Likes Likes:  4
Results 1 to 11 of 11
Thread: Replacement Headlight Bulb
    900+ Posts
    Bellville, Texas, USA
    Default Replacement Headlight Bulb
    The high beam on my 2015 FLRT has gone out, low beam still works. The original bulb is a H4U 60/55 watt. I have a new H4 100/55 watt bulb on hand. Has anyone replaced the original 60/55w bulb with a 100/55 w bulb? Is the 100 watt high beam too much for the charging system or wiring? Seems to me it should be OK but would like to have some input from others. Thanks,
    Sunman
    I would worry more about the heat in the fixture from the 100 watts. I am forever removing the 100 watt bulbs in our police car spotlights because it is melting the housing. I replace with a 55 and all is well.
    My experience with those bulbs is pretty much the same as Ted's. I've used them in the past on a few of my bikes and they produce so much heat,it tends to melt the mirrored surfaces of the headlight and also the plug-in connector.
    900+ Posts
    Thanks guys for the responses. I hadn't thought about the heat being an issue. I will go back with the same as OEM.
    Sunman
    Quote Originally Posted by Sunman View Post
    Sunman
    Give one of these a try. I'll bet you will really like it.
    http://www.dkcustomproducts.com/Prem...-H4-HL-LED.htm
    900+ Posts
    Quote Originally Posted by Clint44 View Post
    Thanks Clint but already bought a replacement. Will look into this next time.
    Sunman
    100+ Posts haute pursuit's Avatar
    Aug 2016
    houston, texas, usa
    After a "Close Encounter of the Whitetail Buck Kind" last night. I'm going to try out that DK LED bulb replacement. I never saw the dude until he got in the roadway... and had he slowed down, one or both of us would have lost some meat.
    Dec 2013
    Clarion PA USA
    Default Be careful now those deer are real stupid
    You know it's Ruttin season the boy's are real stupid pre-occupied with other more important things on their minds. Please be very alert at all times more especially now. I really avoid riding after dark now. ride safely fearless
    Quote Originally Posted by haute pursuit View Post
    Brighter head lights are great.... Provided when you drive at night at the same speeds as you would with the standard lights.. You can see further down the road with brighter lights' So most people tend to drive faster down the road, So the closing times to the target will be faster and harder...
    Aug 2016
    houston, texas, usa
    I'm just trying to avoid the target...😆
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Yep, we have all kinds of critters in our parts...and the big ones (deer) are starting to move.
    The LED Bulb is great for Seeing & Being Seen.
    Equally important, if not more so for the critters, are the Stealth LED Driving Lights.
    I need to get a good pic of them from the riders perspective at night. They spread the light VERY Wide, but it is down low, so it does not bother oncoming traffic...but it really lights up both sides of the road.
    www.DKCustom.com
  1. Replies: 17
    Last Post: 01-22-2019, 02:57 PM
  2. Replacement panel for the level headlight/memo panel
    By paid4c4 in forum Honda Trikes
    Last Post: 05-26-2016, 10:20 AM
  3. Fog Light Bulb Replacement
    By Suzanne L Oldt in forum Stallion Trikes
    Last Post: 10-09-2012, 10:08 PM
  4. Buy replacement headlite bulb???
    By GYPSYGAL in forum Honda Trikes
    Last Post: 04-16-2012, 10:40 PM
