LD-Ordie2Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11Jack KlarichNew Member Introduct...New member from FL
ADSavarese11woodyNew Member Introduct...New member from FL
LD-Ordie2LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11hardwickbvNew Member Introduct...New member from FL
ADSavarese11ol' schoolNew Member Introduct...New member from FL
ADSavarese11GorillaNew Member Introduct...New member from FL
ADSavarese11Marc HNew Member Introduct...New member from FL
ADSavarese11ADSavareseNew Member Introduct...New member from FL
ADSavarese11Phu CatNew Member Introduct...New member from FL
ADSavarese11trike ladyNew Member Introduct...New member from FL
ADSavarese11Uncle FesterNew Member Introduct...New member from FL
ADSavarese11rhino 2New Member Introduct...New member from FL
Results 1 to 4 of 4
Thread: 2011 SE5 seat lift cylinder
    950+ Posts
    Jun 2013
    DFW, Texas
    Default 2011 SE5 seat lift cylinder
    FYI: Mine quit, Didn't want to wait for dealers to order. Replaced with Stabilus P/N SG359010 from PEP Boys. Works perfectly and was less expensive than OEM from dealers and what I could find on line.
    Should have added that the P/N given above will replace CanAm P/N 708000479
    Oct 2010
    USA
    do you think it can handle a heavier seat than stock?
    950+ Posts
    Jun 2013
    DFW, Texas
    Possibly, but I found several units in the same barrel size, length, and hole size which varied in their resistance to being pushed down. I chose one which lifted the seat quickly, but could be pushed back down easily also. Since they are easy to install, you could try different pressures to find one suitable.
    Oct 2010
    USA
    Quote Originally Posted by 2006gold View Post
  1. installed DK Lift kit and tank lift
    By uppercaseJC in forum Harley Trike Conversions
    Last Post: 10-25-2015, 12:35 AM
  2. HD mistake fix - Seat Mod For undersized seat bolt & loose seat tab on Freewheeler
    Last Post: 06-14-2015, 04:58 PM
  3. cylinder heads
    By matman1972 in forum VW Powered Trikes
    Last Post: 01-24-2015, 10:16 AM
  4. 2011 FLHXXX Street Glide Seat
    By azmerm in forum Harley Tri Glide
    Last Post: 10-18-2011, 09:55 PM
