Likes Likes:  12
Results 1 to 20 of 30
Thread: 2015 FLRT Rear Wiring Harness Insert
    350+ Posts Springman2007's Avatar
    Sep 2014
    Grafton, OH, USA
    Default 2015 FLRT Rear Wiring Harness Insert
    In an effort to keep the stock wiring harness intact and without any splicing or modification, I decided to build an insert harness to power some of the accessories I would like to have on the 2015 FLRT. The insert goes in between the main wiring harness and the rear light wiring harness at the junction located just below the FLRT’s seat (Connectors 7A & 7B on the FLRT Schematics). The following are notes in support of that insert.
    Terminal Pin Chart
    Terminal 1 on connectors 7A & 7B – R/Y – Accessory Power
    Terminal 2 on connectors 7A & 7B – BE/BN – Right Turn Signal Power
    Terminal 3 on connectors 7A & 7B – BE – Running Light Power
    Terminal 4 on connectors 7A & 7B – BE/R – Brake Light Power
    Terminal 5 on connectors 7A & 7B – BE/V – Left Turn Signal Power
    Terminal 6 on connectors 7A & 7B – BK – GROUND
    Terminal 7 on connectors 7A & 7B – R/BE – P&A Power
    Terminal 8 on connectors 7A & 7B – Reverse Indicator Power FLRT (Not Used)
    Parts:
    HD part number – 72168-07 – Terminal Socket – 8 needed (10 requested)
    HD part number – 72469-07GY – Housing (Male), 8 way, Grey – 1 needed
    HD part number – 72473-07 – Seal Pin – 1 needed
    HD part number – 72169-07 – Terminal Pins – 8 needed (10 requested)
    HD part number – 72447-07GY – Housing (Female), 8 way, Gray – 1 needed
    Hope this Helps
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    Just bought a harness to run my trailer. They use the same/similar set up. Plugs in and add the proper plug for the trailer is all.
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
    Sep 2014
    Grafton, OH, USA
    Quote Originally Posted by Keystone View Post
    Keystone,
    Your premade insert is most likely cheaper than ordering the HD parts and its pre-made. Please post details on it - maker, place of purchase, part number, and price.....
    Springman
    Jul 2010
    Minnesota
    I won't call them cheap, but here is where I got mine from. Up until 2013 the electric hook ups were easy and cheap...
    Edit: Today I went out to the garage with the intention of doing the trailer hook up. After questioning the vender as to his product actually working on the FLRT and him stating it did I came to find out it will NOT work on the TG. The one he sent only works on the TG. He know understands it won't work. He will replace the part in 2 or more weeks once he gets the new set up from the company that makes them.
    BKMNI
    2015 Harley FLRT
    300+ Posts 0pini0nated's Avatar
    Oct 2012
    Willow Grove, PA Turnpike, Exit 343
    "In an effort to keep the stock wiring harness intact and without any splicing or modification . . . ."
    This thread is a 'keeper' ~ nice work Jim.
    2005 FXST Softail Std | 2015 FLRT Freewheeler | 2015 FLD103 Switchback
    *14-year Member, ABATE of PA- ABATE.ORG
    * MRF- MRF.ORG
    1000+ Posts screwball's Avatar
    Santa Clarita, SoCa & Bullhead City, Az
    Harley sells an accessory 12v socket for the tourpack on the Tri-Glide. It connects to the same socket under the left panel on the Freewheeler. There is a plastic nameplate/plug behind the felt lining. I took out the plate, drilled a hole, notched the hole and passed the 12v socket wire through it. I now have a 7.2v USB outlet strip in the trunk to charge MP3 players, cordless headsets, etc. I also installed a 120v inverter . . . just in case.. Total outlay was under $50.00
    http://www.triketalk.com/forum/custo...epic4494_1.gif
    Why 3 wheels?
    because 2 isn't enough and 4 is too many
    We are really Steve & Vesta Brown
    Her: 2014 Tri-Glide Me: 2015 Freewheeler
    Vietnam Vet 1967-68 U.S. Air Force
    Sep 2014
    Grafton, OH, USA
    Quote Originally Posted by Bazooka View Post
    Great Information Springman. Thread stickied.
    Thanks Zook!
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Default Reverse motor circuit breaker
    I tripped the breaker and really feel dumb now after seeing what some of you are doing with the electrical system. I am looking at Figure 98 of my owner's manual but I have no clue where the electrical caddy is. I was just about to take the seat off then decided that I should just ask for help.
    My car is in the shop so I thought it would be fun to back my trike into the garage. I am not sure if it was too far or if I used the brake too much before letting off of the reverse but I will be more careful from this day forward.
    Yes, I am blonde.
    Quote Originally Posted by LadyonaMission View Post
    Yes, I am blonde.
    If it was uphill that will do it sometimes, also I've found bumping up a curve, like at the beginning of a driveway will do it too.
    4250+ Posts
    Feb 2015
    San Antonio
    Default I fixed it
    I found the location on another thread and I also read that someone drives up the driveway and coasts back down to get out so I will do that the next time I don't use my trike garage. Hopefully my car won't be in the shop too frequently.
    Sep 2015
    Bella vista
    Default Air wing LED light wiring
    Do you think your harness will run my air wing LED light? I can do the work. Harley wonts to Hrs. labor to do it. Thanks for the post man.
    Sep 2015
    Bella vista
    Default insert for harley Free Wheeler
    Quote Originally Posted by Springman2007 View Post
    Keystone,
    Springman
    I was told bi Harley their was no insert wiring for the Free Wheeler for the trunk for ACC. or add on air wing light?
    Sep 2014
    Grafton, OH, USA
    Recently, I have got an influx of private message request for the insert I made and data posted herein. Folks I made exactly one; and, I am not interested in making them to sell - that is sort of why I posted the data on making one.
    However, I have heard that a firm called "RIVCO Products, Inc" http://rivcoproducts.com/ may make such an item.
    Springman
    Sep 2015
    Bella vista
    Default harness
    Ok, all is good. I'll make one or two. Safe travel.
    Sep 2014
    Grafton, OH, USA
    Springman
    Also, I have to say that if you are in the market for one, I would try Rivco and see - as I am sure it would be cheaper than ordering the stuff from Harley as I did.......
    Springman
    Jul 2010
    Minnesota
    Springman
    His doesn't fit either. Bought on last day in Sturgis. Still waiting for them to make it right.
    BKMNI
    2015 Harley FLRT
    20+ Posts Freewheeler's Avatar
    Oct 2015
    Utica
    Default 2015 Freewheeler rear wiring harness
    Thanks for this info, I'm making the harness as soon as the parts come in...
    On on another subject I added passing lights using a 2015 road king light bar and cobra passing light housings. Looks awesome...
    padded to date:
    passenger backrest
    driver backrest
    LED headlamp,
    rear bumper,
    detachable windshield,
    heated grips,
    Vance & Hines 4" slip ons
    luggage rack
    luggage rack LED Center light
    rear chrome tail lamp LED
    Front turn signal LED Custom Dynamics
    chrome engine heat deflectors... Need to know more let me know....
  19. #19
    Sep 2015
    Bella vista
    Cool Rear rack air wing light
    I got it done and it works good. Was not hard to do. " Thanks for the info." How I'm looking for a better head light bulb for the big axx head light that's on it, maybe a H4 PIAA ?? I'm not giving Harley 500 bucks for an LED head light.
  20. #20
    Oct 2015
    Utica
    Default LED H4
    Quote Originally Posted by GLT View Post
    I found an H4 LED Cree light 6000k light on eBay, installed. Had to modify the retainer, works fantastically, and wow, extremely white and bright. Cost: $55.00...
  1. RS trailer wiring harness
    By wiredgeorge in forum Roadsmith Trikes
    Owners Forum
    Last Post: 08-22-2014, 06:35 PM
  2. trailer wiring harness
    By sassoman in forum Can Am Spyder Trikes
    Last Post: 04-25-2014, 09:54 PM
  3. trailer wiring harness
    By greybeard.3 in forum Trailers / Campers
    Last Post: 02-23-2013, 10:51 AM
  4. trailer wiring harness
    By fordor328 in forum Trailers / Campers
    Last Post: 12-02-2012, 09:28 AM
  5. Hitch & Wiring Harness for Yamaha
    By BinIdaho in forum Yamaha Trikes
    Last Post: 08-01-2011, 11:20 AM
