rocket1lf1rocket1lfStallion TrikesParts
Dasmoeturhead1DasmoeturheadCan Am Spyder Trike...New LED Lights
Davep6rhino 2Harley Tri GlideTRI GLIDE AIR FILTER QUESTION
Vin5Jack KlarichHarley Tri GlideCold Engine Revs High When Starting
Davep6Jack KlarichHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Davep6DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Ironhorse542Ironhorse54California Sidecar T...Helmet release button
Kneesinbreeze9rhino 2Harley Freewheeler /...Hiway pegs without installing crash...
Kneesinbreeze9Papa ZookHarley Freewheeler /...Hiway pegs without installing crash...
Ironhorse542Papa ZookCalifornia Sidecar T...Helmet release button
Kneesinbreeze9JerseyGirlRiderHarley Freewheeler /...Hiway pegs without installing crash...
DK Custom Products362SmittysTrikeHarley Tri GlideWhat did you do to Your Tri-Glide T...
Vin5Rogue1Harley Tri GlideCold Engine Revs High When Starting
diferg13hardwickbvNew Member Introduct...Hello from Southeast Georgia U.S.A
diferg13woodyNew Member Introduct...Hello from Southeast Georgia U.S.A
ZZMACH15Jack KlarichHarley Tri GlideElectric Fans on 2014 Tri Glide
Kneesinbreeze9Jack KlarichHarley Freewheeler /...Hiway pegs without installing crash...
TomyJ7Jack KlarichHome Built TrikesShenanigans
dthorn8Rogue1Harley Tri Glide2024 Tri Glide front axle nut torqu...
MDO101DK Custom ProductsHarley Freewheeler /...What Did You Do To Your Freewheeler...
diferg3Motorcycle MikeChampion TrikeChampion irs banging noise on bumps
Kneesinbreeze9My TurnHarley Freewheeler /...Hiway pegs without installing crash...
MDO101LD-OrdieHarley Freewheeler /...What Did You Do To Your Freewheeler...
diferg3difergChampion TrikeChampion irs banging noise on bumps
Rogue15Rogue1Harley Tri GlideOil pressure gauge.
Vin5Dan SCHarley Tri GlideCold Engine Revs High When Starting
Rogue15Dan SCHarley Tri GlideOil pressure gauge.
HDUSA113ol' schoolNew Member Introduct...New to Trike Talk
diferg13ol' schoolNew Member Introduct...Hello from Southeast Georgia U.S.A
scuzzi5scuzziHarley Tri GlideTri Glide extended reach seat
Vin5rhino 2Harley Tri GlideCold Engine Revs High When Starting
diferg3Marc HChampion TrikeChampion irs banging noise on bumps
Vin5VinHarley Tri GlideCold Engine Revs High When Starting
Frisco5Marc HCalifornia Sidecar T...Side pod door open signal
diferg13Uncle FesterNew Member Introduct...Hello from Southeast Georgia U.S.A
JohnnyVDA13Uncle FesterNew Member Introduct...Hello I am from Belgium
jef_nik20002jef_nik2000Lehman TrikeMonarch 2 center cap removal proced...
jef_nik20002Papa ZookLehman TrikeMonarch 2 center cap removal proced...
Tritek4stancotreauLehman TrikeAvoid buying a Lehman?
Rogue15Jack KlarichHarley Tri GlideOil pressure gauge.
Tritek4Papa ZookLehman TrikeAvoid buying a Lehman?
gfaltersack8DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
Kneesinbreeze9Noodles107Harley Freewheeler /...Hiway pegs without installing crash...
Rogue15Old Road DogHarley Tri GlideOil pressure gauge.
Tritek4TritekLehman TrikeAvoid buying a Lehman?
Burnerboy11rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
JohnnyVDA13Phu CatNew Member Introduct...Hello I am from Belgium
ZZMACH114BrokenBackJackHarley Tri GlideNew Member Hello from NH
diferg13BrokenBackJackNew Member Introduct...Hello from Southeast Georgia U.S.A
JohnnyVDA13BrokenBackJackNew Member Introduct...Hello I am from Belgium
JohnnyVDA13Papa ZookNew Member Introduct...Hello I am from Belgium
Frisco5FriscoCalifornia Sidecar T...Side pod door open signal
JohnnyVDA13Jack KlarichNew Member Introduct...Hello I am from Belgium
diferg13Jack KlarichNew Member Introduct...Hello from Southeast Georgia U.S.A
ZZMACH114SullyHarley Tri GlideNew Member Hello from NH
diferg13SullyNew Member Introduct...Hello from Southeast Georgia U.S.A
Kneesinbreeze9pigfoot63Harley Freewheeler /...Hiway pegs without installing crash...
AriNV14KneesinbreezeNew Member Introduct...New to trike
Burnerboy11KneesinbreezeCan Am Spyder Trike...How many of you ride a Can Am spyde...
TXFIRE766BurnerboyHonda TrikesNew to Trikes and needing a convers...
smokey_mountain2BurnerboyAccessoriesJ&S Moto conversion to Trike Li...
Frisco5BurnerboyCalifornia Sidecar T...Side pod door open signal
Frisco5ol' schoolCalifornia Sidecar T...Side pod door open signal
ZZMACH114trike ladyHarley Tri GlideNew Member Hello from NH
JohnnyVDA13trike ladyNew Member Introduct...Hello I am from Belgium
diferg13trike ladyNew Member Introduct...Hello from Southeast Georgia U.S.A
diferg13rhino 2New Member Introduct...Hello from Southeast Georgia U.S.A
diferg13GorillaNew Member Introduct...Hello from Southeast Georgia U.S.A
ZZMACH114Marc HHarley Tri GlideNew Member Hello from NH
diferg13Marc HNew Member Introduct...Hello from Southeast Georgia U.S.A
diferg13ZammyNew Member Introduct...Hello from Southeast Georgia U.S.A
Bloke10Marc HNew Member Introduct...Hello from Uttoxeter UK
JohnnyVDA13Marc HNew Member Introduct...Hello I am from Belgium
Kneesinbreeze9ZammyHarley Freewheeler /...Hiway pegs without installing crash...
diferg13difergNew Member Introduct...Hello from Southeast Georgia U.S.A
Phill Griggs2ZammyTrike TravelPIE-PIE & PIE
Bloke10ZammyNew Member Introduct...Hello from Uttoxeter UK
JohnnyVDA13ZammyNew Member Introduct...Hello I am from Belgium
Frisco5rhino 2California Sidecar T...Side pod door open signal
Rogue15rhino 2Harley Tri GlideOil pressure gauge.
JohnnyVDA13hardwickbvNew Member Introduct...Hello I am from Belgium
ZZMACH114hardwickbvHarley Tri GlideNew Member Hello from NH
Kneesinbreeze9KneesinbreezeHarley Freewheeler /...Hiway pegs without installing crash...
ctdair1ctdairHarley Tri GlideFixed Switch
Davep13GorillaNew Member Introduct...Hello from the mountains
ZZMACH114GorillaHarley Tri GlideNew Member Hello from NH
HDUSA113GorillaNew Member Introduct...New to Trike Talk
JohnnyVDA13GorillaNew Member Introduct...Hello I am from Belgium
Bloke10GorillaNew Member Introduct...Hello from Uttoxeter UK
Sunman7GoldWingrGregHonda TrikesF1 Warning Light
ZZMACH11ZZMACH1Harley Tri GlideRinehart VS Vance & Hines for M...
Bloke10rhino 2New Member Introduct...Hello from Uttoxeter UK
JohnnyVDA13rhino 2New Member Introduct...Hello I am from Belgium
JohnnyVDA13ol' schoolNew Member Introduct...Hello I am from Belgium
JohnnyVDA13JohnnyVDANew Member Introduct...Hello I am from Belgium
Bloke10Jack KlarichNew Member Introduct...Hello from Uttoxeter UK
Bloke10SullyNew Member Introduct...Hello from Uttoxeter UK
Bloke10ol' schoolNew Member Introduct...Hello from Uttoxeter UK
Bloke10hardwickbvNew Member Introduct...Hello from Uttoxeter UK
Bloke10trike ladyNew Member Introduct...Hello from Uttoxeter UK
Burnerboy11BurnerboyCan Am Spyder Trike...How many of you ride a Can Am spyde...
Phill Griggs2Phill GriggsTrike TravelPIE-PIE & PIE
ZZMACH13Longbeard71Harley Tri GlideLooking for Dynajet Power Vision mo...
Bloke10BlokeNew Member Introduct...Hello from Uttoxeter UK
Papa Zook2Jack KlarichHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
ZZMACH12Jack KlarichHarley Tri GlideElectric Fans on 2014 Tri Glide
ZZMACH13Jack KlarichHarley Tri GlideLooking for Dynajet Power Vision mo...
Smitty9013Marc HSidecar ForumSmall crack down the rabbit hole
HDUSA113Marc HNew Member Introduct...New to Trike Talk
HDUSA113ZammyNew Member Introduct...New to Trike Talk
Oldman-TriGlide10ZammyHarley Tri GlideEnclosed Trailer Size
Smitty9013ZammySidecar ForumSmall crack down the rabbit hole
Likes Likes:  9
Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
Thread: riding a trike after years of..
  1. #21
    50+ Posts Condor Spirit's Avatar
    Jun 2014
    Keene NH USA
    Glad you are able to be "back in the wind" I like many others rode 2 wheels for about 45 years. When we first got the trike I thought it was a huge mistake. It took me about 1K miles to get used to it. But now I love it and think you will too, once you get your muscle memory to accept the new way of riding. Wishing you many happy miles.
    In Youth you Learn. In Age you Understand. Now if I could just remember what I learned.:xzqxz:
  2. #22
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    As far as the weave goes try relaxing your grip a bit.Let the trike do the work.What happens to me is if I grip too tight or stiff arm it and I get a cross wind go over uneven pavement I shift a bit it gets transmitted to the bars and it doesn't take much to move the trike.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
  3. #23
    100+ Posts
    Mar 2017
    Bournville, OH, USA
    [QUOTE=pcombe;488840]interesting, I will have to look at their design?[/QUOTE
    here is the email I received from frankenstein trikes:
    Henry
    You purchased the premium kit which includes the trike kit, the exhaust and the raked tree.
    We do not sell fork tube extensions with our tree.
    Some companies sell the fork tube extensions with their tree because of the way their trees are made.
    I do not know if there are fork tube extensions available, if you were to find some and install them it would raise the front of the bike which would be lengthening the trail which could make the trike heavy to steer.
    We only have one tree for the touring models.
    I am not sure how the back of the trike could be higher than when it was a bike.
    When our trike kit is installed the back of the bike is lowered less than ½”
    When the trees are installed on the front, the front is lowered less than ½”
    The height of the wheels and tires are very close to the height of the motorcycle wheel and tire.
  4. #24
    100+ Posts
    Mar 2017
    Bournville, OH, USA
    Quote Originally Posted by Marc H View Post
    I admit I have been holding on with a death grip that makes hands hurt by time I make it back home, I dont stiff arm if very much or at least I dont think I do, I will try your suggestion, It will be a few days before I can ride it again as I have put off to much work around here, I have a floor to replace in bath room plus total remodel of same , install chimney for wood furnace, rent back hoe to rebuild back stop for on site shooting range, plus a few jobs I need to get done asap on metal lathe, Lot of irons in fire that need dealt with before snow flies, but that's all normal for everyone, so much work for so little time,
    Hank
  1. Who's Riding on New Years Day?
    By DK Custom Products in forum Harley Trike Conversions
    Last Post: 01-15-2014, 04:28 PM
  2. Wanted a trike for 45 years
    By alwayswantedatrike in forum New Member Introductions
    Last Post: 11-05-2012, 02:29 AM
  3. Newbie that has been riding for 53 years
    By Darrell in forum New Member Introductions
    Last Post: 12-18-2011, 06:23 AM
  4. New Years Day! Who's Riding Today?
    By RiderRick in forum General Discussion
    Last Post: 01-04-2010, 09:06 PM
