Likes Likes:  6
Results 1 to 20 of 22
Thread: Hannigan 180 front end kit
    Apr 2017
    NL,CT
    Default Hannigan 180 front end kit
    I'm taking my Hannigan GW trike to KY so they can see why the installer has it sitting low and while it's there I may have them install their 180 kit.
    I'd like to hear from those that have the kit on their Wing.
    Would you do it again if you had to replace your ride with another one?
    Jun 2010
    Indianapolis, In.
    Please let us know why it is setting low, thanks
    As far as the 180 front, pretty big hit on cost for a fat tire!!! I asked a former manager at Hannigan what was done to the "inside" of the forks. For some reason, I never got an answer!!!!!
    I've followed the reports of one owner of the 180 on another forum. He posts praises for it with high mileage on the tire.
    I never got to test one so all I can do is post what this person had to say. Obviously he thinks it's great and well worth the money.
    Have you checked out the front available from EuroWing?
    BTW. NL,CT to Murray, Ky is quite a trip!!!! Did you ask if another installer closer to you could be paid by Hannigan to check it out?
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Mar 2011
    mountain home,ar. USA
    When I asked during my factory tour I was told they added heavier springs to the forks.
    As far as cost goes, if you had the 180 front end installed during the kit installation it would add about $1,000 over the normal rake kit and new front tire. Additionally, the new wider fender is built longer on the back side which save buying a fender extender. From the reports I've read, the primary one being the same person you are talking about, the ride, handling, and tire wear all significantly improved.
    As far as the Eurowing front end, I have questions but after repeated attempts to get some technical answers I have been unable to get a response. I question whether the built in rake kit would be sufficient for long wheelbase trikes like my Roadsmith since the Eurowing wheelbase appears to be the same as original bike. Plus, I've seen no reviews on how it handles compared to other front ends.
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by mhgoldwing View Post
    Not sure where your price came from but, the 180 front is approx. $4,000!!!! That's substantially more than a rake kit and new front tire!!!!
    Patriot Guard
    Was a LEO
    Jun 2010
    Indianapolis, In.
    But, what does heavier springs mean?? I wanted to know exactly what they were incase I wanted something different!
    When I got my Hannigan, I was told by one installer, he had sold 6 customers "heavy springs"(not the 180 fronts). 5 of those had returned asking for the OEM springs to be reinstalled, so he quit insisting on heavy springs!
    Some time later, it seems, Hannigan made "heavy springs" mandatory with any of their kits!?!?
    Patriot Guard
    Was a LEO
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Let me be clear.. I love my Hannigan kit on my 2012 Wing. That being said, I have also had questions that Hannigan never seemed in a hurry to answer.. The calipers are so small the rear brake pads do not last long at all. Also, I had to have the Progressive springs removed since the ride was so rough it broke my front fender. When I posted on this site about why Hannigan put such puney brakes on the rear they never answered, even with several reminders. When I got them on the phone they simply said that the brakes are motorcycle brakes. Hell, I knew that. Nothing looks as good as my Hannigan kit, ( IMHO) and I would probably buy another one but I wish the company was a little bit more forth coming.
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    On their web page they list the cost of their fat-tire kit. Not sure if includes labor.
    http://www.hannigantrikes.com/produc...-conversion-2/
    350+ Posts
    Jul 2016
    N Ky USA
    Quote Originally Posted by FRR View Post
    ............... Also, I had to have the Progressive springs removed since the ride was so rough it broke my front fender.............
    FRR, I'm not saying stiff springs didn't cause your front fender issue but many have had that issue including myself. When I was doing a little research on the goldwing front fender I found more mention of this occurring on 2012 models than other years. Most feel the fender extensions are the major cause of this problem..........I'm not completely sold on that.
    Good Luck with your Hannigan.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Quote Originally Posted by Bronson512 View Post
    Dennis, you bring up a good point here. I ride some rough roads here in Clermont County, (I'm sure you know where that is) and those Progressive springs shook my bike to pieces. My installer even mentioned that most of his customers that bought Hannigan's had him change the springs out back to stock. Oh, and I did take that fender extension and pitch it when I got my new fender. I know it didn't weigh much, but I didn't want to take any more chances.
    350+ Posts
    Jul 2016
    N Ky USA
    .................... Oh, and I did take that fender extension and pitch it when I got my new fender. I know it didn't weigh much, but I didn't want to take any more chances.
    when I replaced my front fender I went through the same thoughts. I wanted it on as I felt it offered protection to that area but I sure didn't want to take the risk of maybe another broken fender.
    I ride a CSC and I feel it's front suspension is too harsh. Many times it feels as the only suspension (give) is what little the front tire itself offers.
    Jun 2010
    Indianapolis, In.
    Several reasons for that feel!
    1. One of the biggest is the thought one needs to run 42psi in the front end!!! Just not true. Try reducing pressure to 36psi and see what you think!
    2. A stuck ADV. Take it apart and clean it, check to make sure it functions properly
    3. Yes, it can be the fork springs. Most of those "heavy springs" are just that, to heavy. Stock springs are good enough. Springs do wear out!!!! Mine were replaced at 32K miles with new take offs from a trike shop. Cost me shipping to get them!
    Oh, and don't forget to change the fork oil at the proper intervals!
    Patriot Guard
    Was a LEO
    350+ Posts
    Jul 2016
    N Ky USA
    Quilty as charged running 41 PSI. BUT my front tire is wearing flat. I'm concerned that by lowering the air pressure would expedite that.
    Ill take a look at my manual and see if this is something I feel I can handle. Thanks
    Since I bought the bike used and it has the rake kit (what ever CSC calls theirs) in it I've often wondered if it had some aftermarket springs installed.
    It's on the list of to do things. Got a oil weight suggestion?
    Jun 2010
    Indianapolis, In.
    Tires are not that expensive! The quality of the ride is greatly improved at the lower PSI.
    BTW, I have no experience w/the Avon trike tire. Not sure what the "good" psi for it is???
    Patriot Guard
    Was a LEO
    350+ Posts
    Jul 2016
    N Ky USA
    The tire presently on my trike was on it when I bought it. I don't remember it having a flat profile on it when I got it however with the approx. 3000 mi. I've put on the tire it definitely has flattened out. I have no idea the total miles on the tire but I'd bet its not going to get anything near what some of these guys & gals on this forum are getting.
    Jun 2010
    Indianapolis, In.
    What kind of tire is it?
    Patriot Guard
    Was a LEO
    350+ Posts
    Jul 2016
    N Ky USA
    Bridgestone BT-45.
    Mar 2011
    Avon told me to run 40-42 psi. I do. figure they designed and built they probably know the stresses, temps, etc. and what is best. I'm running two up and heavy.
    950+ Posts JaysGone's Avatar
    Nov 2012
    Delray Beach Florida
    Tires are not that expensive! The quality of the ride is greatly improved at the lower PSI. BTW, I have no experience w/the Avon trike tire. Not sure what the "good" psi for it is???
    Im with you and the 36psi front. As Ive stated a ton of times here. Ride quality is to me is greatly improved at 36 psi even less 33 is where Im at now with the Avon.The Avon tire.....................If someone had a new MPA and came over here. They could have mine.
    After 1500 miles and a lot of experimenting with pressures. I overall don't like it.
  19. #19
    Jun 2010
    Indianapolis, In.
    Bridgestone BT-45.
    That was my first trike front, run reverse rotation and at 42psi as I was led to believe at the time.
    Started cupping and at 17k needed replaced!
    Patriot Guard
    Was a LEO
  20. #20
    250+ Posts 07BlueCSC's Avatar
    May 2008
    Gasport, NY
    Bridgestone BT-45.
    I have about 15,000 on the BT45 @ 41psi and it looks new.
  1. New to me 2012 Hannigan Gen II with 180 front
    By Jobe05 in forum Honda Trikes
    Last Post: 07-31-2016, 04:56 PM
  2. My new hannigan trike - 180 front end
    By Doc* in forum Honda Trikes
    Last Post: 03-17-2015, 12:25 PM
