Likes Likes:  2
Results 1 to 12 of 12
Thread: Push to connect 1/8" air line fittings.
    80+ Posts Oldrodder's Avatar
    Mar 2018
    Sudbury, on. Canada
    Default Push to connect 1/8" air line fittings.
    Does anyone have a source for these? Can anyone tell me if they are single use only or can they be re-used?
    TIA.
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    They can be reused, just make sure the hose is like new.
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
    Mar 2018
    Sudbury, on. Canada
    Quote Originally Posted by Notgrownup View Post
    Thank you!
    Dec 2012
    Santee
    Mike
    Don't know if you have a McMaster-Carr store up there but they have just about any type of air fitting you could want.
    Ray
    2017 Harley Triglide
    Tijuana Border
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Oldrodder View Post
    TIA.
    amazon
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Take what you can with you to the nearest big truck dealer: Freightliner, International, KW, Peterbilt, Volvo/Mack etc. and go to the parts department.
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Old Road Dog View Post
    they generally run bigger than 1/8
    Oct 2021
    Snow Hill NC USA
    If you have a clean tubing end it will work fine reused
    IIRC those lines and fittings look like Lincoln Town Car airbag lines.
    If I am right Amazon carries some lines and fittings
    Advance Auto and Orileys auto parts used to carry lines and fittings also
  11. #10
    Mar 2018
    Sudbury, on. Canada
    Default Shedding more light on the topic!
    When I picked up this trike (2007 Ultra Classic, triked in 2008) last April, it had the suspension completely changed with new coil overs and air bags.
    The coil over part # is 99-SU-SH2-6603-0 $995.95 CDN./Pr.
    The air bag # is 99-MTRS-0170 $321.90 CDN./Pr.
    The bags were fitted with 1/8" air lines attached to the bags with the fittings shown here:
    The fitting is 1/8" NPT to 1/8" air line.
    The orange line is new stuff bought on Amazon along with 2 new Schrader valves. I've attempted to repair the leaking bags. More on that later! I will water test them tomorrow and if my repair is successful, my plan is to install the Schrader valves directly on the bags and install them on the bike. This is temporary until the AIRBAGIT bags arrive. According to Airbagit, what they call "Air Brake" fittings are leak proof and re useable and they cost 3 times what the push style fittings do! The smallest size they come in is 1/8" NPT to 1/4" Air line. I only want to do this job once so I will be using the 1/4" stuff. Presently, the air charging port is in the back of the trunk, requiring that the trunk be emptied to air up the bags. My plan is to move the charging port to under the tour pack and plumb everything new with the best fittings and 1/4" line.
  12. #11
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    STACEBG: The bags on axle airide suspension take a larger hose- both on tractor and trailer. But the cab airbags use the smaller hose and smaller airbags depending on application. Steel cabs found on some Peterbilt, KW, Western Star( Freightliner product) over 18,000lb, may have larger bags/ airlines). Ive delivered all of them from the factory to dealerships ( piggybacked 4 at a time) and each job is different.
  13. #12
    750+ Posts
    Jan 2010
    east windsor ct
    y bad i was thinking brake lines
  1. Air bag line fittings
    By AzBTO in forum Honda Trikes
    Last Post: 09-28-2019, 07:50 PM
  2. Replies: 7
    Last Post: 07-23-2019, 03:38 PM
  3. Replies: 4
    Last Post: 04-18-2019, 12:29 PM
  4. Zert Fittings
    By Fireeater in forum Roadsmith Trikes
    Owners Forum
    Last Post: 12-31-2017, 08:15 AM
  5. Myth Busted on HD "Stage I" "High Flow" air cleaner
    By DK Custom Products in forum Harley Trike Conversions
    Last Post: 05-16-2016, 01:12 AM
