developed an opinion. Either way, I must apologize for muddying the water.
    Apr 2010
    Every time I do something like that .... I promise I'm gonna proofread my posts and whatever I respond to .... again before posting .... and then I do it again.
    Jun 2013
    Grayson, Ky.
    I am really confused now. I guess we now have the description figured out so now how good do they work for 58.00 for two.
    May 2011
    San Angelo
    If they do indeed have the illumination factor of a 50W bulb then by all means they will be a LOT BRIGHTER than the original 35W ones. The key again is to get the brightness without the heat and these LED bulbs should easily fill the bill. Let us know you results.
    Jun 2013
    Grayson, Ky.
    Guess someone has to be the Guinea Pig and try them first. I guess it might as well be me.
    Apr 2009
    Amarillo Texas, Potter
    Default Cornering Lights
    My trike is a 98 so the "cornering lights" are on all the time. Are you asking about a bike where the lights are actually "cornering". That could be factor in regards to the heat generated. Let us know as "inquiring minds" like to know. Looking forward to seeing how this works.
    Apr 2009
    Well, I put my foot in my mouth too. I should have looked at the bulb description before I jumped in. As soon as I saw the listing I knew I had just stepped in it. I am slowly replacing the many incandescent bulbs on my trike so I will be trying these sometime soon. Am still interested in hearing your results.
    Jun 2013
    Grayson, Ky.
    Default New LED Cornering lights
Size:  545.5 KBName:  100_0761.JPG
    New LED Cornering lights before and after from cyclemax. Looks some brighter but not what I expected for 58.00. Oh well maybe everyone else will see me better and that's what im after.
    May 2011
    San Angelo
    Thanks for posting the results Rodger. What is the actual difference in brightness from the rider perspective? I totally agree they are making you more visible but do they help you see better as you turn?
    I'm with ZOOK.... Money well spent even with what you've shown us already.
    Jun 2013
    Grayson, Ky.
    They do light the side of the road a lot better, which is good when you have a broken spot in the shoulder or a dead possum laying in the road and hopefully I will be more visible.
    May 2011
    San Angelo
    Thanks! That's good news Rodger. Sounds like you are better off than before so I'd say you spent $$ well.
    Apr 2010
    Well, at only 6 watts power each vs 35 watts oem each and the brighter white .... I think I will order a set and slip in and clip that wire at the relay and put that switch in there so I can use as cornering or visibility lights.
  19. #19
    Apr 2009
    I installed the 50w led's in my cornering lights about a month ago and am well pleased with them. They were a simple plug in and forget. They do much for the side illumination especially with the high beams on. I was afraid oncoming traffic would be continually flashing because of the brightness but thus far it has not been a problem.
  20. #20
    Jun 2016
    Jackson,MIssouri,USA
    I have them in my 1500 and they are a lot brighter and have had no issue with heat.........
  1. Help with cornering. New trike owner. 2015 Triglide.
    By Trikenewby in forum Harley Tri Glide
    Last Post: 07-22-2020, 09:48 PM
  2. Which LED lights for the rear tail/brake lights
    By 470004 in forum Harley Trike Conversions
    Last Post: 11-20-2014, 08:13 PM
  3. Cornering - How fast?
    By VinnieBagaDonuts in forum Harley Trike Conversions
    Last Post: 09-20-2013, 04:17 PM
  4. Cornering Lights 1500se
    By geneo in forum Honda Trikes
    Last Post: 10-28-2012, 02:28 PM
  5. New triker cornering concerns?
    By bernard in forum New Member Introductions
    Last Post: 12-15-2009, 12:38 PM
