Likes Likes:  3
Thanks Thanks:  3
Results 1 to 5 of 5
Thread: 2019 Harley Trouble Code List
    Default 2019 Harley Trouble Code List
    2019 Harley-Davidson Trouble Codes, Check Engine Light
    Diagnostic Trouble Codes (DTCs) and Fault Conditions
    DTC PRIORITY
    ORDER
    FAULT CONDITION SOLUTION
    B1103 47 LHCM internal error SWITCH DIAGNOSTICS
    B1153 46 RHCM internal error SWITCH DIAGNOSTICS
    B1200 37 IM internal fault NO INSTRUMENT POWER DIAGNOSTICS
    B1210 176 Fuel level sender shorted low/open FUEL GAUGE AND SENDER DIAGNOSTICS
    B1211 182 Fuel level sender shorted high FUEL GAUGE AND SENDER DIAGNOSTICS
    B1212 175 Fuel signal low FUEL GAUGE AND SENDER DIAGNOSTICS
    B1213 176 Fuel signal high FUEL GAUGE AND SENDER DIAGNOSTICS
    B1300 340 Radio voltage high AUDIO VOLTAGE DIAGNOSTICS
    B1301 341 Radio voltage low AUDIO VOLTAGE DIAGNOSTICS
    B1302 342 Faceplate home button stuck FACEPLATE BUTTON DIAGNOSTICS
    B1303 343 Faceplate favorite button stuck FACEPLATE BUTTON DIAGNOSTICS
    B1304 344 Faceplate navigation button stuck FACEPLATE BUTTON DIAGNOSTICS
    B1305 345 Faceplate power/mute button stuck FACEPLATE BUTTON DIAGNOSTICS
    B1306 399 Rear hand controls shorted high REAR AUDIO CONTROL DIAGNOSTICS
    81307 400 Rear hand controls shorted low REAR AUDIO CONTROL DIAGNOSTICS
    81308 401 Rear volume up button stuck REAR AUDIO CONTROL DIAGNOSTICS
    B1309 402 Rear volume down button stuck REAR AUDIO CONTROL DIAGNOSTICS
    B1310 403 Rear mode button stuck REAR AUDIO CONTROL DIAGNOSTICS
    81311 404 Rear PTT button stuck REAR AUDIO CONTROL DIAGNOSTICS
    B1312 405 Rear tune up button stuck REAR AUDIO CONTROL DIAGNOSTICS
    B1313 406 Rear tune down button stuck REAR AUDIO CONTROL DIAGNOSTICS
    B1314 346 LHCM VR PTT button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1315 347 LHCM up button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1316 348 LHCM left button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1317 349 LHCM center button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1318 350 LHCM right button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1319 351 LHCM down button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1320 352 RHCM info button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1321 353 RHCM up button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1322 354 RHCM left button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1323 355 RHCM center button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1324 356 RHCM right button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1325 357 RHCM down button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1326 358 RHCM CB squelch up button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1327 359 RHCM CB PTT button stuck FRONT HAND CONTROLS DIAGNOSTICS
    B1328 360 RHCM CB squelch down button stuck FRONT HAND CONTROLS DIAGNOSTICS
    81329 361 Faceplate preset button 1 stuck FACEPLATE BUTTON DIAGNOSTICS
    B1330 362 Faceplate preset button 2 stuck FACEPLATE BUTTON DIAGNOSTICS
    B1331 363 Faceplate preset button 3 stuck FACEPLATE BUTTON DIAGNOSTICS
    B1332 364 Faceplate preset button 4 stuck FACEPLATE BUTTON DIAGNOSTICS
    81333 365 Faceplate preset button 5 stuck FACEPLATE BUTTON DIAGNOSTICS
    B1334 366 Faceplate preset button 6 stuck FACEPLATE BUTTON DIAGNOSTICS
    B1335 367 Faceplate preset button 7 stuck FACEPLATE BUTTON DIAGNOSTICS
    B1336 368 Faceplate preset button 8 stuck FACEPLATE BUTTON DIAGNOSTICS
    B1337 369 Front left speaker shorted together FRONT SPEAKER DIAGNOSTICS
    B1338 370 Front left speaker open FRONT SPEAKER DIAGNOSTICS
    B1339 371 Front left speaker shorted low FRONT SPEAKER DIAGNOSTICS
    B1340 372 Front left speaker shorted high FRONT SPEAKER DIAGNOSTICS
    B1341 373 Rear left speaker shorted together REAR SPEAKER DIAGNOSTICS
    B1342 374 Rear left speaker open REAR SPEAKER DIAGNOSTICS
    B1343 375 Rear left speaker shorted low REAR SPEAKER DIAGNOSTICS
    B1344 376 Rear left speaker shorted high REAR SPEAKER DIAGNOSTICS
    B1345 377 Front right speaker shorted together FRONT SPEAKER DIAGNOSTICS
    B1346 378 Front right speaker open FRONT SPEAKER DIAGNOSTICS
    B1347 379 Front right speaker shorted low FRONT SPEAKER DIAGNOSTICS
    B1348 380 Front right speaker shorted high FRONT SPEAKER DIAGNOSTICS
    B1349 381 Rear right speaker shorted together REAR SPEAKER DIAGNOSTICS
    B1350 382 Rear right speaker open REAR SPEAKER DIAGNOSTICS
    B1351 383 Rear right speaker shorted low REAR SPEAKER DIAGNOSTICS
    81352 384 Rear right speaker shorted high REAR SPEAKER DIAGNOSTICS
    B1353 385 Speaker output DC offset DTC B1353
    B1354 386 GPS antenna open SECURITY ANTENNA DIAGNOSTICS
    B1355 387 GPS antenna shorted low SECURITY ANTENNA DIAGNOSTICS
    B1356 388 SDARS antenna open SECURITY ANTENNA DIAGNOSTICS
    B1357 389 SDARS antenna shorted SECURITY ANTENNA DIAGNOSTICS
    B1358 390 Front left headset shorted high HEADSET DTCS
    B1359 391 Front right headset shorted high HEADSET DTCS
    B1360 392 Front left headset shorted low HEADSET DTCS
    B1361 393 Front right headset shorted low HEADSET DTCS
    B1362 394 Rear left headset shorted high HEADSET DTCS
    B1363 395 Rear right headset shorted high HEADSET DTCS
    B1364 396 Rear left headset shorted low HEADSET DTCS
    81365 397 Rear right headset shorted low HEADSET DTCS
    B1366 398 Internal thermal shutdown error DTC 81366
    B1367 451 WIM fault detected Code used to support P&A parts.
    B1401 407 Amp voltage low AUDIO VOLTAGE DIAGNOSTICS
    B1402 408 Amp voltage high AUDIO VOLTAGE DIAGNOSTICS
    81403 409 Speaker output DC offset AMPLIFIER 1 DTCS
    B1404 410 Internal thermal shutdown error AMPLIFIER 1 DTCS
    B1405 427 EQ correlation error AUDIO SYSTEM SYMPTOMS
    81406 428 Invalid or missing EQ AUDIO SYSTEM SYMPTOMS
    B1410 411 Channel 1 speaker open AMPLIFIER 1 DTCS
    B1411 412 Channel 1 speaker shorted low AMPLIFIER 1 DTCS
    B1412 413 Channel 1 speaker shorted high AMPLIFIER 1 DTCS
    B1413 414 Channel 1 speaker shorted together AMPLIFIER 1 DTCS
    B1420 415 Channel 2 speaker open AMPLIFIER 1 DTCS
    B1421 416 Channel 2 speaker shorted low AMPLIFIER 1 DTCS
    B1422 417 Channel 2 speaker shorted high AMPLIFIER 1 DTCS
    B1423 418 Channel 2 speaker shorted together AMPLIFIER 1 DTCS
    B1430 419 Channel 3 speaker open AMPLIFIER 1 DTCS
    B1431 420 Channel 3 speaker shorted low AMPLIFIER 1 DTCS
    B1432 421 Channel 3 speaker shorted high AMPLIFIER 1 DTCS
    81433 422 Channel 3 speaker shorted together AMPLIFIER 1 DTCS
    B1440 423 Channel 4 speaker open AMPLIFIER 1 DTCS
    B1441 424 Channel 4 speaker shorted low AMPLIFIER 1 DTCS
    B1442 425 Channel 4 speaker shorted high AMPLIFIER 1 DTCS
    B1443 426 Channel 4 speaker shorted together AMPLIFIER 1 DTCS
    B2102 4 System power output shorted high SYSTEM POWER CIRCUIT DIAGNOSTICS
    B2103 5 System power output shorted low SYSTEM POWER CIRCUIT DIAGNOSTICS
    B2104 6 System power output over- loaded SYSTEM POWER CIRCUIT DIAGNOSTICS
    B2106 257 L4 output open HEADLAMP DIAGNOSTICS
    B2107 225 L4 output shorted high HEADLAMP DIAGNOSTICS
    B2108 226 L4 output shorted low HEADLAMP DIAGNOSTICS
    B2109 227 L4 output overloaded HEADLAMP DIAGNOSTICS
    B2112 132 ACC output shorted high ACC CIRCUIT DIAGNOSTICS
    B2113 134 ACC output shorted low ACC CIRCUIT DIAGNOSTICS
    B2114 136 ACC output overloaded ACC CIRCUIT DIAGNOSTICS
    B2116 92 Fuel pump output open FUEL PUMP DIAGNOSTICS
    B2117 93 Fuel pump output shorted high FUEL PUMP DIAGNOSTICS
    B2118 94 Fuel pump output shorted low FUEL PUMP DIAGNOSTICS
    B2119 95 Fuel pump output overloaded FUEL PUMP DIAGNOSTICS
    B2121 58 Starter output open STARTER OUTPUT DTCS
    B2122 59 Starter output shorted high STARTER OUTPUT DTCS
    B2123 60 Starter output shorted low STARTER OUTPUT DTCS
    B2124 61 Starter output overloaded STARTER OUTPUT DTCS
    B2127 243 E4 output shorted high HORN DIAGNOSTICS
    B2128 244 E4 output shorted low HORN DIAGNOSTICS
    B2129 245 E4 output overloaded HORN DIAGNOSTICS
    B2131 233 High beam output open HEADLAMP DIAGNOSTICS
    B2132 234 High beam output shorted high HEADLAMP DIAGNOSTICS
    B2133 235 High beam output shorted low HEADLAMP DIAGNOSTICS
    B2134 236 High beam output overloaded HEADLAMP DIAGNOSTICS
    B2136 229 Low beam output open HEADLAMP DIAGNOSTICS
    B2137 230 Low beam output shorted high HEADLAMP DIAGNOSTICS
    B2138 231 Low beam output shorted low HEADLAMP DIAGNOSTICS
    B2139 232 Low beam output overloaded HEADLAMP DIAGNOSTICS
    B2141 207 Left front turn signal output open FRONT TURN SIGNAL DIAGNOSTICS
    B2143 214 Left front turn signal output shorted low FRONT TURN SIGNAL DIAGNOSTICS
    B2144 215 Left front turn signal output overloaded FRONT TURN SIGNAL DIAGNOSTICS
    B2146 216 Right front turn signal output open FRONT TURN SIGNAL DIAGNOSTICS
    B2148 217 Right front turn signal output shorted low FRONT TURN SIGNAL DIAGNOSTICS
    B2149 218 Right front turn signal output overloaded FRONT TURN SIGNAL DIAGNOSTICS
    82151 219 Left rear turn signal output open REAR TURN SIGNAL DIAGNOSTICS
    82153 220 Left rear turn signal output shorted low REAR TURN SIGNAL DIAGNOSTICS
    B2154 221 Left rear turn signal output overloaded REAR TURN SIGNAL DIAGNOSTICS
    B2156 222 Right rear turn signal output open REAR TURN SIGNAL DIAGNOSTICS
    B2158 223 Right rear turn signal output shorted low REAR TURN SIGNAL DIAGNOSTICS
    B2159 224 Right rear turn signal output overloaded REAR TURN SIGNAL DIAGNOSTICS
    B2161 198 Brake lamp output open STOP LAMP DIAGNOSTICS
    B2163 199 Brake lamp output shorted low STOP LAMP DIAGNOSTICS
    B2164 200 Brake lamp output overloaded STOP LAMP DIAGNOSTICS
    B2168 172 Running lights output shorted low RUNNING LAMP DIAGNOSTICS
    B2169 173 Running lights output over- loaded RUNNING LAMP DIAGNOSTICS
    B2172 237 H2 output shorted high ALARM DIAGNOSTICS
    B2173 238 H2 output shorted low ALARM DIAGNOSTICS
    82176 239 Security antenna output open SECURITY ANTENNA DIAGNOSTICS
    B2177 240 Security antenna output shorted high SECURITY ANTENNA DIAGNOSTICS
    B2178 241 Security antenna output shorted low SECURITY ANTENNA DIAGNOSTICS
    B2183 249 G2 output shorted low ADDITIONAL OUTPUT DIAGNOSTICS
    B2188 254 G3 output shorted low ADDITIONAL OUTPUT DIAGNOSTICS
    B2193 257 H4 output shorted low ADDITIONAL OUTPUT DIAGNOSTICS
    B2198 259 H3 output shorted low ADDITIONAL OUTPUT DIAGNOSTICS
    B2201 52 IGN switch off w/VSS IGN SWITCH DIAGNOSTICS
    B2202 53 Ignition switch accy with vehicle speed IGN SWITCH DIAGNOSTICS
    B2203 50 Ignition switch input shorted low IGN SWITCH DIAGNOSTICS
    B2206 51 Run/stop switch input open/shorted high ENGINE STOP SWITCH DIAGNOSTICS
    B2208 54 Run/stop switch input shorted low ENGINE STOP SWITCH DIAGNOSTICS
    B2210 55 Run/stop switch inputs both open SWITCH DIAGNOSTICS
    B2212 56 Run/stop switch inputs both closed SWITCH DIAGNOSTICS
    82218 131 Neutral switch shorted low NEUTRAL SWITCH DIAGNOSTICS
    B2223 197 Rear brake switch shorted low (light on) STOP LAMP DIAGNOSTICS
    B2226 247 BAS input open BCM not configured properly.
    B2228 250 BAS input shorted low BCM not configured properly.
    B2231 312 Fork locked w/VSS BCM not configured properly. This DTC should only apply to CVO models.
    B2232 313 Fork lock shorted high BCM not configured properly. This DTC should only apply to CVO models.
    B2233 314 Fork lock shorted low BCM not configured properly. This DTC should only apply to CVO models.
    B2234 315 Fork lock detected w/option disabled BCM not configured properly. This DTC should only apply to CVO models.
    B2235 316 Fork lock configuration invalid BCM not configured properly. This DTC should only apply to CVO models.
    B2250 128 Clutch switch stuck SWITCH DIAGNOSTICS
    B2251 242 Horn switch stuck SWITCH DIAGNOSTICS
    B2252 437 High beam switch stuck SWITCH DIAGNOSTICS
    B2253 228 FTP switch stuck SWITCH DIAGNOSTICS
    B2254 203 Left turn switch stuck SWITCH DIAGNOSTICS
    B2255 246 Trip switch stuck Trip Odometer Functions Inoperative, DTC 82255
    B2256 208 LHCM police siren power switch stuck BCM not configured properly. This DTC should only apply to Police models.
    B2257 209 LHCM police siren wail power switch stuck BCM not configured properly. This DTC should only apply to Police models.
    B2258 210 LHCM police siren yelp switch stuck BCM not configured properly. This DTC should only apply to Police models.
    B2260 57 Start switch stuck SWITCH DIAGNOSTICS
    B2261 204 Right turn switch stuck SWITCH DIAGNOSTICS
    B2262 196 Front brake switch stuck SWITCH DIAGNOSTICS
    B2263 202 Hazard switch stuck SWITCH DIAGNOSTICS
    B2264 211 RHCM police lights power switch stuck BCM not configured properly. This DTC should only apply to Police models.
    B2265 212 RHCM police lights front switch stuck BCM not configured properly. This DTC should only apply to Police models.
    B2266 213 RHCM police lights rear switch stuck BCM not configured properly. This DTC should only apply to Police models.
    B2270 27 BCM internal error SWITCH DIAGNOSTICS
    B2271 26 BCM voltage low BCM VOLTAGE DIAGNOSTICS
    B2272 33 BCM/IM voltage high BCM VOLTAGE DIAGNOSTICS
    B2274 49 Constant battery line error Odometer Self-Diagnostic Inoperative: DTC 00001, 00002, U0011, B2274
    C0562 38 ABS voltage low ABS VOLTAGE DIAGNOSTICS
    C0563 40 ABS voltage high ABS VOLTAGE DIAGNOSTICS
    C1014 183 ABS ECU relay error INTERNAL FAULT DIAGNOSTICS
    C1021 191 ABS front WSS always zero WSS DIAGNOSTICS
    C1023 192 ABS rear WSS always zero WSS DIAGNOSTICS
    C1025 194 ABS front wheel speed intermittent WSS DIAGNOSTICS
    C1027 195 ABS rear wheel speed intermittent WSS DIAGNOSTICS
    C1029 193 ABS wheel speed difference too high WSS DIAGNOSTICS
    C1032 189 ABS front wheel speed circuit open/shorted WSS DIAGNOSTICS
    C1034 190 ABS rear wheel speed circuit open/shorted WSS DIAGNOSTICS
    C1040 184 ABS pump/motor error INTERNAL FAULT DIAGNOSTICS
    C1055 39 ABS ECU internal error INTERNAL FAULT DIAGNOSTICS
    C1061 185 ABS front apply solenoid circuit open/high resistance INTERNAL FAULT DIAGNOSTICS
    C1062 187 ABS front release solenoid circuit open/high resistance INTERNAL FAULT DIAGNOSTICS
    C1065 186 ABS rear apply solenoid circuit open/high resistance INTERNAL FAULT DIAGNOSTICS
    C1066 188 ABS rear release solenoid circuit open/high resistance INTERNAL FAULT DIAGNOSTICS
    C1071 283 Rear prime valve error INTERNAL FAULT DIAGNOSTICS
    C1072 284 Rear isolation valve error INTERNAL FAULT DIAGNOSTICS
    C1073 285 Front isolation valve error INTERNAL FAULT DIAGNOSTICS
    C1074 286 Front prime valve error INTERNAL FAULT DIAGNOSTICS
    C1075 287 Front linked inlet valve error INTERNAL FAULT DIAGNOSTICS
    C1076 288 Front linked outlet valve error INTERNAL FAULT DIAGNOSTICS
    C1077 289 Front circuit pressure sensor error INTERNAL FAULT DIAGNOSTICS
    C1078 290 Rear circuit pressure sensor error INTERNAL FAULT DIAGNOSTICS
    C1081 291 Front master pressure sensor error INTERNAL FAULT DIAGNOSTICS
    C1082 292 Front master pressure sensor offset error INTERNAL FAULT DIAGNOSTICS
    C1083 293 Front wheel pressure sensor error INTERNAL FAULT DIAGNOSTICS
    C1084 294 Front wheel pressure sensor offset error INTERNAL FAULT DIAGNOSTICS
    C1085 295 Rear master pressure sensor error INTERNAL FAULT DIAGNOSTICS
    C1086 296 Rear master pressure sensor offset error INTERNAL FAULT DIAGNOSTICS
    C1087 297 Rear wheel pressure sensor error INTERNAL FAULT DIAGNOSTICS
    C1088 298 Rear wheel pressure sensor offset error INTERNAL FAULT DIAGNOSTICS
    C1089 299 Pressure sensor external supply error INTERNAL FAULT DIAGNOSTICS
    C1159 43 ABS invalid stored VIN INVALID VIN DIAGNOSTICS
    C1178 41 ABS no VIN received from ECM INVALID VIN DIAGNOSTICS
    C1184 42 ABS invalid VIN from ECM INVALID VIN DIAGNOSTICS
    C1195 266 Wake up error INTERNAL FAULT DIAGNOSTICS
    P0031 153 Front HO2S low/open HO2S DIAGNOSTICS
    P0032 156 Front HO2S shorted high HO2S DIAGNOSTICS
    P0051 154 Rear HO2S low/open HO2S DIAGNOSTICS
    P0052 155 Rear HO2S shorted high HO2S DIAGNOSTICS
    P0072 112 AAT sensor low AAT SENSOR DIAGNOSTICS
    P0073 113 AAT sensor high/open MT SENSOR DIAGNOSTICS
    P0107 100 MAP sensor failed low/open TMAP SENSOR DIAGNOSTICS
    P0108 101 MAP sensor failed high/open port TMAP SENSOR DIAGNOSTICS
    P0112 123 IAT sensor shorted low TMAP SENSOR DIAGNOSTICS
    P0113 125 IAT sensor high/open TMAP SENSOR DIAGNOSTICS
    P0117 102 ET sensor shorted low ET SENSOR DIAGNOSTICS
    P0118 107 ET sensor high/open ET SENSOR DIAGNOSTICS
    P0120 76 TPS 1 range error TCA DIAGNOSTICS
    P0122 74 TPS 1 low TCA DIAGNOSTICS
    P0123 75 TPS 1 high/open TCA DIAGNOSTICS
    P0131 157 02 sensor low/engine lean (front) HO2S DIAGNOSTICS
    P0132 159 Engine running rich (front) HO2S DIAGNOSTICS
    P0134 161 Oxygen sensor high/open (front) HO2S DIAGNOSTICS
    P0151 158 02 sensor low/engine lean (rear) HO2S DIAGNOSTICS
    P0152 160 Engine running rich (rear) HO2S DIAGNOSTICS
    P0154 162 02 sensor high/open (rear) HO2S DIAGNOSTICS
    P0220 79 TPS 2 range error TCA DIAGNOSTICS
    P0222 77 TPS 2 low/open TCA DIAGNOSTICS
    P0223 78 TPS 2 high TCA DIAGNOSTICS
    P0261 96 Fuel injector low/open (front) FUEL INJECTOR DIAGNOSTICS
    P0262 97 Fuel injector shorted high (front) FUEL INJECTOR DIAGNOSTICS
    P0264 98 Fuel injector low/open (rear) FUEL INJECTOR DIAGNOSTICS
    P0265 99 Fuel injector shorted high (rear) FUEL INJECTOR DIAGNOSTICS
    P0325 139 Knock sensor front open circuit KNOCK SENSOR DIAGNOSTICS
    P0327 140 Knock sensor front circuit low KNOCK SENSOR DIAGNOSTICS
    P0328 141 Knock sensor front circuit high KNOCK SENSOR DIAGNOSTICS
    P0330 142 Knock sensor rear open circuit KNOCK SENSOR DIAGNOSTICS
    P0332 143 Knock sensor rear circuit low KNOCK SENSOR DIAGNOSTICS
    P0333 144 Knock sensor rear circuit high KNOCK SENSOR DIAGNOSTICS
    P0371 65 CKP sensor wrong number of pulses CKP SENSOR DIAGNOSTICS
    P0374 64 CKP sensor no pulses CKP SENSOR DIAGNOSTICS
    P0444 147 Purge solenoid low/open PURGE SOLENOID DIAGNOSTICS
    P0445 148 Purge solenoid shorted high PURGE SOLENOID DIAGNOSTICS
    P0462 174 Fuel sender shorted low FUEL GAUGE AND SENDER DIAGNOSTICS
    P0463 175 Fuel sender shorted high/open FUEL GAUGE AND SENDER DIAGNOSTICS
    P0502 137 VSS failed low PURGE SOLENOID DIAGNOSTICS
    P0503 138 VSS failed high VSS DIAGNOSTICS
    P0505 148 Idle speed control - unstable IDLE SPEED CONTROL DIAGNOSTICS
    P0522 168 Engine oil pressure sensor/switch shorted low INDICATOR LAMPS
    P0523 169 Engine oil pressure sensor/switch shorted high/open INDICATOR LAMPS
    P0562 127 ECM voltage low BATTERY AND SYSTEM VOLTAGE DIAGNOSTICS
    P0572 202 Brake switch low BRAKE SWITCH DIAGNOSTICS
    P0577 163 Cruise control input error Cruise Control
    P0603 29 ECM EEPROM memory error ECM INTERNAL DIAGNOSTICS
    P0605 28 ECM FLASH memory error ECM INTERNAL DIAGNOSTICS
    P0641 62 5 Volt reference out of range 5V REFERENCE DIAGNOSTICS
    P0651 63 5 Volt reference 2 out of range 5V REFERENCE DIAGNOSTICS
    P0693 119 Chassis fan control circuit shorted low CHASSIS FAN DIAGNOSTICS
    P0694 120 Chassis fan control circuit shorted high CHASSIS FAN DIAGNOSTICS
    P1009 32 VTD disabled fuel due to bad password DTC P1009
    P1017 103 ET indicates overheating DTC P1017
    P1019 106 ECT difference (high temp) ECT SENSOR DIAGNOSTICS
    P1270 67 TGS 2 ND validation error DTC P1270
    P1501 166 JSS low JSS DIAGNOSTICS
    P1502 167 JSS high/open JSS DIAGNOSTICS
    P1505 445 Power limit violation HESITATION OR LOSS OF POWER
    P1510 447 ETC limited performance mode ETC MANAGEMENT DIAGNOSTICS
    P1511 448 ETC power management mode ETC MANAGEMENT DIAGNOSTICS
    P1512 449 ETC forced idle mode ETC MANAGEMENT DIAGNOSTICS
    P1514 87 ETC airflow error ETC ERROR DIAGNOSTICS
    P1600 66 ETC watchdog error ETC ERROR DIAGNOSTICS
    P1655 164 ACR solenoid low/open ACR Diagnostics
    P1656 165 ACR solenoid shorted high ACR Diagnostics
    P1691 115 Cooling fan left low/open COOLING FAN DIAGNOSTICS
    P1692 116 Cooling fan left shorted high COOLING FAN DIAGNOSTICS
    P1693 117 Cooling fan right low/open COOLING FAN DIAGNOSTICS
    P1694 118 Cooling fan right shorted high COOLING FAN DIAGNOSTICS
    P2100 82 ETC driver open circuit ETC ACTUATOR DIAGNOSTICS
    P2101 83 ETC actuation error ETC ACTUATOR DIAGNOSTICS
    P2102 84 ETC driver shorted low ETC ACTUATOR DIAGNOSTICS
    P2103 85 ETC driver shorted high ETC ACTUATOR DIAGNOSTICS
    P2105 446 ETC forced shutdown mode DTC P2105, P2107
    P2107 68 ETC driver internal error DTC P2105, P2107
    P2119 81 ETC actuator return error DTC P2119
    P2122 69 TGS 1 low/open TGS DIAGNOSTICS
    P2123 70 TGS 1 high TGS DIAGNOSTICS
    P2127 71 TGS 2 low/open TGS DIAGNOSTICS
    P2128 72 TGS 2 high TGS DIAGNOSTICS
    P2135 80 TPS correlation error CORRELATION ERROR DIAGNOSTICS
    P2138 73 TGS correlation error CORRELATION ERROR DIAGNOSTICS
    P2176 86 ETC zero position learning error DTC P2176
    P2184 121 ECT sensor low ECT SENSOR DIAGNOSTICS
    P2185 122 ECT sensor high ECT SENSOR DIAGNOSTICS
    P2300 88 Ignition coil driver low/open (front) IGN COIL DRIVER DIAGNOSTICS
    P2301 89 Ignition coil driver shorted high (front) IGN COIL DRIVER DIAGNOSTICS
    P2303 90 Ignition coil driver low/open (rear) IGN COIL DRIVER DIAGNOSTICS
    P2304 91 Ignition coil driver shorted high (rear) IGN COIL DRIVER DIAGNOSTICS
    P2602 104 Coolant pump “A” control circuit low COOLING PUMP DIAGNOSTICS
    P2603 105 Coolant pump “A” control circuit high COOLING PUMP DIAGNOSTICS
    U0001 1 CAN BUS error Odometer Self-Diagnostic Inoperative: DTC 00001, 00002, U0011, B2274
    U0002 16 CAN comm bus perf error Odometer Self-Diagnostic Inoperative: DTC 00001, 00002, U0011, 82274
    U0003 13 Network management monitoring NO VEHICLE POWER OR LOST COMMUNICATION DTCS
    U0011 2 CAN bus low shorted to CAN bus high Odometer Self-Diagnostic Inoperative: DTC 00001, 00002, 00011, B2274
    U0100 7 Lost comm w/ECM NO VEHICLE POWER OR LOST COMMUNICATION DTCS
    U0121 11 Lost comm w/ABS NO VEHICLE POWER OR LOST COMMUNICATION DTCS
    U0140 3 Lost comm w/BCM NO VEHICLE POWER OR LOST COMMUNICATION DTCS
    U0141 9 Lost comm w/LHCM NO VEHICLE POWER OR LOST COMMUNICATION DTCS
    U0142 8 Lost comm w/RHCM NO VEHICLE POWER OR LOST COMMUNICATION DTCS
    U0156 10 Lost comm w/speedo NO VEHICLE POWER OR LOST COMMUNICATION DTCS
    U0158 180 Lost comm w/fuel gauge SECONDARY COMMUNICATION DIAGNOSTICS
    U0159 181 Lost comm w/volt gauge SECONDARY COMMUNICATION DIAGNOSTICS
    U0160 179 Lost comm w/fuel and volt gauges SECONDARY COMMUNICATION DIAGNOSTICS
    U0184 323 Lost comm w/radio NO VEHICLE POWER OR LOST COMMUNICATION DTCS
    U0185 325 Lost comm w/AMP 1 AMP COMMUNICATION DIAGNOSTICS
    U0186 326 Lost comm w/AMP 2 AMP COMMUNICATION DIAGNOSTICS
    U0187 20 Lost comm w/AMP 3 AMP COMMUNICATION DIAGNOSTICS
    U0188 21 Lost comm w/AMP 4 AMP COMMUNICATION DIAGNOSTICS
    U0300 15 Internal control module software incompatibility NO VEHICLE POWER OR LOST COMMUNICATION DTCS
    U1302 324 ACC bus pert error SECONDARY COMMUNICATION DIAGNOSTICS
    U1401 331 Lost comm w/CB SECONDARY COMMUNICATION DIAGNOSTICS
    U1405 450 ACC bus lost comm w/ WIM
    Dang ... Is it me to does the list just keep on growing ....
    New electronics New Trouble Codes
    It will only get worse IMO
    Alan, can you move this to Sticky?
    I don't seem to have the "Power" to do that .... or at the very least ... the knowledge ... I'm sure Randy will do it soon.
    Jun 2008
    Lovington, NM, U.S.A.
    OMG! I'm glad to be retired from motorcycle repair. I miss the good old stuff you can fix yourself.
    Retired trike builder
  1. Harley trouble codes
    By Jack Klarich in forum General Harley Chat
    Last Post: 04-11-2024, 11:48 AM
  2. 2019 Harley Triglide Hydraulic Clutch Problems
    By Puckmeister in forum Harley Tri Glide
    Last Post: 07-09-2019, 04:50 PM
  3. Trouble finding list of DTC's
    By grandpawj in forum General Discussion
    Last Post: 06-20-2019, 09:02 AM
  4. 2019 Harley Tri Glide Price
    By Totosdad in forum Harley Tri Glide
    Last Post: 10-29-2018, 07:51 AM
  5. Friend's List
    By Angelbymyside in forum General Discussion
    Last Post: 02-17-2009, 03:29 PM
