AriNV5pawsRider Safety Discuss...Maybe silly but serious question, s...
AriNV5Pegasus1300Rider Safety Discuss...Maybe silly but serious question, s...
AriNV5cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
AriNV5Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV5AriNVRider Safety Discuss...Maybe silly but serious question, s...
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  1
Results 1 to 12 of 12
Thread: Headlight Height Adjustment
    300+ Posts paid4c4's Avatar
    Mar 2016
    Crestview Hills, KY, USA
    Default Headlight Height Adjustment
    I have a 2006 GW 1800 Motor Trike and none of the functions on the control panel on the left side which had Headlight Height Adjustment, Memo, ect seem to work. Are these disconnected when a GW is Triked or should I start trouble shooting?
    Bill
    350+ Posts Woolie's Avatar
    Jun 2011
    Lubbock, TX
    I have a 2009 and the headlight adjustment works fine. So does the battery charge voltage and the suspension air pressure. Perhaps your installer did something wrong, it wouldn't be the first time.
    2009 Honda Gold Wing Motor Trike Adventure Kit
    May 2011
    San Angelo
    Quote Originally Posted by paid4c4 View Post
    Bill
    Which conversion kit did you have installed Bill? Some have replaced the memo switch location with indicators and others do not. Help us help you...
    2015 GL1800/Roadsmith HTS1800
    Mar 2016
    Quote Originally Posted by Gold Rush View Post
    I bought this trike a couple of months ago from the original owner. I have found a build label on the underneath part of the trike which indicates it was built in 2007 and is a Motor Trike Spyder.Name:  IMG_0575.jpg
    This is about all the information I have.
    Bill
    May 2011
    San Angelo
    Bill there is a big gray connector under the left pocket That I'd bet is not connected. Your OEM suspension preload is disconnected during the conversion but the head light adjust and Hazard Warning should still work. Motor Trike had an optional onboard air compressor for the rear air springs. If you still have the OEM preload controls then that option is not installed so you will have a Schrader valve somewhere to service your air springs. (sorry, I wandered).......
    You will have to remove the molding on the left side then there is an Allen head screw holding the control panel in place. You might be able to get it out and reconnect the gray connector without removing the pocket. If not here is the procedure from the '06 service manual. Pay attention to the red letters I added.
    Good Luck !!
    FAIRING MOLDING REMOVAL
    Take care not to break the molding tabs.
    Release the front tab first by sliding the molding rearward, then release the other tabs and remove the fairing molding. This procedure will most likely cause you to break tabs. Start at the bottom and carefully work you way to the top!!!
    Install the fairing molding in the reverse order of removal, being careful not to damage the tabs.
    LEFT FAIRING POCKET
    Remove the fairing molding
    Push the opener button and open the fairing pocket.
    Remove the following:
    – four trim clips (by pushing the center pin in)
    – left fairing pocket
    Installation is in the reverse order of removal.
    Mar 2016
    Gold Rush, Thank you for the information regarding the headlight adjustment. I have had the molding off as I installed an audio cable for a MP3 player/phone to plug in and also a 12V cigarette plug inside the left side storage compartment. I will pull it out and check to see if the headlight adjustment switch has been disconnected. I do have a schrader valve. I have just replaced the air bags only to find that the T-fitting and air line is leaking. I'm replacing all the cheap plastic air fittings and line with 1/4 inch air line and brass NPT fittings. I ill report the outcome once the work is completed in the event my experiences might help someone else.
    Bill
    Good Luck !!
    LEFT FAIRING POCKET
    1500+ Posts Dockem's Avatar
    Jul 2011
    Cville, IN / Leesburg, FL
    Not trying to hijack the thread, but is there a "manual" adjustment also for aiming the headlights behind the bulbs?
    May 2011
    San Angelo
    Quote Originally Posted by Dockem View Post
    There is on the GL1800 but I don't know about your Valk. Maybe someone with experience or a service manual will help out there....
    Jul 2011
    Gold Rush,
    Sorry, I just updated my profile:
    '08 GL1800 w/ Roadsmith HT1800 conversion.
    Could you elaborate on the manual headlight adjustment for a GL1800?
    TIA
    May 2011
    San Angelo
    Gold Rush,
    TIA
    Shoot me a PM with your email and I'll send you the service manual instructions.
    Jul 2011
    PM sent, THANKS! Got it.
    Jul 2011
    Default Manually adjusting GW headlight aim
    A 12mm socket on a 6" extension does nicely for adjusting aim - after you find the adjuster.
  1. headlight Adjustment
    By jmhenrie in forum Harley Tri Glide
    Last Post: 02-28-2016, 11:26 PM
  2. Headlight adjustment
    By ArkyBubba in forum Honda Trikes
    Last Post: 02-02-2016, 10:13 AM
  3. Proper Headlight Height?
    By 3rdwheel in forum Harley Trike Conversions
    Last Post: 12-11-2015, 01:13 AM
  4. Windshield height - looking over it or through it!
    By RagenTri in forum General Discussion
    Last Post: 05-14-2015, 11:51 AM
  5. Headlight adjustment
    By Motorcycle Mike in forum Yamaha Trikes
    Last Post: 09-14-2014, 05:05 AM
