Likes Likes:  1
Results 1 to 19 of 19
Thread: Brake rotor?
    20+ Posts
    May 2017
    Newburgh, IN 47630
    Default Brake rotor?
    What is the acceptable run out for a brake rotor? OK, I rechecked my numbers and the run out on my left rotor is 0.16 and the right rotor is 0.05. This is with the rotors on the bike and a dial indicator clamped to the bike.
  2. Roadsmith banner
  3. #2
    I'm not sure of the rotor specs, but, I'd think both are out of spec. 0.160" and 0.050" is a lot in my humble opinion ... I would suspect to see like 0.006" max.
    Disclaimer: my numbers would be on a test bench or rotor lathe, not just jacking up the trike and spinning the hub and rotor. lots of other possible "plays" in the later.
  4. #3
    20+ Posts
    May 2017
    Newburgh, IN 47630
    I need to recheck my numbers I may be off.
  5. #4
    20+ Posts
    May 2017
    Newburgh, IN 47630
    Back to the drawing board I need to recheck my numbers.
  6. #5
    10+ Posts oolddog's Avatar
    Apr 2013
    Hickory Withe, TN USA
    Default Where can you get the Roadsmith rotors turned?
    Quote Originally Posted by old willie View Post
    I have a 2012 Goldwing with 2013 ROADSMITH HCS trike kit. I have been unable to find a shop anywhere in Memphis, TN that has the capability to turn the rotors. They all told me that they must be turned "on the vehicle" and they had no way to handle a trike. I even went to the VW dealer and talked to the shop service foreman. Same story.
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    Have you compared price of new rotors versus turning old rotors?
    Oct 2010
    I’m in Jackson Tn. Lots of tire and brake repair shops with lathe machine for turning rotors. Do you have a odd design that makes it difficult to turn. Not familiar with RS Trikes.
    Apr 2013
    Default New Rotors and pads cost
    Quote Originally Posted by trikeman View Post
    At 29,500 miles I replaced the rotors & pads. Got them from ROADSMITH. $384.13! I'll just drive it and try tp enjoy the surges as I stop. I have 61,000+ on it now.
  10. Roadsmith banner
  11. #9
    Oct 2010
    • shock:
    Are they silver and gold plated?
  12. #10
    Quote Originally Posted by oolddog View Post
    You are going to find it harder to find a tech willing to turn rotors for a bike
    There are TOO many variables with run out to take a job like this
    IMO, and I have turned a few bike rotors, it just aint worth it now days, not to mention the liability factor
    If you have TOO much run out already you are on the losing end, replace the rotors and be safe and happy
    one IMO way to correct the warped rotor is surface grind them, how ever this could cost as much as new rotors, never mind the run out, stacked tolerances and minimum machine to spec These are JMO I aint trying to scare any one, brakes are serious business, it does not matter what you ride you best be able to stop safely
  13. #11
    Apr 2013
    Default I agree.....
    Thanks for the reply!
  14. #12
    Apr 2013
    Default Precious metals....
    • shock:
    LOLOL! They should of been!!
  15. #13
    Sep 2012
    Lakeland, FL
    I had the same problem, mine warped out of specs, so little it could not be measured to determine which one it was, I knew it was the left, but no way to prove it. No one in my world to turn the rotors, so had to bite the silver bullet and pay up, it was painful, but the slow/stop surge was getting awful, driving me nuts. Gentlemen, that's the price we pay.
  16. Roadsmith banner
  17. #14
    Mar 2011
    mountain home,ar. USA
    I have same problem. Wish Roadsmith would design and use a modern braking system. I am living with mine for now.
  18. #15
    20+ Posts
    May 2017
    Newburgh, IN 47630
    I pulled mine and took them to a local machine shop. they turned them and now I stop nice and smooth. These rotors are not like bike rotors and they can be turned. I confirmed this with Roadsmith.
  19. #16
    May 2011
    San Angelo
    I believe the key to getting these rotors trued it finding a shop willing to try. At the very worst they fail and you lost some time trying to save rather than replace them.
    Both of my discs warped and I called all the "PROS" in town that were suppose to be so great. Got a whole lot of "NO we can't do those". One of the guys at Advanced Auto told me about an old gentleman to go see. Sure enough, he had an old lathe with all sorts of adapters. $10 per disc and smooth as glass!!!
    This same gentleman has since done all four wheels on my 1974 Charger SE Brougham I've been restoring for a couple years now.
    2015 GL1800/Roadsmith HTS1800
  20. #17
    Sep 2012
    Lakeland, FL
    Holy Christmas, wish this old school guy had been in Florida, somewhere, anywhere, I'd have been on his door step.
  21. #18
    Any rotor can be turned, the questions are are you checking and duplicating rotor runout before and after?
    If not you will end up with a problem for sure.
    Also, be very careful to index the rear rotors ( clean ALL mating surfaces including the hat area to the hub) If you do not your run out will continue to be stacked and not correct. This will lead to a good looking rotor, BUT the run out will cause vibration, noise and rapid wear of the pads. JMO from years of brake work and teaching brakes 101
  22. #19
    Apr 2023
    Mentor Ohio USA
    Default Turning rotors
    Most machine shops won’t touch rotors. Too hard. I’ve had mine resurfaced on a flywheel grinder. It worked great so long as you stay in spec on thickness. Just my opinion.
  1. Roadsmith HDT Brake rotor
    By tinker in forum Roadsmith Trikes
    Owners Forum
    Last Post: 04-03-2023, 01:23 PM
  2. After market rear brake rotor
    By vettriker68 in forum Harley Trike Conversions
    Last Post: 09-01-2016, 11:11 AM
  3. CSC cobra rear brake rotor
    By turboman1354 in forum Honda Trikes
    Last Post: 11-14-2014, 06:49 PM
  4. Rear brake rotor
    By GARYD in forum Harley Trike Conversions
    Last Post: 10-16-2012, 06:48 PM
  5. warped front brake rotor---not happy with HDMC
    By pcmikey in forum Harley Tri Glide
    Last Post: 10-16-2011, 06:15 AM
