Likes Likes:  9
Thanks Thanks:  1
Results 1 to 12 of 12
Thread: reverse motor out again
    Dec 2013
    enola pennsylvania
    Default reverse motor out again
    2011 tri glide replaced reverse 2yrs ago motor out again it was lightly used looking for options
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    Small local Indy shop removed, rebuilt and re-installed mine last month for less than $250.
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
    Jack....You could have it rebuilt ....Or have a mechanical reverse put in...I Had an 11 Tri-Glide and i used reverse a lot ...And i got tired if monkeying with it.. 3 times...Once i put the mechanical in i found out there wasn't any parking spot where i couldn't back out of, Just like i could in a car i could park nose in down hill ,in gravel , grass , and back out of..
    600+ Posts ISP-FL's Avatar
    Mar 2017
    Lake Suzy, FL USA
    My buddy from Paducah had his 2014 rebuilt a couple years ago for around $60.00. I forget where he said he had to ship it to for the exchange. He said it was very easy to change out.
    Current: 2019 Trike (custom 130ci T-Man kit with Darkhorse bottom end)
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by oilman jack View Post
    Have you troubleshoot it & verified the actual problem ? Start with checking the breaker, then all connections.
    Oct 2017
    St. Louis, MO USA
    Make sure this is for your model/year trike. I'm seeing an 09 & 09A
    https://www.ebay.com/p/Harley-Davids...d4ca4ffff6145b
    Hi Jack, have a look and read here
    https://alternatorstarterrebuildkits...tor-83388-09a/
    200+ Posts
    Nov 2016
    groesbeck texas usa
    had mine go out on my 2016 and got tired of trouble shooting. Called Papa Zook at Cut-N-Shoot Customs in Conroe Texas, ordered a Champion reverse installed it and know I don't worry about are you going to back up or not. Give him a shout and he treats us members real good
    Oct 2017
    St. Louis, MO USA
    Hey Jack, do you know what the revision on this motor is & or what the difference between 09 & 09A in the p/n?
    Also, are they the same for the Tri-Glide & Freewheeler?
  11. #10
    Hey Jack, do you know what the revision on this motor is & or what the difference between 09 & 09A?
    Not a clue on the part number change Up til recently HD replaced the reverse motors, now the techs are rebuilding them in house
    The trikes share a common reverse motor
  12. #11
    Oct 2017
    St. Louis, MO USA
    To make matters more confusing, their is a 09B also, but it says it's superseded.
  13. #12
    Michael, there is another updated part number for this motor that ends with a B suffix
    The replacement motors now have a vent hose much like import starters do This keeps moisture out of the starter and helps internal heat ( bad JU JU) to escape
  1. TG Reverse motor went out at 21,000 miles!
    By Rooster57 in forum Harley Tri Glide
    Last Post: 05-09-2021, 06:54 PM
  2. Motor Trike mechanical reverse lock-out
    By RoadKingTrike in forum Harley Trike Conversions
    Last Post: 05-30-2016, 07:00 PM
  3. Again THINKING out loud !
    By Rollin Thunder in forum General Discussion
    Last Post: 03-28-2016, 07:12 PM
  4. Reverse Or No Reverse?
    By GETRDONE in forum Harley Trike Conversions
    Last Post: 09-05-2015, 07:37 PM
  5. Never Run out ot Gas Again
    By mgwtrike in forum Honda Trikes
    Last Post: 02-18-2015, 09:25 PM
