Sunman5rhino 2Honda TrikesF1 Warning Light
Papa Zook1Papa ZookHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
Bonsai4rhino 2New Member Introduct...New member from Texas
Bonsai4GorillaNew Member Introduct...New member from Texas
Rawhideken1714TGHarley Tri Glide2024 Tri glide
kj5ix32trike ladyHonda TrikesMotor Trike Service Manual Finished
Bonsai4trike ladyNew Member Introduct...New member from Texas
Bonsai4BonsaiNew Member Introduct...New member from Texas
Sunman5BowdenTrikeHonda TrikesF1 Warning Light
LD-Ordie10Marc HNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain4rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie10ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain4Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn5rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn5dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie10ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie10trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie10SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
LD-Ordie10Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17LD-OrdieHarley Tri Glide2024 Tri glide
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie10LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn5nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
kj5ix32ADSavareseHonda TrikesMotor Trike Service Manual Finished
ADSavarese13rhino 2New Member Introduct...New member from FL
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
Gorilla2Jack KlarichEnabled TrikersFull length floorboards
DrCrazyTrain4powerhaulicHarley Freewheeler /...True Dual Header
DrCrazyTrain4DrCrazyTrainHarley Freewheeler /...True Dual Header
Likes Likes:  4
Thanks Thanks:  1
Results 1 to 17 of 17
Thread: Slingshot stuff......
    Default Slingshot stuff......
    To answer a few questions that i was asked .......
    Once you get in it its like driving a sports car....Ride comfort the stock shocks are like Pogo sticks, hard pogo sticks, I 86th the stock shocks and add adjustable coil-over shocks......After a few thousand miles and slowly adjusting them the ride is acceptable.
    Storage theres a compartment [Locking] behind each seat....Which is enough for me i ride solo...Getting in and of it out is a little tricky ...But i have the roof so i can grab the cross bar and Sky hook my way out....I'm 5'11 and 185 + -....So far the only service i've had to do in almost 10k was to change the oil......Its a GM engine just like changing oil in a car...Oil filter on top drain plug on the bottom...Clean and simple...
    MPG...28/31....[10Gal tank]....
    Traction, If you get on it hard from a stop you'll smoke the rear tire off...Once rolling it will accelerate fast enough to get you in trouble real fast...
    Also Slingshot dealers are few and far between, At least in my neck of the woods...Mine is 80 miles one way.....There was one about 20 miles from me but he stoped selling Slingshots....He said he couldn't sell enough in the winter to justify the space they took up in his showroom and service area ....His main business is Indian and ATV's...
    Sep 2012
    Lakeland, FL
    Good response, what type of fuel? A tad bumpy, like most three wheelers, doesn't miss many bumps in the road.
    They recommend 91........I use 93...
    Meme Master
    Jan 2014
    Farmington, NH USA
    Will Chevy/GM Dealership do any engine warranty work on it, if needed?
    Im gonna say no......The engine is warranty by Polaris only....They 'Polaris just buys the engine .....
    Oct 2010
    USA
    How is the Slingshot handle in the rain? Does the cockpit get sprayed on from the wheels?
    No spray from the wheels.......I have the Slingshade [Roof] and water will come in over the windshield, But at speeds over 35, The rain will go over the top and out the back...
    But your still going to get wet....As far as rain you have to be easy on the gas petal , No heavy foot inputs , If you do lose traction the traction control will kick in immediately ..My Tri- Glides were better in the rain because you can't spin the rear wheels like you can with the one wheel and 175 HP that the Slingshot has...
    Oct 2010
    USA
    Stickyer tire help any or lower the tire pressure?
    I figure you still get wet but being close to the wheel was wondering if the water was sheaded away from the driver and passenger
    You could use glue and it wouldn't help...My stock rear tire is 255/30/20....Any lower air pressure ..[I run 28] and you'll almost be running on the rim..Polaris missed the boat when they didn't make it front wheel drive...That would have helped in the traction department , And also eliminated the belt drive and the angle drive crap back there..
    With the roof you get wet..[Ask anyone who has a convertible and what happens if they get caught in the rain with the top down].....Without a roof you'll get soaked.....But not to worry the interior is water proof....The seats are porous the water runs through them and they dry quickly...
    Just to add.....Would i get another Slingshot...No.....
    But not not because i don't like it.....Back in 08 I bought a new 08 Spyder [I still had two two wheelers] But that was my way of easing away riding two wheelers exclusively' With my first Tri-Glide [2011] i sold one bike, With my 2017 Tri-GlIde , The last bike and the 2011Tri-Glide Went.......After the Sling is gone, Who knows.....Corvette' Mustang GT or a Fiat Spider..........
    Oct 2010
    USA
    Maybe a VAnderhall in your future?
    Still have to get my ass to the dealer someday to test ride a Slingshot..
    But I better stay away too
    The problem with Vanderhall is a lack of dealerships 😱
    Oct 2010
    USA
    OK Back to Slingshot
    Is it true a automatic Slingshot is in store for 2020? Or Semi Auto?
    That seems to be right, Im on a Slingshot forum and thats the scuttlebutt going around.....And if so that will increase sales ....
    Oct 2010
    USA
    When do they announce the next models year
    I don't really know, But its got to be soon.......
  1. Any recent Slingshot recall news?
    By jaxbobg in forum Polaris Slingshot Trikes
    Last Post: 06-07-2015, 04:14 AM
  2. no slingshot for me
    By Jonesy in forum General Discussion
    Last Post: 06-03-2015, 11:13 PM
  3. Good Slingshot write up
    By Carbon_One in forum Polaris Slingshot Trikes
    Last Post: 01-13-2015, 09:55 PM
  4. Slingshot trikes
    Last Post: 01-13-2015, 08:00 PM
  5. SLINGSHOT by Polaris
    By seabiz in forum Polaris Slingshot Trikes
    Last Post: 01-10-2015, 09:33 PM
