Likes Likes:  17
Page 1 of 10 1 2 3 4 5 6 7 8 9 10 LastLast
Results 1 to 20 of 186
Thread: Harley Fluids What and Why!
    100+ Posts 1852cc's Avatar
    Jun 2009
    Camp Verde, AZ
    Arrow Harley Fluids What and Why!
    Ok, just want to know what you all are running in twin cam's (ultras, trikes etc), and why you have settled on that brand and weights.
    What are you running in all 3 holes, motor, primary and trans.
    Thank You
    Mike
    350+ Posts Nauga Mok's Avatar
    Dec 2009
    Las Vegas, NV
    Default Re: Harley Fluids What and Why!
    I'm running Harley's Syn 3 in everything on my '06 Ultra. It is a bit pricy, but I like the idea of only having to carry one bottle of oil when out on the road that will cover "all 3 holes". Yes, I have had to add oil to the trans when out on the road. Now that she's a trike, I probably won't ever have to do that again, but I plan to keep using the Syn 3. According to some people, that are using Amsoil, the Amsoil gear lube helps quiet that clunk in the trans when going from neutral to 1st, but then too, plain old 90 wt gear oil would probably do that too. I know when I get that Syn 3 on my hands it's almost impossible to wipe off that slipery feeling without soap or handcleaner. It feels a LOT like Type E fork oil in that respect.
    NM
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    Mike and I use the Syn-3 in everything also. Been very happy with it.
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
    Apr 2009
    Clifton, NJ
    I use the Syn-3 in both the Tri Glide and the 06 Ultra.
    AMSOIL 20 w 50 in all 3 places. Been doing it for almost 20k. No issues.
    70+ Posts myth's Avatar
    Nov 2009
    ocean county, NJ
    been using amsoil and like it
    Feb 2008
    Anderson, Missouri
    As my HD is an EVO, I won't chime on on the fluids use except to say I found it interesting that for years, Harley cautioned against using any kind of synthetic fluids in any Harley. Ah, but now that the MoFoCo has Syn3, it is fine in all 3 seperate places we had to use 3 seperate fluids before, even recommended in the EVO's.
    30+ Posts trikerman's Avatar
    Nov 2009
    Stoke on Trent, UK
    I've been using Spectro oils for 10 years now, I've looked on the internet and we can get Amsoil 20-50 in the UK, Would I have to flush out every trace of the Spectro oils or would a hot drain down and fill with Amsoil be ok.
    Regards
    John.
    500+ Posts tis's Avatar
    Dec 2008
    West Falls, N.Y.
    I've been useing Syn-3, works great.......
  11. #10
    60+ Posts Tonyd's Avatar
    Jan 2009
    Brookfield, IL
    Ok lets think for a minute....would you put trans fluid in your car engine? or motor oil in the rear end gear case? :no: NO right?......well why do you think is ok to put motor oil in all three holes cause some guy says do it from Harley...the people that want to sell more bikes .......So me...I run Red line 20w50 in the motor...motor oil......and Red line heavy duty shock proof gear oil in the trans.......and Red line MTL (manuel trans lube) in the primary :yes:
    BTW all syn.
    google it on the net
    just my 2 cents
    Tony
  12. #11
    80+ Posts Hawkeye's Avatar
    Mar 2008
    Greenville, NC - USA
    +1 for Redline. Same as Tonyd. I've used it in all three trikes totalling close to 100,000 miles with no problems.
  13. #12
    Dec 2009
    Las Vegas, NV
    [QUOTE=Tonyd;27933]Ok lets think for a minute....would you put trans fluid in your car engine? or motor oil in the rear end gear case? :no: NO right]
    Not necessessarily. I've used ATF in engines to clean 'em out. We used to put engine oil in the Road Ranger transmissions on our semis. Worked fine. Got in excess of 500,000 in a trans rebuild. A there are several autos & trucks now that use ATF in the manual transmissions, differentials, & transfer cases on 4X4s. Cat heavy equipment used hydraulic oil in transmissions & 50 wt motor oil in the diffs & final drives. 90 wt gear oil is almost a thing of the past.
    NM
  14. #13
    trikerman a hot drain fliter change and add the new AMSOIL will be fine.
  15. #14
    Jan 2009
    Brookfield, IL
    OK!! LOL....I knew someone would come back......So if ya wanna put Crisco in fine..maybe Mazola...lol....But Im not takin chances with my $6,000 AIR cooled engine or my $2,000 trans that reves at 3000 rpm...I listen to the experts.
    Tony
  16. #15
    Nov 2009
    Stoke on Trent, UK
    Quote Originally Posted by tmigala View Post
    Thanks very much tmigala,
    John.
  17. DKCustoms postbit
  18. #16
    40+ Posts hepengr's Avatar
    Dec 2009
    Globe, AZ
    When I first got the bike, I was running the HD SYN3 oil in the engine, transmission, and primary. In an effort to reduce drive train noise and the clunk when shifting, I went to Spectro Primary Chaincase oil in the primary,
    and the 6 speed tranmission oil (synthetic 75W140) in the gear box with good results.
    Due to the high temperatures during the summer months here in Arizona, I
    have switched to Red Line 20W60 (synthetic) in the crankcase which has a better VI (viscosity index - less thinning at higher temps) than comparable 20W50. What I was looking for was higher oil pressure at idle with 230 - 250 deg F oil temp. Seems to be better so far however need to see what happens when I get stuck in traffic on a 105+ deg. summer day.
    I believe that the 20W50 SYN3 oil provides adequate lubrication for all three compartments under normal conditions. I've decided to utilize different lubricants to either improve performance, or deal with extreme conditions.
  19. #17
    600+ Posts TNTriker's Avatar
    May 2010
    McDonald, TN. USA
    Quote Originally Posted by 1852cc View Post
    Thank You
    Mike
    I've just bought my 2010 Street Glide Trike last Monday. My husband has already changed the fluids. Red Line Shock Proof in the tranny; Mobile 1 ATF in the Primary; Mobile 1 20W50 V-Twin in the Engine. He has owned motorcycles for around 40 years, raced, built and experienced many changes. He is also a stickler for perfection. In his opion that combination works best for him. He has a 2008 HD Ultra Classic 105th anniversay edition. If you want more inside stuff, let me know and he will pm you with more info.
  20. #18
    300+ Posts
    May 2009
    Nashua, NH
    Quote Originally Posted by hepengr View Post
    I went to Spectro Primary Chaincase oil in the primary, and the 6 speed tranmission oil (synthetic 75W140) in the gear box with good results.
    I use the Spectro Platinum 6 speed (75/140) tranny oil in my 07 Ultra
    for 20k miles and will be putting it in Lynn's Trike because of her shifting
    problems today in 80+ heat and being in City traffic. She had a heck of
    a time trying to shift between gears :-(
    Rob ......
  21. #19
    350+ Posts
    RickDeVon's Avatar
    Jun 2010
    Pine Mountain,Ga
    Now that we are talking trike oil...My manual says to check it on the side stand...How do you check the level on a trike???Anyone follow me here??
  22. #20
    50+ Posts bounder04's Avatar
    Jun 2010
    Mcminnville, TN
    Rick - if you pull the oil dip stick, it has two bands, one measures when on kick stand and the other straight up... which is the case with the trikes.
  1. sportster fluids
    By drvndbus in forum Harley Trike Conversions
    Last Post: 09-07-2014, 07:05 PM
  2. we want a Harley
    By lboos in forum Harley Trike Conversions
    Last Post: 08-20-2014, 02:36 PM
  3. Harley's Gone
    By Johnlyn in forum Harley Trike Conversions
    Last Post: 09-08-2012, 10:57 AM
  4. Harley Reverse Trike - Morgan Threewheeler to Return with Harley Power
    By SBStormy in forum Harley Trike Conversions
    Last Post: 11-08-2010, 07:43 AM
