Likes Likes:  35
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 49
Thread: My Basket of parts
  1. #21
    Quote Originally Posted by TwistedKarma View Post
    possibly the worlds shortest drive shaft
  2. #22
    750+ Posts
    Jan 2010
    east windsor ct
    looks like a cardigan?? if so i dont think it will run smooth... made for one end of a drive shaft not to be both ends.
  3. #23
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default Diff.
    And the rear end will move up and down "How many inches"? I really like this design, please do not stop building this time...
    JakeJacobsen@Pinterest.com
  4. #24
    100+ Posts
    Feb 2017
    DE
    stripped a cv joint apart, been using it on 4x4,s a bit that way. finally figured out a bad ground, after i started putting hei distributor in tonight. added the baff like es to pipes, got the motor nice and warm. found a leak 🤣🤣 cleaning up tomorrow, brakes all bled.
  5. #25
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    The test ride will tell all! Gonna be a wild one!
  6. #26
    100+ Posts
    Feb 2017
    DE
    😔😔 no pumping from powerglid.....
    have to remove trans, and check the thingy. to see if broke...uggghhh. argrevating
  7. #27
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by TomyJ View Post
    its not the dif will move but if that is a cardigan it is made for an angle and not an offset! it would be "almost" impossible to get the two lined with no mismatch and there can be 0 flex in the frame...not saying this cant work.. just 2 regular universals would be better
  8. #28
    100+ Posts
    Feb 2017
    DE
    its i gutted cv joint . it has only 2 - 157x neapco ujoints
    we called them cv joints years ago (is that the right term?)
    i almost positive on part number. I've done this with 2 other builds.
    from what I've found 2 speed manual valve body's, don't like to be down shifted, maybe with less pressure they might work, so I'm in limbo, on if now i have to 3 speed it, and lengthen frame....������ not happy with another week of frame and longer 4 links, brake lines, ect. it was so close on a test run ���� pfffft.
  9. #29
    750+ Posts
    Jan 2010
    east windsor ct
    now i get it! u said stripped cv joint before... didnt understand
  10. #30
    Jun 2016
    milnor n.d. usa
    no xpert on powerglides, but could you revert to the original valve body. or use a vacuum modulator or some type of valving to reduce line pressure for a manual downshift?
  11. #31
    100+ Posts
    Feb 2017
    DE
  12. #32
    That's one bad a** looking trike
  13. #33
    100+ Posts
    Feb 2017
    DE
    trans going in for check up. going to drop pressures down towards factory settings. doing some writing then hope trans done quick
  14. #34
    100+ Posts
    Feb 2017
    DE
    big smile.......... need to button up some other things. nice pep. trans back in, and working
  15. #35
    Jun 2016
    milnor n.d. usa
    Good to hear tranny worked out...looks like the body is an easy install, looks great either way. Now to see some video of the trike running and driving?
  16. #36
    30+ Posts kodiak93657's Avatar
    Oct 2014
    Sanger, ca
    A curiosity question... I've seen a couple trikes with the long DOM tubing leading link front ends. it's a feature I'd build into a trike (If the stars ever align). I know a test ride hasn't happened yet, but I'm curious as to how "flexy" the tubing is. it seems to me like it'd flex laid way out like that...
    and that trike is wicked bad and nasty by the way. should be a hoot to ride! enjoy!
    Brettsky
  17. #37
    100+ Posts
    Feb 2017
    DE
    taged.....
    my guess, 70 mph. got windy.
    possible flex, as long as it's flex, and not bending.
    def.... hot on the stop light breaks. need to wrap last pipes on manifolds, each side.
    im supprised, they said 1700 lbs, me n bag of tools too.
  18. #38
    Oct 2014
    Sanger, ca
    Thanks for the info Twisted.
    helps this keyboard warrior see a better day.
    keep the rubber down.
    Brettsky
  19. #39
    100+ Posts
    Feb 2017
    DE
    i jacked right rear preload on that shock, so it pushed it up higher, i was having drifting to right, seems to cure the engine torqing, pretty good now.
    still no Speedo yet, going to get a new sensor, and ground hub, in case that's the issue.
  20. #40
    100+ Posts
    Feb 2017
    DE
Size:  790.8 KBName:  IMG_20210610_134650.jpg
  1. basket for trailer hitch
    By brianl in forum Trailers / Campers
    Last Post: 08-18-2013, 06:36 AM
  2. Appropriate Snacks for Your Easter Basket
    By 87Trike1200 in forum General Discussion
    Last Post: 03-31-2013, 07:20 AM
