ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Likes Likes:  2
Results 1 to 8 of 8
Thread: Aluma MCTXL wiring question.
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    Default Aluma MCTXL wiring question.
    My used 2013 Aluma MCTXL came with a flat 4. Lights "worked" but not as designed by Aluma. I will be using a flat 5 (Aluma uses the round 5 from the factory). The trailer has 6 wires: Red, Green, yellow, brown, white and black. According to Aluma the plug is as follows. (see bottom left of diagram )
    Red=brake
    Green=right turn
    yellow=left turn
    brown=running
    white=ground.
    How ever when I look at the plug diagram directly above it shows black as ground and does not mention the white wire. Then the wire diagram dose not mention black. Can someone make this simple for me?
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
    800+ Posts Motorcycle Mike's Avatar
    Jul 2014
    Lawrenceville, Ga
    Black is ground on my MXT. Everything else is as stated.
    However, I have a sixth blue wire. No idea what it's for.
    You don't quit riding because you get old.
    You get old because you quit riding.
    Mike & Shirley
    I'd love to help ... but me and tricity don't get along ... unless you're looking for burnt screwdriver tips ....
    I call it accidental welding ...
    Jul 2010
    Minnesota
    Quote Originally Posted by Motorcycle Mike View Post
    Thanks Mike. I've sent an e-mail to Aluma customer service. Hopefully they will get back with me Monday morning.
    BKMNI
    2015 Harley FLRT
    Quote Originally Posted by Keystone View Post
    Red=brake
    Green=right turn
    yellow=left turn
    brown=running
    white=ground.
    Since you are getting "professional" help ... my timeout is wired like you show.
    1250+ Posts jaxbobg's Avatar
    Nov 2011
    Jacksonville Beach
    Okay, okay, don't give me grief, but take a look at this thread on a different forum.
    http://gl1800riders.com/forums/showt...agram-Question
    Jul 2010
    Minnesota
    Quote Originally Posted by jaxbobg View Post
    I had actually read that prior to posting my question. It pretty much repeats what I have said. Guess I'll just have to wait to hear from Aluma....
    BKMNI
    2015 Harley FLRT
    Jul 2010
    Minnesota
    And the answer is: "You are correct on what each color is used for. The black would be unused. The wiring harness manufacture uses a 6 wire cable to make this harness for us so there is an unused wire."
    BKMNI
    2015 Harley FLRT
  1. Question regarding trunk wiring / GL1800
    By rmrc51 in forum Honda Trikes
    Last Post: 06-05-2013, 12:10 PM
  2. CSC trike kit wiring question
    By Folksinger in forum Honda Trikes
    Last Post: 05-01-2013, 09:03 AM
  3. Have Voyager trailer wiring question
    By krazybob in forum Outrigger Style Trikes
    Last Post: 05-02-2012, 09:34 AM
  4. trailer wiring question
    By Southern Man in forum Trailers / Campers
    Last Post: 05-24-2011, 08:54 PM
