Likes Likes:  2
Results 1 to 7 of 7
Thread: Auxilliary Fuel Tank Venting - Yamaha RSV with Hannigan Conversion
    1500+ Posts leo3wheel's Avatar
    Aug 2011
    Cranford, NJ, USA
    Default Auxilliary Fuel Tank Venting - Yamaha RSV with Hannigan Conversion
    Looking for some help understanding the venting of the auxiliary fuel tank on a Hannigan conversion. If I fill the auxiliary fuel tank on a hot day, gas expands and spills near right, rear wheel. Noticed today that filler pipe attaches to neck of tank with a radiator type hose. Upper band clamp was hand tight, and this is where fuel leaks. Bottom band clamp is very tight. Tightened the upper clamp today to stop the leaks, but now concerned about where fuel will expand since I removed this outlet. Is there some other venting. Does anyone know? Thanks!
    Leo TOI #617
    (Jeannette)
    09 RSV Black on Red with Hannigan trike conversion
    Aug 2011
    Cranford, NJ, USA
    Going to loosen up the top band clamp. Believe Hannigan meant it to be a release valve.
    Leo TOI #617
    (Jeannette)
    May 2018
    Angleton, Texas
    Quote Originally Posted by leo3wheel View Post
    Have you inspected for a release vent in the fuel cap area?
    Aug 2011
    Cranford, NJ, USA
    Looks like a solid chrome cap.
    Leo TOI #617
    (Jeannette)
    750+ Posts
    Jan 2010
    east windsor ct
    i dont believe for a second anyone would use a loose clamp as a vent... why not contact hannigan??
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    Hi Leo sorry to hear you are having trouble. I would contact Hannigan and ask them how they vent that tank or if you are supposed to leave some head space. You have had that trike awhile, are you just now having trouble?
    Happy TRAils/NSD
    Paul
    Aug 2011
    Cranford, NJ, USA
    Hi Paul, Had our trike 10 years. Full auxilliary tank overflowing has been an issue since beginning. Recently changed rear brake pads and was watching for leaks. Well, weather has been super hot, so auxilliary tank overflowed. Took rear tire off to make sure bleeder was dry. While there, could see signs of gas leaking at filler tube. Tried to tightenen clamps, and found upper clamp was very loose. Tightened clamp and put wheel back on. Then wondered if I did the right thing. Don't want to introduce problems, especially since I'm going on a long trip this weekend. Worried about excessive pressure in auxilliary tank or problems transferring fuel to main tank. So went back in and loosened clamp again. Turns out another Hannigan owner has had same issues. Started thinking that maybe Hannigan set it this way intentionally. Will have to check with Hannigan, but right now my focue is on Northeast Rally this weekend. Cheers!
    Leo TOI #617
    (Jeannette)
  1. auxilliary fuel tank
    By corvette in forum Honda Trikes
    Last Post: 03-12-2014, 06:14 PM
  2. Yamaha RSV & RSTD Front tire on Trike
    By kj5ix in forum Yamaha Trikes
    Last Post: 08-13-2013, 10:03 AM
  3. Yamaha RSV/Hannigan trike gas tank kit
    By Carbon_One in forum Yamaha Trikes
    Last Post: 05-26-2012, 12:54 PM
  4. Auxilliary Fuel Tank
    By 1550vt in forum Accessories
    Last Post: 10-07-2009, 02:16 PM
