Likes Likes:  37
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 53
Thread: We need to talk about oil.
  1. #21
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    The Lucas Oil I'm using is doing great for me, but I'll look into it.
    What weight gear oil do you use?
    I see some are 70w-90 and some are 90w-140
    Gear oil is not my strong point. Lucas makes a dedicated oil for the differential & tranny.
    I have heard good reviews on Mobil 1 & Valvoline full synthetic gear oil.
    I also read the gear/tranny fluid is under low stress & can take 10,000 mile change intervals.
  2. #22
    Try Redline heavy with shock proof,
    Mobil 1 is good also
    I am currently running Lucas 75-145 synthetic
    The Redline cuts down the clunk
    Plus it is designed to cling to the gears better
    You can view on the site what a burned up tranny looks like
    You will see shifter forks burned blue
    Spectro makes a Platinum 6 Speed gear oil
    Baker the leader in the Tranny industry ships their trannys with a quart of this lube
    I have run this in my 07 Dyna,it was a very good lube
    Much like most oil threads you will see many likes
    IMO your ride you decide
    I just hate seeing motor oil in a gear box
  3. #23
    Oct 2017
    St. Louis, MO USA
    You have me convinced. I will keep the Lucas 20W/50 for the motor. Hell, I might as well try their tranny fluid. How long of a change interval are you using?
  4. #24
    4750+ Posts
    Mar 2015
    Texas
    Those 2 reasons are why I liked Redline while I had a Harley. You had to listen extremely close to tell any difference in the clunk though. It was slightly better. I also like gear oil for gears. But Harley says motor oil is fine and they have to warranty their drivetrains. But what happens after the warranty period? It's on you then so choose wisely.
    American Legion Rider
  5. #25
    10,000 miles
  6. #26
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    An oil thread!
    To delve deeper, for those interested...
    What weight oil is "20-50"? (no, it is not 20 weight when cold and 50 weight when hot)
    Can someone look at their M8 Owners manual and see if they have a page that reads similar to the one below?
    www.DKCustom.com
  7. #27
    An oil thread!
    Same chart.... In my manual...2017 T/G, Except no 10/40 listing In place of the 10/40 is 20/50 full Synthetic.. ......
  8. #28
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Thank you. Was not sure if HD was still saying it was best to run straight 50 in temps higher than 60* and straight 60 in temps higher than 80*.
    (not that you will damage the engine running a thinner oil, like 20W50, in hotter temps....it's just not the best practice)
    www.DKCustom.com
  9. #29
    Oct 2017
    St. Louis, MO USA
    Table 1. Recommended Engine Oils
    TYPE
    VISCOSITY
    RATING
    LOWEST AMBIENT
    TEMPERATURE
    COLD-WEATHER STARTS BELOW
    50 °F (10 °C)
    Screamin' Eagle SYN3 Full Synthetic Motorcycle Lubricant
    SAE 20W50
    HD 360
    Above -1 °C (30.2 °F)
    Excellent
    Genuine Harley-Davidson H-D 360 Motorcycle Oil
    SAE 20W50
    HD 360
    Above 4 °C (39.2 °F)
    Good
    SAE 50
    HD 360
    Above 16 °C (60.8 °F)
    Poor
    SAE 60
    HD 360
    Above 27 °C (80.6 °F)
    Poor
    This is from the 2017 Freewheeler manual. For the new M8, the MOCO likes 20w-50
    I knew people would like my oil thread.
  10. #30
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    TYPE
    VISCOSITY
    RATING
    LOWEST AMBIENT
    TEMPERATURE
    50 °F (10 °C)
    SAE 20W50
    HD 360
    Excellent
    SAE 20W50
    HD 360
    Good
    SAE 50
    HD 360
    Poor
    SAE 60
    HD 360
    Poor
    Not sure how you're coming to the conclusion your stated.
    I am reading the chart you posted and seeing that if the lowest temp you ride in is above 60 and below 80, the recommended oil is SAE 50, and if the lowest temp you ride in is above 80, the recommended oil is SAE 60.
    The Excellent, Good, Poor ratings are referring only to "Cold Weather Starting" below 50.
    The reason the temps are there is that different weight oils are ideal for different temps....otherwise, why even have a chart...they would just say that 20W-50 is the recommended oil.
    www.DKCustom.com
  11. #31
    Oct 2017
    St. Louis, MO USA
    I live in a strange climate. It can be 25° 1 day & 75° the next day.
    100° in the summer & 0° in the winter.
    The more I looked at oil, the more confused I've become. The HD dealers around here recommend the Syn3 oil 20W50 in all 3 holes, with 1/2 reccomending a specěfic tranny & diff. fluid. It's hard to figure out what's best. Lucas Oil recommended to me in my climate, their full synthetic high performance 20W50 would be best. I am liking it so far.
  12. #32
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    If for an entire oil change (approx. 5000 miles) one cannot say that riding temps will always be above 60*, then the 20W-50 is what HD recommends as best.
    I have similar weather to what you have, but I'll do 4-5 oil changes a year when the temps are always above 60*. Sometimes a couple of oil changes where the temps are always above 80*.
    Can't imagine what it would be like in some of the areas in the Southwestern States!
    The viscosity of oil for riding conditions is pretty easy to figure out....BUT, WHICH oils to use, in which holes, can be a never ending quest to find what is "Best".
    I have tried more oils than I can count. I think all of the main line oils will provide adequate lubrication...but there are other things to consider, such as noise, smoothness, clutch engagement, how many miles before the viscosity modifiers start breaking down, etc.
    The subject is endless.
    I can't say I'll never try another oil...but it has been a couple of years since I quit "testing out" new oils.
    www.DKCustom.com
  13. #33
    Oct 2017
    St. Louis, MO USA
    Kevin, thanks for responding. I am curious to know,
    what oil/lube are you using in your 3 reservoirs?
  14. #34
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    In the Tri-Glide I use Redline Heavy Shockproof in the trans. Last couple of years been using Syn3 in the primary. Part of the year is Redline 20W-50 in the engine, rest of the year is Royal Purple 50W in the engine.
    I also use Petron Plus additives in the engine and trans.
    www.DKCustom.com
  15. #35
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    I have been running Lucas in the last 4 Harleys I have owned with zero issues 20/50 until now,i switched to Lucas straight 50 weight,I have a heated garage so cold starts are not an issue.I still use Bel Ray in the trans and HD primary oil.But will switch to Lucas primary oil this spring.
  16. #36
    Oct 2017
    St. Louis, MO USA
    I with you on the Lucas 20W50. I had an immediate improvement in shifting after installing it.
    I may go with their dedicated tranny & primary oil, the experience on here has convinced me.
  17. #37
    80+ Posts
    Cochise, AZ USA
    Default Oil Break down
    I like reading these posts on oil! I have been running nothing but full synthetics in all 3 hole since buying my 2000 FLHTC 2nd year of Twin Cam!
    I run the Synthetic because I read somewhere that Dino oil starts to break down fast at 270deg!
    These newer twin cams run hot! My old 2000 hit 270deg in the oil bag in Sturgis in 2015 fried the fuel line and it split Amsoil in all 3 holes engine still runs fine! It's still a twincam but all S&S gear drive; Billet Plate and Melling oil pump! Amsoil gear oil in trans and shifts smoother!
    DK has done a lot of heat research on the twin cam engine and I'm using most of his stuff on my 2015 Freewheeler. I have the remote oil filter and have not installed the 2nd oil cooler yet (it's been 25deg low 60's for high) don't freell the need to install till this summer!
    JMO I would never run anything but synthetic in a twin cam: They just run too Hot!
  18. #38
    IMO the M* runs just as hot if not a bit hotter
    The plus is they cool down quicker
    I think the metals in the M8 are a bit better to stand this heat
  19. #39
    Oct 2017
    St. Louis, MO USA
    +1! I totally agree.
  20. #40
    150+ Posts ragsflh's Avatar
    Feb 2018
    rush springs,ok usa
    Default oil
    run 20/50. live in okla where temps in summer are 100 plus.remember old days when i would run 70 weight kendahl oil in my knuckle.times have change.be cold out and that oil was like tar.new oil run thinner.my truck uses 5/20.hd going to recomend their oil.i run mobil 1.buy any parts store/walmart travel xcoss county.use what you want.
  1. Old vet just wants to talk
    By Oldveteran in forum Military & Veterans
    Last Post: 06-15-2017, 04:11 AM
  2. TV Talk
    By Papa Zook in forum General Discussion
    Last Post: 02-08-2013, 07:53 PM
  3. A GPS you can talk to
    By BlueTrinity in forum Accessories
    Last Post: 06-30-2009, 03:31 PM
