LD-Ordie1LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  6
Page 2 of 2 FirstFirst 1 2
Results 21 to 39 of 39
Thread: 2008 honda goldwing 1500 stec
  1. #21
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
  2. #22
    Jun 2008
    Lovington, NM, U.S.A.
    Quote Originally Posted by trikeman View Post
    Is this a missing picture? Normally I get the blue box.
    Retired trike builder
  3. #23
    May 2018
    Canadian Texas USA.
    Hello have another question.Having trouble getting the trunk open previous owner said he removed the cover and bar to spray the mech.with penetrating oil, replaced the cover and could not get the trunk open after that.I have tried the coat hanger trick the bar doesn't want to move .Any suggestions
  4. #24
    Jun 2008
    By chance does they key to open the trunk turn to the left? I was told when I had my 1500 that if the trunk latch failed to try that.
  5. #25
    May 2018
    Canadian Texas USA.
    Hello.Yes it will turn to the left but still does not do anything
  6. #26
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Quote Originally Posted by Samw410 View Post
    A 🍺🍺🍺🍺🍺🍺 pac , , and a lot of patience !
  7. #27
    Oct 2010
    Are you referring to the lower cover under the tour box?
  8. #28
    Oct 2010
    Are you trying to open trunk on trike or tour box?
  9. #29
    Oct 2010
    There are 3 latches under the tour box. Left is to open left saddlebag. Right is to open right saddlebag. Center latch opens the tour box. When triked usually the left latch is used to open the trunk on the trike. If neither tour box or trunk on trike will open linkage or keyed lock on tour box is malfunctioning.
  10. #30
    Oct 2010
    Quote Originally Posted by trike lady View Post
    Just a thumbs up to your previous post
  11. #31
    Jun 2008
    I had to ask because I run 4 ad blockers on the browser and sometimes stuff vanishes.
    He needs to open the trunk (tour box) on the Goldwing, the latch malfunctioned. I know most people use the coat hanger. The only other way I can thinking of getting to the lever from the bottom by removing the underside of the tour box to gain access to the latch. The plastic part may have broken.
  12. #32
    Oct 2010
    Think you’re correct. Remove the lower panel under the tourpack and use a mirror to see the latch assembly and should be able to open the trunk
  13. #33
    Jun 2008
    Attached is the parts break down for the trunk. The large red arrow points to the bottom by removing this should give more space to catch the latch. A right angle screw driver is essential for disassembly. The red upright triangle point to the lock system and levers, and the sideways triangle points to the part that gets in trouble.
  14. #34
    May 2018
    Canadian Texas USA.
    Hello finaly got it opened removed the seat and made a hole in the backrest to unscrew the latch screws.Removed the cover he had replaced it with the rod on top of the release. works perfect now . Thanks for your help.
  15. #35
    Oct 2010
    AWESOME!
  16. #36
    1750+ Posts TGCarol's Avatar
    Jan 2016
    Ocala, FL, USA
    Hi Sam Welcome
    2016 Triglide Vivid Black (Black Bear).
  17. #37
    Jun 2008
    That's great.
  18. #38
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    Welcome from Indiana !!!
    Bob
  19. #39
    Dec 2013
    Clarion PA USA
    Welcome to the forum from Pennsylvania travel safe Fred.
  1. Honda GL 1500 rake kit
    By Grime in forum Honda Trikes
    Last Post: 02-22-2015, 08:59 PM
  2. 99 Honda Goldwing 1500 choke/carb problem
    By boregard9 in forum Honda Trikes
    Last Post: 11-03-2014, 07:24 PM
  3. 2008 Honda Lehman Goldwing 1800 Trike
    By jimmyfenster in forum Honda Trikes
    Last Post: 08-07-2013, 07:53 AM
  4. 1500 honda
    By geraldlanc in forum Honda Trikes
    Last Post: 11-20-2011, 09:20 PM
  5. GPS 2008 Honda Goldwing
    By skibridg in forum Honda Trikes
    Last Post: 06-27-2011, 11:34 AM
