Likes Likes:  1
Results 1 to 20 of 31
Thread: HD reduced Reach Batwing Handlebars
    150+ Posts JJHog's Avatar
    May 2013
    Pittsburgh, Pennsylvania, USA
    Default HD reduced Reach Batwing Handlebars
    Planning on installing the HD Reduced Reach Touring Handlebars. Has anyone installed them and did you have to replace the front brake lines? I know you can reroute the clutch cable by not routing it through the batwing but I'll get and longer black cable instead. I've heard you can reuse the front brake line but was wondering what one did to make up for the 2" extension on the handlebars.
    Just the usual's so far, SE Stage I Air Breather Kit, SERPT Tuner, V & H Power Duals, V & H Turndown Slip-on mufflers, Barnett +1 Carbon Fiber Clutch Kit, AIM 480# Clutch Spring, ClutchWiz, DK Products Comfort Soft Lift Kit, HD LED Headlight and Passing Lamps, HD Reduced Reach Touring Bars, Clearview 10" recurve windshield, Boom Audio Fairing and Passenger Speakers, Kuryakn Adjustable Passenger Footpegs, Rivco Trailer Hitch.
    100+ Posts
    Punta Gorda Fl
    Default Re: HD reduced Reach Batwing Handlebars
    When I put mine on the clutch brake and throttle all fit fine. You can still use the hole in fairing for clutch cable. Just re route it along the front of the frame.
    Jul 2013
    Hernando fl usa
    No problem it is all good. Feels better ridding.
    150+ Posts 5x40's Avatar
    Oct 2013
    Land Between the Lakes, Tn
    No problem w/my HD pullbacks..dealer installed w/out any extra parts too buy..they feel great as I am only 5'5"...
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    will these handle bars fit the 2014
    2019 Goldwing CSC
    Oct 2013
    Quote Originally Posted by sylwoody View Post
    according to the HD on line parts list, yes. this is the model I had installed on my 2013.
    part#56176-08 $154.
    PM me if you are interested on a set. I just put a set on my 2013 TRI for 3 weeks. I had to change to Heli-bars due to my bad wrists. On long rides the right wrist could not hold the throttle any longer. The same with the stock bars. I loved the reach of them but I needed something that will keep my wrist straighter. PM if you want to buy them.
    750+ Posts
    May 2011
    peru,in,usa
    as info I installed paul yaffee's 10" "bagger bars" not apes on my '09 triglide. needed a 4" over clutch cable. wireing was ok . the only think I suggest is if you cut 1/4" off of a allen wrench, you CAN remove the trans side cover with-out removeing the exhaust.
    also butter lube the "O" ring on the new clutch cable with permatex non-hardening sealant before you install it. to prevent any future leaks.
    500+ Posts jcolson's Avatar
    Jun 2011
    South Bend,IN,USA
    Had my bars on since new. Love them. Makes it easier to steer. More leverage. In the cataloge it says to replace upper and lower brake lines and clutch cable. So that's what they did. They installed the braided lines which are better anyway.
  11. #10
    May 2013
    Just got my TG back with the Reduced Reach Touring Bars installed. We replaced the TBW with the recommended extended assembly, replaced the clutch cable with a 4+ aftermarket black vinly cable and reused the front brake assembly. I wasn't interested in replacing all my cables with braided stainless HD cables. Feels great. Moved me back in the saddle a bit, brought my hands a little closer providing better leverage. Also raised the level of my hands a bit. Would recommend this setup to anyone that is vertically challenged (5'6" or less).
  12. #11
    Thanks for the interest the bars are gone
  13. #12
    Nov 2013
    Cerritos,ca,USA
    How much did the labor cost? Around a thousand was what the HD salesperson said.
    I am 5' 2" and would like to change mine. The previous owner put some custom bars on the flhxxx and they are way too far for my reach. Was also considering a different seat also. Thanks.
  14. #13
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    Quote Originally Posted by jenr View Post
    I put my 2" reach bars on myself & the bars only cost me $119. The clutch cable was just fine where it was & left stock. The wiring was fine, & the brake lines fit just fine.
    Where they would get $1000 for the bars installed is puzzling.................. Maybe with 5 or 6 hrs labor & all parts having to be replaced.
    WOW !
    Prepping you before the shock with a green light to make some serious coin !
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  15. #14
    Oct 2013
    My handlebars cost $134 and dealer install was $186. Needed NO extra parts, lines, etc...
  16. #15
    450+ Posts tbear's Avatar
    Sep 2013
    Carleton, Michigan
    Quote Originally Posted by 5x40 View Post
    AND WHAT YEAR TRIKE DO YOU HAVE??? and name of Handlebars,again?
    TBEAR
    2010 Triglide Harley Davidson
    V&H Exhaust,True Duals, Big Sucker Ac,,557 S&S Cam,SE Compensator 2014, oil cooler,EBC r.brakes,Progressive air-shocks,Floorboard extensions,rear fender bras, Dynoed,krome-werks 2+2 bars, and a sheep wool butt protector....
  17. DKCustoms postbit
  18. #16
    Oct 2013
    Quote Originally Posted by tbear View Post
    HANDLEBAR, 2 INCH PULLBACK #56176-08 LISTED PRICE...$149.95 I get military discount, I paid $134.95
    My trike is a 2013
  19. #17
    Jul 2012
    Talladega,Al 35160
    what has to be changed to put these on a 2014 TG?
    2019 Goldwing CSC
  20. #18
    Jul 2012
    Talladega,Al 35160
    will the hydralic clutch line have to be changed?
    2019 Goldwing CSC
  21. #19
    Jun 2016
    Boise, ID
    Quote Originally Posted by woody View Post
    I haven't seen a post in a while so I will update this installation. I have a 2014 HD trike and just installed the reduced reach handlebars (#56176-08) myself. I paid $155 for the bars and the local HD dealer wanted $230 to install them. They work with the original wiring and hydraulic lines with no problem. I have dealer installed HD heated grips and they worked as well. The bars are almost identical to the original except have a lesser bend in them, so when laid back they sit correctly, not pointed down. That is where the 2 inch setback comes from, not that they are longer. I am 5'6" and they are more comfortable and I would recommend them for shorter riders. These bars also work on 2 wheel HD touring bikes.
    I recommend viewing <cite class="_Rm]HOW TO INSTALL HANDLEBARS ON A 2015 HARLEY STREET GLIDE video @ </cite><cite class="_Rm]
    , by Rumbling Rider.
    The video is well done and explains how to remove the fairing so you can replace the handlebars. The most difficult and meticulous task is dismantling the "throttle wiring" plug since it will not pull through the bars.
    All you need is a sharp thin "ice pick" and a lot of patience and you will save money by not buying a new wiring harness.
    You can run the control wiring internal or external to the new bars since they have open slots in them. I went external as was the original wiring. (Throttle & heated grip wiring is internal) If you go internal, you have to relocate the wiring plugs from the electrical panel as shown in the video.</cite> Not difficult, just a few extra steps. Pulling all the extra wires through the bars is a challenge as well. I could not have done this myself without the video to guide me. I am glad I did it as it has given me more confidence to work on the trike myself rather than paying someone else to do it.
    I know this was long, but hopefully it will clear up some issues and encourage others to install them as well.
  22. #20
    60+ Posts
    May 2009
    Chesapeake, VA.
    Default Helibars
    I had a set of Horizon ES Black HeliBars installed on my 2015 TriGlide while I was at the Sturgis Rally last month. As soon as I sat on the bike I fell in love. Hands down, this is the best set up I have found to let a short (5’ 3”) rider sit up straight. I can actually lean back against the rider backrest with my arms still bent at the elbow. Getting a better seating position is more important now that I’m getting older; my lower back does not like leaning forward. FYI, The MoCo “Reach” seats were a non-starter; I did not like half way sitting on the gas tank.
    Scott Smith
    2015 Tri Glide: Painted Inner Fairing, Anarchy Five-Spoke Black Chrome Wheels.
  1. Reduced Reach Handlebars
    By patriot in forum Harley Trike Conversions
    Last Post: 03-06-2013, 04:36 PM
  2. ?? Batwing Adjustment ??
    By Chappy in forum Harley Trike Conversions
    Last Post: 06-22-2012, 01:51 PM
