Likes Likes:  3
Thanks Thanks:  1
Results 1 to 20 of 22
Thread: Rear brake question
    Dec 2019
    gold canyon, az, usa
    Default Rear brake question
    I recently bought an 08 GW motortrike. In a parking lot brake test should be able the lock up the rear brakes? They stop OK but will not lock up.
    100+ Posts msrvpeig's Avatar
    Feb 2008
    Home of the Buckeyes
    Similar issues with my '05 Goldwing MT. Was replacing front brakes every 20k miles. Ended up that rear brake calipers were locked up. Replaced both rear calipers about 3 years ago. I brake almost exclusively with the rear brake pedal now. BTW, those replacement calipers are not cheap!
    500+ Posts
    triwinggirl's Avatar
    Jun 2010
    Las vegas Nevada
    if the bike has ABS it wont lock up. otherwise you might have a leak, air in the lines can cause all sorts of issues. also old fluid, or bad master cylinders. I have had issues with all of these from a Goldwing that sat for awhile.
    Jul 2019
    Joaquin, TX. USA
    Default 08 Goldwing champion trike - rear brakes
    I have an 08 Goldwing Champion trike and when we were riding last weekend, seemed like I was losing power, but what actually happened is that my rear brakes locked up, solid couldn't move the bike and in the road. Husband got me going again, but was wondering if anyone else has had this happen and if so, what caused this to happen.
    Also, does anyone know what brake shoes go on the rear.
    Thanks in advance for any help.
    Glenda
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Quote Originally Posted by Glenda McGinty View Post
    I have an 08 Goldwing Champion trike and when we were riding last weekend, seemed like I was losing power, but what actually happened is that my rear brakes locked up, solid couldn't move the bike and in the road. Husband got me going again, but was wondering if anyone else has had this happen and if so, what caused this to happen.Also, does anyone know what brake shoes go on the rear.Thanks in advance for any help.Glenda
    There was a brake recall in 2016 I believe it was for the GL1800. Don’t know if your bike’s problem would be part of that recall but just in case you can check with a Honda dealer who will run the VIN number to see if your bike has had that recall done.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    Glenda
    Does it have an aftermarket brake pedal or did anyone adjust the brake pedal recently ???
    As stated above, there is a recall from Honda.
    Champion bypasses the anti-dive valve and the secondary master cylinder so unless your master cylinder is plugged up, I suspect something with the brake pedal.
    Jim Murphy
    Iron Butt Rider 2001
    Jul 2019
    Joaquin, TX. USA
    Took to Honda and supposedly they did fix recall on brakes - now the rear brakes are spongy and not stopping properly. They stopped just fine before they did recall work
    glenda
    glenda
    Call to see what warranty they offer on the work. Brakes should always work proper after service or not be released to the owner. This is a huge liability.
    paws's Avatar
    Kerrville, TX U.S.A
    Same thing happened on my GL1800 Motor Trike..just after they did the brake recall. Brakes got worse and worse and finally none.
    Can’t remember exactly what my indy told me happened.. he had a conversation with the head Motor Trike technician and it was something about an obscure valve that had not been closed all the way? I never saw any signs of fluid residue on the bike or garage floor so it must have been a very slight leak. He flushed and totally checked the system, refilled, and all was good after that. Good luck with finding the problem.
    200+ Posts
    Dec 2019
    Melbourne Fl USA
    EDIT -
    Whoops! Did not check post date... Nevermind...
    Purchased Dec 2019 * 2006 Honda VTX 1800 with solid axle Motortrike Conversion. * Color: Y181P Challenger Brown Metallic * Seats: VTX 1800 Big Boy Seat, Passenger Seat, Driver Backrest and Sissy Bar Pad from Ultimate Seats * Exhaust: SUPER quiet hidden pipes, quad 6" baffles, 51mm DB killers
    Jan 2020
    Todwick,Yorkshire,UK
    Default brakes
    Quote Originally Posted by paws View Post
    I had a letter a few days ago from Honda about this recall/problem.....it say's..(the shortened version)..The check valve orifice in the GL1800 brake system is susceptible to blockage by deposits,formed due to infrequent brake system fluid changes,prolonged periods in-stock or inadequate maintenance.This deposit could cause the check valve orifice to become blocked causing rear brake drag.....
    30+ Posts
    Apr 2017
    long branch n.j. monouth
    Default brake poor.
    where in the system is the check valve ? had brake recall dune still poor braking.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by funone97 View Post
    If your DFT kit came with a check valve it would be here:
    DFT install instructions can be found here: https://pdf4pro.com/view/d-f-t-trike...ns-47773d.html
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    Thar recall has nothing to do with the trikes rear brakes. It only applies to two wheeled Goldwings.
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    Quote Originally Posted by cavie View Post
    The recall applies to both trikes and bikes. It involves parts that are still part of the original bike (secondary master) and don't get removed with conversion.
    But to the question of weak braking after recall, it is important to properly bleed the brakes. Usually the trike manufacturers provide special bleeding instructions due to modifications to the rear brakes because an extra caliper is added. But there is still one more procedure that doesn't show up in either the Honda manual or any of the trike instructions. It has been labeled the "Rocky Bleed". Many times the weak brakes are a result of some air still left in the system and the "Rocky" method helps to eliminate all the air and will probably firm up your brakes to where they should be.
    https://www.theglforum.com/forum/mot...=6033#post6033
    Jul 2016
    Not sure if this will work but I am attaching a document that will go into further detail.
    upper brake bleed.doc
    And here is the info about the recall. You can see that this is a component that is part of a GL1800 whether it is a bike or converted into a trike.
    https://secureservercdn.net/198.71.2...eplacement.pdf
    paws's Avatar
    Kerrville, TX U.S.A
    Two different dealers did the recall on my 2008 GL1800 Motor Trike, my husband’s 2008 GL 1800 Lehman Monarch II, and our friend’s 2010 GL1800 motor Trike. Both dealers had to work us in as they were so busy with other people’s Gold Wing trikes coming in for the recall. One dealer did our 2 trikes and the other did our friend’s trike. This was done in November 2016 and we had to trailer the trikes to the dealers 150 miles from us due to inclement weather. Took 3 trips as the Aluma TK1 only held 1 trike.
    Jan 2013
    Quote Originally Posted by pwhoever View Post
    I've always been told that anytime a Honda is triked, all warranty and recall responsibility's are off. I am going to bring "Rocky's" method to the attention of my mechanic. Good read.
  19. #19
    Jul 2016
    The warranty would still apply to whatever wasn't modified as a result of the conversion.
  20. #20
    Jan 2013
    glenda
    I have a 2003 that needs the recall fix. Are you saying that Honda will still preform the Recall even with the bike being triked?
  1. Replies: 40
    Last Post: 01-20-2020, 09:13 AM
  2. Bleeding the brake/clutch lines to replace the DOT 4 brake fluid.
    Last Post: 10-07-2018, 05:03 PM
  3. Replies: 2
    Last Post: 02-03-2017, 12:27 PM
  4. E-Z Brake Extended Brake Lever
    By Sunman in forum Harley Freewheeler / Road Glide 3
    Last Post: 01-21-2016, 05:28 PM
  5. To Brake or Not to Brake?
    By BELCHER in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-14-2013, 04:28 PM
