Likes Likes:  5
Results 1 to 6 of 6
Thread: Harley Trike Conversion wouldn't start, so
    100+ Posts Smitty Werben Manjensen's Avatar
    Aug 2012
    Lost in Kansas
    Default Harley Trike Conversion wouldn't start, so
    The following is strictly for information porpoises only. I hadn't used my trike for a couple years as have been having various operations.
    Had drained the tank way back, but now felt like starting her up again. Put a gallon of gas in there and -- no start. Noticed gas leaking out the quick disconnect under the tank, but thought just a o-ring problem. Checked for a spark and mistakenly thought there was none. Ordered a new coil after testing it (poorly). In the meantime, did a lot of internet investigation and one person said if you have a leaking gas line, your motor may not start.
    So, back to my less than stellar troubleshooting, and now found a spark. Then looked at the fuel quick disconnect (not the one on the tank itself), and saw the o-ring rotted. Decided to drain the tank and look at that part of the quick disconnect. Both o-rings were rotted. I then looked for all those o-rings on the internet (2 on the tank part, and one on the hose part). The two on the tank part were (off the internet) 11105 (or AS568A-109) for the smaller top one, and 11387A (or AS568A-905 or Advance 64492.1) for the larger bottom one.
    The bottom one was the cause of my leak while the hose was connected to the tank, so I bought the Advance one, and changed the others with one of the hundreds of o-rings I have laying around. I couldn't find any of the o-rings on-line without purchasing 90-100 of them, except the Advance one was per unit.
    Hooked it all back up and the motor started! But, the gas gage wasn't working, and had a B1004 and B1005 code. After some more search, someone said use some Seafoam or similar in a full tank and see if the codes clear up. So, added Seafoam to a full tank, and after 4-5 "trike shakes" over 30 minutes to slosh the fuel around, the codes vanished.
    Life is now good again.
    Quote Originally Posted by Smitty Werben Manjensen View Post
    So, back to my less than stellar troubleshooting, and now found a spark. Then looked at the fuel quick disconnect (not the one on the tank itself), and saw the o-ring rotted. Decided to drain the tank and look at that part of the quick disconnect. Both o-rings were rotted. I then looked for all those o-rings on the internet (2 on the tank part, and one on the hose part). The two on the tank part were (off the internet) 11105 (or AS568A-109) for the smaller top one, and 11387A (or AS568A-905 or Advance 64492.1) for the larger bottom one. The bottom one was the cause of my leak while the hose was connected to the tank, so I bought the Advance one, and changed the others with one of the hundreds of o-rings I have laying around. I couldn't find any of the o-rings on-line without purchasing 90-100 of them, except the Advance one was per unit.
    Nice when plan works out 👍👍📞
    Aug 2012
    Lost in Kansas
    By the way, the trike is based on a 2004 Road King Custom, in case anyone wondered.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Way back when,,, they said drain your tank. Now days the new thing says full tank with Stay Bil ( or some such fuel additive) for storing. Just passing along. Seems to work for me on all things that dont get started but maybe once a year just to check. Think it has something to do with Ethanol in the gas.
    All the way back in the 60's/70's when i put my Snowmobiles away from March till next December i always filled the tanks to the top, and never turned the gas off to the carbs, That way water [condensation] didn't get in the tank, and the carbs stayed Wet so the seals didn't dry up....I do that with my ATV'S .....Regardless of what the so-called experts say...I found you can learn a lot more than the experts just by doing it caveman style...And i never had a problem ....But then i'm not an expert...
    Now would be a good time to run some Marvel Mystery Oil thru the gas
  1. Replies: 8
    Last Post: 02-27-2018, 06:23 PM
  2. Hood wouldn't open!
    By JerryC in forum Stallion Trikes
    Last Post: 12-11-2017, 10:12 AM
  3. Stallion Wouldn't Crank
    By Dean H in forum Stallion Trikes
    Last Post: 06-11-2015, 09:30 PM
