Likes Likes:  3
Results 1 to 16 of 16
Thread: Ideas to improve passenger view (height)
    Dec 2016
    Atlanta
    Default Ideas to improve passenger view (height)
    Been lurking awhile and learning a ton from all of you - thanks. My passenger is 5'3"
    and I'm 5'6" and she says all she can see is the back of my helmet! 2016 FW (Velocity Red) is our ride, with stock seat and Tour Rest back rest for her. I understand the benefits of a lift kit and the potential for a more "comfortable" ride and am seriously considering ordering & installing. Wondering from those of you that have installed, if your passenger has noticed any appreciable height increase. Will the lift kit help “boost” her viewing position – even just a little - or do I still need to find another solution? I’ve seen the HD Road Zeppelin Passenger Pillion Pad (think inflatable pillow), but can’t quite pull the trigger on $140, unless someone has one and swears by it – then maybe! Any other suggestions? - beyond getting a taller passenger - cause that's not a viable solution ()!
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    Welcome to TT!
    My wife is 5'2". She says that she just looks to one side or the other.
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    I haven't ridden the backseat on a motorcycle for many years now but I do recall that for the year I did - on the backseat of a Gold Wing - I hated sitting taller than the driver....the wind buffeting was horrendous. That's when I decided to drive my own bike. Have never regretted that decision. Carla
    Dec 2016
    Atlanta
    Quote Originally Posted by paws View Post
    good point on the wind! - thanks -
    Dec 2016
    Atlanta
    Quote Originally Posted by Keystone View Post
    Welcome to TT!
    Thanks - I think that will ultimately be the best solution - learning to look off center just a bit - and soon my helmet will disappear! thanks too for the welcome - I'm really enjoying and learning and hope to contribute as I can. Santa brought us some adjustable passenger floorboards - so I'm hoping to capture the install and load the pictures as others have done with their various customizations. My passenger has some pretty bad knees and the stock position is just not comfortable after about an hour, so we are hopeful the 12 positions and 9 degrees of range will help take some of the pressure off her hips and knees. Once I get them installed and we ride, I can update the post with her feedback. (not associated the company or their products in any way other than being a first time customer!)
    200+ Posts
    Nov 2015
    palm bay
    What Carla said. My child bride rides behind me on my trike when she wants to avoid the wind buffeting. Otherwise she rides her own bike.
    I have a H-D air cushion I seldom use because it raises me up 2 - 3 inches into the turbulence depending on how full I pump it. It is a nice change for my behind sometimes.
    200+ Posts knob's Avatar
    Jan 2015
    Metropolis
    Quote Originally Posted by marnie View Post
    I also added some adjustable passenger floor boards for the wife to help with the hip pain. I raised them all the way up and shazam everything was better for her as far as discomfort. As far as her setting up higher, you might just add a seat pad and see if it helps.
    Dec 2016
    Atlanta
    Quote Originally Posted by knob View Post
    thanks - what seat pad did you find / use? I've seen the circulator style for the pillion and that looks somewhat promising and beneficial for summer riding.
    3250+ Posts hogmemberisold's Avatar
    Nov 2016
    Shepherdsville, Ky, USA
    We both have a airhawk cushion. She uses a square one, mine is more cycle seat shaped. They have their place... be worth a try....
    Jan 2015
    Metropolis
    No seat pads for us, I was just suggesting that as an idea.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Yes, not only does it increase the height, it also changes the relationship of the passenger height with the rider height via the angle.
    Besides that other benefits of a Lift Kit, what I noticed is my eye line sits higher in relationship to the windshield (due to angle change) and Mary noticed that she sat "less leaning back", again due to the angle change.
    www.DKCustom.com
    gerald martin
    Guest
    Default lift kit
    are there any pictures of a freewheeler with a lift kit and one without a lift kit standing side by side
    Dec 2016
    Atlanta
    Thanks Kevin - given all the bennies of a lift kit - I think that is the direction I'll go. Appreciate you taking the time to respond.
    Dec 2016
    Atlanta
    Quote Originally Posted by gerald martin View Post
    Check out the Dk customs page - lift kits - couple of nice pics there showing both. I just went there looking and found the pics. I think it will work for me. I'm just not sure I'm up for taking the wheels off for the install! I.e I don't have the jacks / stand etc ...
    Zeppelin pillow if u can find one on Flea Bay
    Pillow case with a phone book inside...The larger the City the phone book is from the taller you'll sit. And Vice Versa... .
  1. Headlight Height Adjustment
    By paid4c4 in forum Honda Trikes
    Last Post: 06-15-2016, 06:57 AM
  2. Windshield height - looking over it or through it!
    By RagenTri in forum General Discussion
    Last Post: 05-14-2015, 11:51 AM
  3. First ride: handling..does it improve as the bike breaks in ? Or inexperience.?
    By missedem in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-22-2015, 08:13 PM
  4. How to improve GPS screen viewing?
    By GoSlo in forum Accessories
    Last Post: 10-10-2014, 09:34 PM
  5. Trailer Ball Height
    By tis in forum Trailers / Campers
    Last Post: 05-28-2009, 07:07 AM
