ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Likes Likes:  33
Thanks Thanks:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 27 of 27
Thread: How Common Are Flat Tires On A Trike?
  1. #21
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Quote Originally Posted by Motorcycle Mike View Post
    Good advise. However, there are times when insurance isn't worth a dime.
    The two times I called AAA for a tow because of a flat on my two wheelers they didn't have anybody who was capable of picking it up on their list even though that coverage was in my plan and this was in New Jersey. Managed to limp it home both times, but it wasn't a pleasant experience.
  2. #22
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Quote Originally Posted by priell3 View Post
    I carry this kit.
    Attachment 105669
    I had a Slime in my Jeep for a while. I didn't like the valve nozzle. It was so poorly designed by the time I got it off the valve stem half of the air I put in had bled out. I prefer the screw on type fitting. Very minimal air loss.
  3. #23
    Quote Originally Posted by JTJersey View Post
    To use The Slime in the picture you remove the valve core..[The black cap is the removal tool].....Then you squeeze in the slime reinstall the valve core ...And then use the compressor to fill the tire ...So theres no air loss...
  4. #24
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    Not what I meant. It's the nozzle on the air compressor that's the problem. Getting it off was such a chore that it would bleed out more air than I put in, that's why I prefer the screw on type nozzles for a air compressor.
  5. #25
    900+ Posts
    Bellville, Texas, USA
    I have always carried a compressor, plug kit and a can of Fix-a-Flat. Never had to use it on my bike but used it twice for people that were riding with me. I like the Fix-a-Flat because you don't have to remove the valve core. Just screw it on, inflate the tire with the air in the can and ride or roll the bike slowly for a few feet to coat the inside of the tire with the sealant then use the air compressor to top off the air if the can doesn't inflate the tire to riding pressure. It will even work on a tire with a tube if the tube isn't ripped. I carry the larger size can of Fix-a-Flat.
    Sunman
  6. #26
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    An important thing to know about towing services is that all I am familiar with (HOG / AMA / insurance policy) will only transport to nearest dealer. AAA will transport motorcycle up to 100 miles wherever you want it to go. Motorcycle coverage is an 'add on' to AAA membership. It is not included with standard auto membership . . . but it is very affordable.
  7. #27
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    In close to 200k miles I've found one nail in my rear tire. It was not flat, I noticed it when doing a pre-ride inspection.
    I was out of town and had my plug kit with me.
    I also carry a USB rechargeable air pump with me. I use it all the time to keep the tires at the correct PSI. Have also helped many other folks out with it while on the road. Here's a LINK to it.
    www.DKCustom.com
  1. Common Sense - What happened to it?
    By Papa Zook in forum General Discussion
    Last Post: 01-18-2022, 01:21 PM
  2. Oh them big flat rear tires
    By the paparazzi in forum Tires, Wheels, Brakes, Front End
    Last Post: 07-06-2016, 09:55 PM
  3. Lions and Tigers and Flat Tires, Oh My!
    By kam582 in forum Honda Trikes
    Last Post: 05-19-2014, 06:35 AM
  4. Run flat rear tires on a trike??
    By Dante221 in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-30-2012, 05:43 PM
  5. Is this csc problem common place???
    By The Wolf in forum California Sidecar Trikes
    Owners Forum
    Last Post: 11-22-2010, 06:25 PM
