Likes Likes:  14
Thanks Thanks:  2
Page 2 of 2 FirstFirst 1 2
Results 21 to 22 of 22
Thread: Trans & primary oils
  1. #21
    Just as a tip, I use a poly "cutting board to put under the filter ... I trimmed it to fit under and up the sides of the filter, piece of blue painters tape to hold it, do the punch a hole thing, let it drain into my Harley oil drain pan while doing the three drain plugs. The thing I like about the Harley drain pan ... it's got enough area to catch oil so you can do it all at once if you choose. It also holds everything in all three holes.
    After everything drains and I put the drain plugs back in, I un tape the filter, pull the filter off and slide the plastic out. Did all three holes in my garage today and didn't get a drop on the floor, went through 10 mechanics rags cleaning the drain plugs, putting the funnel in and out, etc. I put them in a pool chemical bucket with a cap of tri sodium phosphate and warm water for 30 minutes, rinse them and let them dry. Ready for the next maintenance.
    As a side note ... one of my upcoming mods will probably be the oil filter relocation kit from DK ... I'm old enough now that I deserve things that make my life easier. Probably do that next oil change.
  2. #22
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Might as well do the Jagg Oil Cooler with the oil filter relocation. You won't regret it!
    Be Safe
    Nuc
  1. Cooling fans for oils cooler
    By Bluz1953 in forum Harley Tri Glide
    Last Post: 03-08-2019, 07:22 PM
  2. Oil from trans to primary......
    By rhino 2 in forum Harley Tri Glide
    Last Post: 07-27-2018, 05:43 PM
  3. 180+ Motor Oils tested for Wear Protection
    By JIMSFLH in forum Harley Trike Conversions
    Last Post: 05-25-2016, 08:17 AM
  4. Oils
    By drumdoctor in forum VW Powered Trikes
    Last Post: 06-02-2011, 08:23 PM
  5. 1996 FLHT Trans pulley...
    By Sideshow Bob in forum Harley Trike Conversions
    Last Post: 07-22-2010, 11:04 PM
