Thanks Thanks:  5
Results 1 to 10 of 10
Thread: CB Volume
    30+ Posts
    May 2010
    Hoschton, GA
    Default CB Volume
    Is anyone having a problem with low cb volume. I can’t seem to hear my cb very well compared to the rest of the things like gps and apple CarPlay.
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    I had the same problem and some things to try are, adjust the speaker to the center of the ear, turn the squelch down till you can hear the rush noise and then try turning up volume on helmet, go into settings on bike and make sure the volume is wide open all the way up you can also do this while the CB is active. What type headsets are you using?
    2019 Goldwing CSC
    Jul 2012
    Talladega,Al 35160
    I know you said everything else comes through fine but if it is the speakers then you will just have to turn the rest down after you adjust them because the CB just does not have the volume everything else has, and another tip if the CB is receiving a signal either from someone transmitting or because the squelch is to low the other volumes will not operate on the bike. Oh and try talking to different people I ride with some that do not come through very well and others that come through just fine I use my handheld when I'm checking mine, good luck
    2019 Goldwing CSC
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Not to be a wise guy (really) but you do know that your CB has its own separate volume adjustment.....?
    2014 CanAm Spyder RTL SOLD
    Semper Fi
    30+ Posts
    May 2010
    Hoschton, GA
    Quote Originally Posted by woody View Post
    I have a Sena 50s. I will try lower settings on other volumes and let you know, thanks
    30+ Posts
    May 2010
    Hoschton, GA
    Quote Originally Posted by cScjhb View Post
    Yes, and I have it set at 20, thanks Marshall
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Quote Originally Posted by marshall View Post
    Try sending your CB to your bike speakers. If that works, then you probably need ot better adjust the headsets.
    I should probably ask first - what bike and year?
    30+ Posts
    May 2010
    Hoschton, GA
    Quote Originally Posted by cycle7447 View Post
    Good idea. Thanks
    30+ Posts
    May 2010
    Hoschton, GA
    Default Problem fixed
    Bad antenna ground strap. Thanks for all the help.
    Marshall
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Marshall
    Thanks for letting us know. This will indeed help others.
  1. Infotainment Volume Control
    By briar in forum Harley Tri Glide
    Last Post: 08-03-2018, 03:37 PM
  2. Goldwing Trike Intercom Volume
    By paid4c4 in forum Honda Trikes
    Last Post: 10-10-2016, 05:37 AM
  3. Navigation Volume
    By davek in forum Harley Tri Glide
    Last Post: 07-14-2015, 10:44 AM
  4. GPS volume
    By Beorn of Ga in forum Harley Trike Conversions
    Last Post: 05-12-2013, 07:52 PM
  5. JM GL1500 CB, Volume, Mic On/Off Pass Controller
    By retdpd in forum Honda Trikes
    Last Post: 09-24-2010, 07:06 AM
