Likes Likes:  1
Thanks Thanks:  1
Results 1 to 7 of 7
Thread: Leaking rear transaxle seal
    30+ Posts
    Feb 2019
    South Elgin, IL USA
    Default Leaking rear transaxle seal
    So i had to pull right wheel to replace battery. When I did I noticed the large nut and inside of rim had oil. Brake drum and shoes are completely dry so I am assuming transaxle seals? Concur? I'll take pics tomorrow if needed.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Could be if it's a Swing axle? Not sure how the outer castle, ("large") nut would/could be wet?
    Master cyl. still full?
    Pics will help...
    30+ Posts
    Feb 2019
    South Elgin, IL USA
    Default Thanks
    Pics will help...
    Yes I will tomorrow.
    30+ Posts
    Feb 2019
    South Elgin, IL USA
    Default Pics of possible seal leak
    Quote Originally Posted by KeithK View Post
    Here is the right side axle and inner axle.
    Founder: Roadsmith Trikes
    TrikeTalk Sponsor
    May 2016
    Daytona Beach Fl
    Default MR TRIKE
    I would say your axle nut is loose. The torque on nut should be 260 ft. lbs. When torque in gone, transaxle oil seeps out past seals in brake drum. There is a factory weep hole in bearing cover that allows oil to drain out backing plate so brake shows don't get wet. "Keep-On-Triken" Dick
    30+ Posts
    Feb 2019
    South Elgin, IL USA
    Default Nut
    Quote Originally Posted by MR TRIKE View Post
    The nut was hand loose when I took it off, Thank you.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Dick has it exactly right.
    Just tightening the nut might not be enough though.
    There is an o-ring around the axle behind that spacer that the seal contacts.
    If that o-ring is not compressed right it will leak down the axle. If run loose it will likely damage the o-ring and not seal until replaced.
    If/when you replace that o-ring make sure it fits the chamfer on the spacer correctly. I have had a hard time with not having the correct crush on that o-ring.
  1. Fork Seal leaking again HELP
    By RUMRUNR in forum Honda Trikes
    Last Post: 10-01-2017, 11:47 AM
  2. Catching an axle seal prior to it leaking
    By GoldWingrGreg in forum Honda Trikes
    Last Post: 06-24-2017, 06:17 PM
  3. Transaxle Oil Leak???
    By Lakota in forum VW Powered Trikes
    Last Post: 02-22-2013, 09:21 AM
  4. Leaking Left Fork Seal
    By Muleskinner in forum Honda Trikes
    Last Post: 08-11-2010, 11:18 PM
