Likes Likes:  1
Results 1 to 4 of 4
Thread: Locking the trunk on a Champion trike
    Dec 2015
    Edmond, OK USA
    Default Locking the trunk on a Champion trike
    I love my Champion trike - however, even though we have discreetly placed the pull cable, I would like to be able to lock the trunk. Anyone have a solution?
    450+ Posts GrandpaDave's Avatar
    Jul 2013
    Hankinson, ND, USA
    My 2007 Goldwing with a champion kit has the lower trunk cable attached to the left side compartment lever under the top trunk and it locks with the key or remote like the top trunk does.
    Dec 2015
    Edmond, OK USA
    Quote Originally Posted by GrandpaDave View Post
    Thanks for the reply.
    I have a 2010 Heritage ST - no top trunk. There is no locking mechanism anywhere.
    Was hoping someone had figured out a way to lock the cable pull for the few times I might want to secure items.
    Apr 2010
    Shenandoah Valley of Virginia
    Discreet placement of the cable for sure .... but you've already done that. Our GL1500 trike's cable pull is disconnected at the lever when the top trunk is locked .... doesn't help you.
    What I also have added is a "lock box" secured to the floor of my trunk at front that has it's own small padlock for times I may want to secure something.
    I'm not familiar enough with your setup to suggest further, discreet cable if discreet enough should do the trick? Maybe hiode cable even "more better" and use it as back up, but configure a electrical activator / lock pull?
    Or a hasp and pad lock ..... chromed or polished stainless steel ..... with engraving maybe?
  1. Trike Trunk Problem
    By alwrmcusn in forum Honda Trikes
    Last Post: 01-29-2015, 07:01 AM
  2. portable gas can in trunk of trike
    By Huelshorst in forum Harley Trike Conversions
    Last Post: 05-06-2014, 07:11 PM
  3. VTX 1800F Champion w/fairing and trunk
    By meredog in forum Honda Trikes
    Last Post: 09-20-2011, 05:31 PM
  4. Hogtrough locking covers
    By rwhgme in forum Harley Trike Conversions
    Last Post: 12-25-2010, 03:10 PM
  5. New trunk lights on trike
    By katfish16 in forum Accessories
    Last Post: 06-04-2008, 05:52 PM
