Results 1 to 8 of 8
Thread: Champion S/A rear end question
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    Default Champion S/A rear end question
    My left Axle is leaking fluid for the second time. It was just fixed under warranty a couple months ago. Question...Before getting it fixed again I want to check the rear end level but am not sure where the oil should be. Champion says when changing fluid not to put in more than one quart and I'm told that this won't take it up enough to drip out when the plug is removed. But..how much below this port should the oil be? Champion says not to fill above that hole, but that's really impossible. The leak is very small but I don't want to run low on oil before I can take it in.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
    150+ Posts Teal's Avatar
    Jun 2011
    tenn
    Default Re: Champion S/A rear end question
    you got mail
    1500 2011 Champion trike
    KR4VA
    US Navy Aviation
    Surely Goodness and mercy shall follow you all the days of your life:)
    250+ Posts Stephen's Avatar
    Jul 2010
    West of Houston
    Take out the plug and stick your finger in to your knuckle and then bend it down then pull it out. If there is oil on your finger you should be good to go. Works with most automotive rear diffs. Of course this will not work with Roadsmith because the RS rear diff has another plate attached to it so you can't get your finger in there.
    Nov 2011
    Quote Originally Posted by Stephen View Post
    Thanks Stephen. I guess you're saying about 3/4" below the hole?
    LES
    Prowler # 67
    Iron Butt #33529
    Jul 2010
    West of Houston
    Sounds about right.
    Jun 2011
    tenn
    Shimpy
    im by-passing the dealer(3 months)they too to fix the last one... still waiting on champion to respond to my warranty request to do it myself.
    KR4VA
    US Navy Aviation
    Nov 2011
    Now that I know where the oil level should be I discovered I don't have a 24mm wrench or socket to remove the inspection plug. This will also fit the drain plug. I've got a 6 point 1/2" drive socket on order from E-bay.
    LES
    Prowler # 67
    Iron Butt #33529
    Jul 2010
    West of Houston
    Quote Originally Posted by Shimpy View Post
    Don't feel bad when I went to the 6 degree rake I didn't have a 30 mm socket. Just ran down to Sears and bought one. It'll be all nice and shiny still when I need it again in about ten years.
  1. Champion driveshaft question
    By RoscoeD in forum Honda Trikes
    Last Post: 03-15-2022, 06:17 PM
  2. Champion rake kit question
    By scribe5 in forum Honda Trikes
    Last Post: 10-31-2013, 06:11 AM
  3. Champion Rear Shock Adjustment
    Last Post: 10-22-2013, 06:58 AM
  4. Unpainted Champion Kit Question
    By Kocomo in forum Honda Trikes
    Last Post: 03-22-2011, 07:55 AM
  5. New Champion Independent Rear Photos
    By Papa Zook in forum Honda Trikes
    Last Post: 02-14-2009, 10:12 AM
