Likes Likes:  11
Thanks Thanks:  2
Results 1 to 15 of 15
Thread: Stage 2 on 2019 TriGuide
    10+ Posts RShomo's Avatar
    Oct 2018
    New Iberia,LA, USA
    Default Stage 2 on 2019 TriGuide
    Well I am taking my 2019 TriGuide to the dealer tomorrow to have a Stage 2 upgrade put on it. SE Torque Cam, exhaust, hi flow Arlen nest inverted air filter and SE Pro Street Tuner. Will see how it runs afterwards.
    Quote Originally Posted by RShomo View Post
    Is that gonna void the warrantee?
    Oct 2018
    New Iberia,LA, USA
    Not suppose to , Harley cam, and tuner
    Oct 2018
    New Iberia,LA, USA
    Got the bike back, went for a short ride. Nice improvement over stock, haven’t run it hard yet, wanted to put a couple hundred miles on it first. But on just a short cruise, pleased with the improvement and it sounds much better.
    I did the stage 1 on my X 2011, That was well worth it.......
    Oct 2018
    New Iberia,LA, USA
    Well I have put a couple thousand Miles on the Tri glide since the stage 2 was installed. Has been really good, runs a lot stronger, sounds a lot better. About the only negative thing I can say is it did not cool it down any, bike is still hot on the right leg and the fan runs for 20-30 sec every time I turn it off. I was hoping the stage 2 setup would have also cooled it some. But the bike puts a smile on my face every time I ride it.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    If you didn't remove the cat in the head pipe or replace the head pipe you are still going to have some heat issues.Also the Harley tuner will still make it run within EPA regulations which means lean.On Nov 3rd i'm taking my 17 Tri Glide in and having the S&S 465 cam installed along with the upgraded oil pump,S&S lifters,adjustable push rods,S&S tappet guides along with a gutted head pipe and a TTS tuner.So i'm hoping the heat issue is better along with better performance.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    With a slightly hotter cam, it is probably running a bit hotter. There are things you can do, see the written Report at this LINK
    and below is the first video in a series on this subject-
    www.DKCustom.com
    150+ Posts David792's Avatar
    Mar 2019
    Idaho Falls, Idaho, United States
    Do you know the HP and Torque benefits? My 2018 could use a little more passing power.
    2018 Tri Glide Ultra Classic. Vivid Black.
  11. #10
    10+ Posts nukie2000's Avatar
    Oct 2020
    Miami, Florida, USA
    Well I am taking my 2019 Tri-Guide to the dealer tomorrow to have a Stage 2 upgrade put on it. SE Torque Cam, exhaust, hi flow Arlen nest inverted air filter and SE Pro Street Tuner. Will see how it runs afterwards.
    I too installed a Stage II kit with Pro Street Tuner and Auto Tune module with the wide band O2 sensors. Vance & Hinds header removing the cat converter and Cobra mufflers. Had Palm Coast H.D. in Florida install the Stage II so as not to void the warranty.
    I runs great and plan on taking it cross country next year after I install the rake and lift kits with the new shocks.
    Mine is Scorched Orange like yours! I love that color!!
  12. #11
    Oct 2018
    New Iberia,LA, USA
    The Stage 2 did replace the stock head pipe with aftermarket cat-less headpipe. It still is hot on the leg. No we didn’t put the bike on a dyno so I don’t have any hp/tq numbers. But it pulls a lot stronger Very happy with the bike now, just wish it was a little cooler.
    i previously has a 2012 CVO Ultra 110 (which run hot), had the exhaust changed to Rinehart True Duals and HD SE Super Tuner, put the bike on the dyno and properly tuned it. Bike run real good and a lot cooler too. This is what I was hoping for with the Stage 2 On the TriGlide .
  13. #12
    350+ Posts
    Aug 2020
    Monaca, Pa, USA
    Quote Originally Posted by nukie2000 View Post
    which cams did you get? 447 or 462?
  14. #13
    Dec 2013
    Clarion PA USA
    Heat management is a long process well it was for me. Started with floorboards extended an inch outward ' a great tuner, I lifted the tank to force more air on motor, purchased air deflectors to assist air on motor, wrapped header pipe with Titanium DEI BRAND. Custom designed an enlarged oil cooler and installed love jug fans. Now on 90° days oil temperature 215-225 Engine temperatures 220-240 Now comfortable any time.
  15. #14
    30+ Posts
    Dec 2020
    Seabrook, SC, USA
    Stage two with OEM parts you are still shorting yourself. To achieve the full benefits of your $$$$ invested, you need to get it tuned, which will entail unlocking the ECM, thereby voiding your warranty, also sending a red flag to harley. However, that SOB will run like hell, hold on...I know...
  16. #15
    1500+ Posts
    Apr 2016
    Dayton Ohio
    Quote Originally Posted by David792 View Post
    Got my 17 back from the shop, using a s&s 465 cam ,stage 1 air cleaner and a TTS tuner along with a Fullsac Sport pipe and started at 73 hp and 96 ft lbs torque and ended with 90 hp and 107 torque. And it runs amazing with the torque coming in at a lower rpm for lots of pull away power.
  17. DKCustoms postbit
  1. attn. anyone installing the perf. machine stage 1 brake system(help)
    By eagle1 in forum Harley Trike Conversions
    Last Post: 02-20-2012, 10:15 AM
  2. Performance Machine Stage 1 install experience
    Last Post: 02-14-2012, 04:49 PM
  3. Replies: 3
    Last Post: 12-21-2011, 09:15 AM
  4. '09 t/g installing p/m stage 1 rear brakes
    By eagle1 in forum Harley Tri Glide
    Last Post: 11-19-2011, 05:40 PM
  5. triguide stuff
    By red shuffles in forum Harley Tri Glide
    Last Post: 08-23-2011, 07:53 PM
