Likes Likes:  2
Results 1 to 5 of 5
Thread: wrap around heel guard to save fenders
    Sep 2010
    Burlington, Iowa
    Default wrap around heel guard to save fenders
    Okay...finished up my Frankenstein conversion...every thing went great. I'll post pictures as soon as I get a good sunny day lined up....needed to know what you guys are using or making to keep the passenger's boots ON the small floorboards? Not worried about pipes...worried about the foot moving off the boards and banging into my paint job on the fenders. I moved them from stock so that they're about an inch or two from the fender....but worry about the boots sliding off during riding. Spent (TOO) much money on a real flame job to match up with the orginial paint on the tank and fenders. I've looked up heel guards but also all of them are on the inside of the floorboards....I did find one that they called the Handicap heel guard that wrapped around the back of the floorboards a little better, but not quite enough for me. Thought I read about someone building something to go around the back half of the floorboards but can't find it now.
    Any suggestions?
    Thanks!!
    Jun 2010
    Indianapolis, In.
    3M StoneGuard or Rhino Liner on the forward facing part of the fenders fenders or you will get rock chips in the paint soon.
    Will also protect from boot marks
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Default 3M
    Amazon has rolls of clear stone guard, as a cut to fit application, Plus it’s cheaper than pre-cut pieces. Easy application and removal If necessary.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Alvin View Post
    Any suggestions?
    Thanks!!
    Al, without a picture of the floorboard, it is difficult to answer your question since so many different boards are being used.
    I made one set for a customer that had polio as a kid and lost most control over their lower extremities. I used a 1/8" X 1 1/2" piece of steel and bent it into the shape I needed to keep his feet on the floorboards without the use of a velcro strap.
    I made another out of 5/16" steel rod as well for another customer.
    They make some like that right now but the don't fully wrap the back of the board like mine did.
    So much depends on the type of board you wish to use.
    I did this long ago and don't have pictures either.
    Jim Murphy
    Iron Butt Rider 2001
    Sep 2010
    Burlington, Iowa
    Thanks guys for the information. I will try to get a picture of the boards and perhaps between all of us come up with a solution to the problem.
    Thanks again and keep any additional ideas coming.
  1. Wrap around fender
    By gerald martin in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-09-2017, 03:23 AM
  2. Harley rider footboard heel guard.
    By DonC in forum Harley Tri Glide
    Last Post: 01-09-2016, 12:14 AM
  3. Aftermarket Trunk With Wrap-Around Backrest
    By Scratch in forum Suzuki - Kawasaki Trikes
    Last Post: 12-15-2014, 07:39 PM
  4. heat wrap exhaust tape
    By tryker55 in forum Harley Trike Conversions
    Last Post: 10-07-2011, 04:45 PM
  5. Exhaust heat wrap?
    By NosMan94 in forum Harley Trike Conversions
    Last Post: 04-24-2011, 11:54 AM
