Likes Likes:  2
Results 1 to 6 of 6
Thread: where's fuel pump ht1500 r/m trike
    750+ Posts
    May 2011
    peru,in,usa
    Default where's fuel pump ht1500 r/m trike
    got a '93 1500I, want to wire the fuel pump back to original cofiguration.but where's the f/p located. got the diagram from r/s web site. thanks lb
  2. Roadsmith banner
  3. #2
    30+ Posts T-Cat's Avatar
    Feb 2018
    MIDLOTHIAN, TX 76065
    Quote Originally Posted by eagle1 View Post
    Check this link - I think it will provide the info you need.
    http://www.berrysweb.com/1500_fuel_pump.htm
    Retired & Time to Ride
    Tom H - aka T-Cat
    2002 Silver GL1800A
    2003 Silver Bushtec Quantum GL trailer
    2007 Black Nomad 1600 - Totaled May 2018
  4. #3
    750+ Posts
    May 2011
    peru,in,usa
    Default aux fuel pump
    sorry i wanted to know where the aux tank fuel pump is on the 9 gal roadsmith trike
  5. #4
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Look underneath the trike and locate the fuel line coming out of the bottom right side of the aux fuel tank. Trace the fuel line forward and you will find a small, inline, cylindrical fuel pump mounted to the frame.
    Also, click on the link below for the Roadsmith GL1500 installation instructions PDF which contains pictures and an auxiliary fuel tank kit diagram # A-100-878-D which you will find by scrolling to the very last page of the PDF.
    Hope this helps.
    PZ
    Roadsmith GL1500 Installation Instructions
  6. #5
    Sep 2016
    Springfield, Mass. USA
    Aaaaaaaaaaaaaaa man "you rock", thank you! I also wanted to know, so now I also know... thank you!
    750+ Posts
    May 2011
    peru,in,usa
    Default closed thread
    sitting on the trike, remove the right rear tire. look under and aft of the aux tank. there it is..
  1. Electric fuel pump pressure
    By Doug D. in forum VW Powered Trikes
    Last Post: 04-21-2017, 08:09 PM
  2. Fuel pump help
    By Nighttrain in forum VW Powered Trikes
    Last Post: 09-06-2016, 10:29 PM
  3. fuel pump
    By samsonone1 in forum Honda Trikes
    Last Post: 06-06-2013, 11:52 AM
  4. Fuel Pump
    By bigjoey38 in forum VW Powered Trikes
    Last Post: 06-12-2012, 12:55 PM
  5. Ok,Gravity or electric fuel pump?
    By warnerrd in forum VW Powered Trikes
    Last Post: 10-15-2010, 10:46 PM
