2002 Lehman Trike Drum Brakes
If and when you decide to change the rear shoes, use riveted linings instead of bonded
WE had MANY fords and chevys with rear bonded brakes acting crazy
Once we switched the linings from bonded the problems went away
You're probably gonna find they are 9" diameter x 1.75" wide Ford Brakes like used on so many Fords like Mustang, Thunderbird, Pinto, Ranger PUs, etc. in '70s up into '90s even. Raybestos 474PG or Wagner Z474R or Motorcraft BR75B or cross it over. Same thing on return springs, same as say a 1980 Mustang with 9" rear drums.
Crystal Pistol: Many thanks for the info! Goldfever....
Rogue24
Rogue24
