Likes Likes:  2
Results 1 to 11 of 11
Thread: Belt issues on a 17
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Default Belt issues on a 17
    I have a facebook friend that has a 17 Tri Glide with 2800 miles on it.He posted a pic of the drive belt with about 4-6 inches of teeth completely gone from the belt,not just chewed up but gone.Has anyone else heard of this.I checked my belt today and my trike has 8000 miles on it and all looked good.Mine is also a 17.
    Hardening of sprockets was an issue on some
    The material would come off and take the belt with it
    Also too loose ( lack of dealer prep or PDI pre delivery inspection)
    the tracking of the belt was not quote right, most belts do not track right, either to the outside of the pulley { most common} or the inside JMO
    Read here
    http://www.epi-eng.com/rotorway_heli...elt_issues.htm
    200+ Posts
    Nov 2015
    palm bay
    I don't follow all the technical issues but I do know that the belt on my 1990 FLHTC had close to 150,000 miles on it when I finally changed it (and the sprockets) because the belt had some weather checking. I had carefully adjusted it for both tightness and to run centered on the sprockets when new and checked both at every service but once "broken in" it needed little change. The only damaged or broken belts I have seen were due to things getting caught between belt and sprocket or a combo of a loose belt and too many wheelies - that is due to a loose nut on the seat. Naturally YMMV.
    off to the dealer for warrantee work. like Jack said defect
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Got a new 2018 Tri-Glide (my first) one week ago. Now have 400 miles on it and it's great. When cleaning I did push on the belt to check its tension and found that it is very tight. I don't have the deflection gauge but it has hardly any play at all. Do they set the tight from the factory because they will stretch a bit?
    300+ Posts
    florissant
    Quote Originally Posted by ultrafxr View Post
    yes ! i think they set it fairly tight when new. get it to a 1000 miles and check it again. they run the belts on these trikes tighter than on the two wheelers. 7/16 of an inch is the loose side of specs. still seems pretty tight to me. check when cold.
    hardheaded
    Check it after a ride, it will loosen up a bit
    The 1000 mile check up they should adjust it make sure they do you will be paying 4 it
    300+ Posts
    florissant
    you check after a ride and it will be guitar string tight, really tight. just after it's overnight cold is the correct way. set it while hot it will be way loose when cold. also buy the correct deflextion tool for set the belt up.
    hardheaded
    Quote Originally Posted by headheaded View Post
    Mine is tight beforeI ride it, loose when I park it Go figure
    The deflection is correct, different han ALL my two wheelers
  11. #10
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Well l got the scoop today about the belt on my new 2018 Tri-Glide being guitar string tight. Was at the dealership and mentioned it to the shop foreman / lead tech who I've known for many years. He said, yes, they do adjust them tight at the factory. He said when doing PDI on new bikes they used to adjust the belt to the spec but the factory told them to NOT do that. Factory said the belt would stretch and tech said by the time I'm ready for the 5k service in his experience most often the belts have stretched and are A-OK in accordance with the spec. His advice: 'ride it like you stole it!'
  12. #11
    300+ Posts
    florissant
    after a couple of thousand miles my belt was loose. had to tighten it up some. it's set on the loose side of harley spec's, but within spec. i've always taken my time and done this with every bike i've had . never any belt problems.
    hardheaded
  1. Belt dressing.....
    By rhino 2 in forum General Discussion
    Last Post: 08-11-2016, 09:38 AM
  2. belt adjustment
    By headheaded in forum Harley Tri Glide
    Last Post: 06-06-2016, 02:37 PM
  3. Bad Drive Belt?
    Last Post: 07-06-2015, 08:25 PM
  4. Belt pulley
    By 1pfdcaptain in forum General Discussion
    Last Post: 12-01-2014, 11:28 PM
  5. Dry Belt Lub
    By Lakeman in forum Harley Trike Conversions
    Last Post: 05-13-2012, 10:16 AM
